Question about Cycling
I want to replace my son's brake and gear cables on his pacific coast montainbike it is a dyno high altitude model# D2438TR,date,FSD)#JH.i want an owners manual or diagrams of the replacement he removed all the cables before i could get a chance to look at them to find how it went back together. thank you, cmcristea @ yahoo.com
fellowesrep
  • 102 Answers
SOURCE: paper shredder gear is stripped.....replacements?
Best bet is Royal Customer Service at 888-261-4555
Posted on Mar 02, 2008
SOURCE: Need owners manual
Have ilo32hd no manual...can't get into menu
Posted on Feb 03, 2009
  • 416 Answers
SOURCE: I need a owners manual
Please go to this link
http://www.funai.us/funai/support/index.html
Follow to Owners Manual and type your model
This the link for PDF for model wv20v6
http://www.funai-corp.com/6pdf/om/WV20V6.pdf
I just check it works
Good Luck
Posted on Feb 09, 2009
  • 653 Answers
SOURCE: I am looking for owners manual for my Symphonic TV
Go to www.symphonic.us/pdf/om/WF20L6.pdf and print the manual (or just save it on your computer).
Posted on Feb 28, 2009
honeymokey
  • 3113 Answers
SOURCE: cannot remove socket from "high" mount brake light
It has melted. Having worked at a dealer I have seen this before. Dealerships deal with problems like this often .They will know the correct bulb to put back in to keep from melting the housing.
Posted on Apr 21, 2009
When i decel it seems I have a engine brake on or in a lower gear how do I fix this
The 650 Burgman has similar engine braking to a normal motorcycle so doesn't allow you to coast as with the smaller engined models. This allows greater control in deceleration, especially in the wet. The coasting on the smaller models can be disconcerting for some, where brakes have to be used to slow down, so make the most of the 650 capability. The 650 will coast eventually at speeds of less than slow walking pace. From what you say consoder this as normal behaviour from the engine.
Take care.
Jan 06, 2014 | 2003 Suzuki AN 650 Burgman
89 pacific coast honda need to install choke cable how do i get the cables hooked into the carb?
Hi, Vccansler sorry you can't find the first and best tool you ever bought for your Honda despair not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
PC800 carburettor tear apart Not Your Average Engineer
http://pc800.co.uk/mwf/attach/13/3413/pc800info.pdf
PC 800 Service Manual
PC 800 Owner Manual
Sep 11, 2011 | 1991 Honda Pacific Coast
The twist shifter is so tight that my son can't shift. I have a hard time doing it. Is there a way to loosen it?
Is the shifter too tight or the cable not flowing freely in the housing?
Shift it to the position that relaxes the cable and manipluate the affected derailleur to see if the cable allows it to instantly spring to its relaxed state. If it doesn't you need the cable(s) serviced and/or replaced.
http://www.sheldonbrown.com/cables.html
Search engine: "how to service shifter cables" for videos
Tools and how-to's: http://www.parktool.com/blog/repair-help/categories/derailleur-systems
http://www.sheldonbrown.com/gears.html
Jun 28, 2011 | Pacific International Pacific Highlander...
The gears will not change at all. It seems like the part that you twist to change gears is seized on both sides. This is causing the bike to ride very slow.
Actually, it's causing you to have no gearing options. If you were Lance Armstrong the bike would move fast ;0) even with a flat tire.
http://www.parktool.com/blog/repair-help/shift-levers-shifters
Crimped, corroded shifter cables can prevent accurate shifting. I'm thinking you need a bike mechanic to look at it.
After it's all fixed you might want to view some resources concerning shifting, braking and general riding skills. It's all out there.
Feb 23, 2011 | Pacific International Pacific Evolution...
HP increase at elevation using a Dyno Jet Dyno?
same dyno? same operator? theres something wrong. the lower altitude the better, as far as I know. But someone thats smarter than me and has high altitude /dyno experience would be better to answer the question.
Oct 01, 2009 | 1983 Mazda RX-7
2001 Accent stick shift sputters in low gears and at high speed.
I suspect the timing is off since timing belt replacement was mentioned. The altitude would be read by the various sensors in the engine and computer and would be compensated accordingly.
Aug 10, 2009 | 2000 Hyundai Accent
How to change front tire on honda motorcycle
if you lift your bike high enough, you dont have to touch the callipers. maybe just loosen the bolts, thats all.
Jun 21, 2009 | 1989 Honda Pacific Coast
Cycling Logo
49 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
