Question about Onkyo DV-SP500 DVD Player
Onkyo DV-SP500 It's not been used for 3 years. Just reconnected it. Power light is on, but nothing on the display. DVD drawer doesn't open (not even a sound. If i press "play" the TV detects it and changes channel ready to play, then goes back to TV channel as no DVD is there to play. So the player is communicating with the TV in some way.Any ideas, as it was working when we put it away?
5 Suggested Answers
SOURCE: DV-C501 MECHA ERROR
That is a great one! I got a good laugh and sure enough it worked like a charm!
Posted on Jul 20, 2007
SOURCE: Onkyo DV Sp500 DVD player set for US region but i Have DVDs from
icon_minipost.gifRegion code hack posted by Victor Lazlo, July 14 2003:
Steps to change Region code:
1. open setup menu (with setup key)
2. select menu point 'General' (dt. 'Allgemein')
3. select sup-menu point 'Setup-Menu Mode' (dt.Setup-Menü-Modus)
4. at 'Setup-Menu Mode' select 'basic' (dt. Einsteiger)
5. confirm 'Basic' sellection with 'Enter' key
6. now push 'Display' key at your remote control, the present regent code will be displaid
7. to change the region code push 'Condition Memory' key (COND.M) at your remote control, afterwards a number key representing the region code you want to select
8. after a successful change, the disply of ther regional code will disappear
9. if pressing the 'Disply' key again the changed regional code will be shown.
Remark: Macrovision copyguard in gerneral will be switched off after that modification
refer to:http://www.videohelp.com/dvdhacks
Posted on Feb 05, 2009
SOURCE: Remote control via RI terminal on Onkyo Receiver
Not sure I can solve, but maybe help. I am having a similiar problem. However, make sure you Analog Audio (RCA type) cable are connected even if using Digital connection between the two. They use those cable to send the Commands (Mentioned in the documentation).
If you did get yours to work, please give me a hint... I upgraded mine from a 603 to a 701 and haven't been able to get it to work since.
Posted on Feb 14, 2009
SOURCE: Onkyo DV-SP301 DVD player stuck in standy mode
Had an Onkyo DV-SP301 that would only intermittently come out of standby. Found faulty resistor R2 on the power supply board (board ORTP-865), it was nominally 5600 ohms, measured much higher. This after checking most p/s caps! R2 runs warm when unit is in standby, so you may want to replace with a higher power rated resistor. I used same rating but 10 k ohm instead, worked fine then.
Posted on May 31, 2009
The remote for my sp-500 no longer works,so I ordered a new one which does not work either. Whats the problem?
If the actual remote has been ruled out as the problem about all that remains is the remote receiver in the set---I will attach a photo of a typical one--part is usually less than 3/8 inch tall and may not have the metal frame in the picture--3 leads is most common.
It receives the signal from the remote and routes it to the unit.12_21_2012_4_51_13_pm.jpg
Dec 21, 2012 | Onkyo DV-SP500 DVD Player
Pioneer DVD player DV-220v-K not responding to Open Drawer command
This is a mechanical problem and will only get worse, caused by gear ware timing issues, or jamming.
Apr 19, 2012 | Pioneer Televison & Video
The Onkyo DV-CP706 changer doesn't seem to complete its boot-up whenever turned on. The console display says "OnkyO DvD" and nothing else. The monitor display indicates "No Disc"...
Hello, I am sorry about you issue. It sounds like your player needs to be serviced. I have included a link to search for an authorized service center. Thank you, Onkyo USA
https://www.onkyousa.com/Support/servicecenterlocator.php
Jun 15, 2017 | Onkyo DV-CP706 Multi-disc DVD Player
Dvd "drawer" will not close.
The reason the drawer will not shut is because there is a problem on the mechanism that opens and closes the disc tray.
To fix this,
Get the appropriate screwdriver, unscrew the cover, you'll see a mechanism by the side of the opening, you'll see a rubber that controls the opening and closing of the door.
Try to replace the mechanism and it will be in good condition again.
take care
Jun 12, 2010 | Onkyo DV-S353 DVD Player
Onkyo DV Sp500 DVD player set for US region but i Have DVDs from Australia - is there a code to unlock the player or do i need to purchse a new one?
Jan 25, 2009 | Onkyo DV-SP500 DVD Player
My onkyo dv-cp704 powers on but frrezes after
HI...
A problem like that will need tech service.
Check the onkyo consumer site for service people
Dec 05, 2008 | Onkyo DV-CP704 DVD Player
Nov 28, 2008 | Onkyo DV-SP301 DVD Player
Jan 20, 2008 | Onkyo DV-SP800 DVD Player
Unlock procedure for Regions
1. Press Open/Close on remote control. DVD tray opens. 2. Press the following buttons in sequence: 2, 8, 1, 2. 3. TV displays "Region 2" 4. Press the Enter button on the remote until code changes to 9 5. Press the Open/Close on the remote. DVD tray closes. 6. Press Power on the remote control. Now code free...
Jan 04, 2008 | Onkyo DV-CP704 DVD Player
DV-C501 MECHA ERROR
I have actually had the same problem multiple number of times now and am going to suggest you a rather "crude sounding" solution!! First, atleast in my case the problem usually occurs when you turn the DVD player off while it still has DVD/CD inside and then turn it back on a little while later. This is how the "solution" works. I just disconnect the player and give it a good shake !! This somehow dislodges the "stuck" disc inside and voila, the player opens up after reconnecting and pressing the open/close button. Sometimes it takes more than one "good shake". Sounds rather severe but works everytime !!
Oct 04, 2006 | Onkyo DV-C501 DVD Player
Onkyo DV-SP500 DVD Player Logo
Top Onkyo Televison & Video Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
