Question about LG Vu CU920 Cellular Phone
What is lattice enthalpy - LG Vu CU920 Cellular Phone
  • 179 Answers
The lattice enthalpy for a particular ionic compound is defined as DH for the process what is lattice enthalpy - image636.gif. This cannot be measured directly as it is not possible to get this reaction to happen on its own, without many other reactions happening around it. Separate ions cannot be brought together in this way.
Posted on Aug 29, 2010
2NO +O2 yields 2NO2 Delta H=-114.6 Kilo Joules. What is the change in internal energy?
Enthalpy is equal to the internal energy of the system plus the product of pressure and volume.
Apr 08, 2017 | Homework
Tip
SERVCIE MODE
Panel Check
You have to check Panel Maker Because of different adjustments as follows. First of all, Check the label rating!
1) Label Rating File
- LCD PANEL MARK
A:ACER(AUO) S : SEC C : CMO
* If not printed you could consider S(sec) panel mark.
Method of Color Calibration (AV)
1) Apply the NTSC Lattice (N0. 3) pattern signal to the AV IN 1 port
2) Press the Source key to switch to "AV1" mode
3) Enter Service mode
4) Select the "Calibration" menu
5) Select the "AV Calibration" menu.
6) In "AV Calibration Off" status, press the " RIGHT ARROW" key to perform Calibration.
7) When Calibration is complete, it returns to the high-level menu.
8) You can see the change of the "AV Calibration" status from Failure to Success.
Method of Color Calibration (Component)
1) Apply the 720p Lattice (N0. 6) pattern signal to the Component IN 1 port
2) Press the Source key to switch to "Component1" mode
5) Select the "Comp Calibration" menu.
6) In "Comp Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "Comp Calibration" status from Failure to Success.
Method of Color Calibration (PC)
1) Apply the VESA XGA Lattice (N0. 21) pattern signal to the PC IN port
2) Press the Source key to switch to "PC" mode
5) Select the "PC Calibration" menu.
6) In "PC Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "PC Calibration" status from Failure to Success.
Method of Color Calibration (HDMI)
1) Apply the 720p Lattice (N0. 6) pattern signal to the HDMI1/DVI IN port
2) Press the Source key to switch to "HDMI1" mode
5) Select the "HDMI Calibration" menu.
6) In "HDMI Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "HDMI Calibration" status from Failure to Success.
FOR MORE DETAILS CHE THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB FIND MODELS OR USE DROP DOWN MENU
on Jun 30, 2015 | Samsung LA32A450 32 in. HD-Ready LCD TV
How do I calculate the enthalpy when given quantity of air of 300kg/s in a depth of 2000m?
Instead of multiplying the number of posts, try to give a description of the system you are trying to model: If the question comes from a book post it in full, including diagrams. That will increase its chances of being answered, but will not guarantee an answer.
Feb 15, 2014 | Office Equipment & Supplies
If a reaction absorbs 40K.J of energy,what is deltaH of this reaction
Energy absorbed by reaction mean the reaction is endothermic. If the reaction is endothermic the change in enthalpy is positive. Delta H is +40 kJ
Oct 07, 2013 | Office Depot Elementary school Physical...
H08882ROTX sei lattice
The drawer was very hard to place in the slider runners, took 20 mins to get it in without it locking and getting stuck. Please note the small grayish tabs in side both slider runners, very hard to press theses tabs and see them but these tabs do release the drawer from being locked when you only have it half way in the slot it goes in.
Mar 08, 2013 | Southern Enterprises Lattice 48 in....
Estimate the bond energy' S-F' in SF6.the standard enthalpy of formation of SF6(gas),S(g),F(g) are-1100kj/mole,275kj/mole,80kj/mole respectively
What is the S-F bond energy in SF6 given DHfo for each of the reaction components?
For this problem you must first calculate the change in enthalpy (heat transfer, delta H under standard conditions) for the conversion, S(g) + 6F(g) => SF6(g) OR for the reverse reaction, it really doesn't matter, because the numerical value will be the same, regardless. Once you calculate the heat transferred, you will be able to say that the amount of heat transferred was the amount of potential energy trapped in all of the S-F bonds, all six of them in the molecule. So, to obtain the answer asked for (the energy content on one S-F bond), all you will have to do is divide by 6.
The above is a logical approach, because all six of the S-F bonds are identical. This is so, because, according to VSEPR theory (look it up for more background on that, if you are interested), you can predict that its molecular geometry is "octahedral" with the central sulfur atom having "sp3d2 hybridization."
Here is how you set up the problem:
First write the balanced chemical equation with the given heats of formation (in kJ) written under each of the reaction components:
275 6(80.) -1100.
Note: I am assuming that each of the above quanties is good (i.e., known) to at least the unit's place; that is, + or - 1 kJ. This reasonable assumption allows me to unambiguously indicate the number of sig figs in each quantity - an important consideration for proper rounding off of the final answer.
Recall that the sum of the product values minus the sum of the reactant values, each component multiplied by its corresponding coefficient will give the net enthalpy ("reaction enthalpy") of the reaction as written. In this case, there being only one product, the reaction enthalpy is:
-1100 - (480 + 275) = - 1855 kJ. From this, we can see that as S and six Fs are combined, 1,855 kJ of heat are released into the surroundings (that is, an exothermic reaction). The amount of heat released informs you of the combined bond energy of ALL six S-F bonds.
A good rule to remember: As bonds are formed, energy is always released (an exothermic process). As bonds are broken (as in the reverse reaction), the same amount of energy is being absorbed (an endothermic process).
Therefore, in conclusion, one S-F bond has a bond energy of 309.17, which is more properly rounded off to 309 kJ.
Recall that the rule for rounding off when adding or subtracting is to make sure that the final answer has the same precision as the values used to calculate it. Since each given value was good only only to the last unit
Nov 22, 2010 | MPS Multimedia QuickStudy Chemistry for PC
I plug my dehumidifier in and I get no power. It did work then it just stopped
check the adjustment of the humidity control. it is also called the enthalpy control. check the level switch in the water bin.
Oct 13, 2009 | Maytag M7DH65B2A Dehumidifier
Matlab Solution for Work requirement and volumetric flow rate
please give me more description of the machine please
Sep 27, 2009 | Air Tools & Compressors
505V lattice-type background
You may sometimes see this. It is normal, when it does occur. I believe this has something to do with the fact that the F505V relies upon a diamond-shaped shutter/aperture design rather than having more leaves. This leads to other interesting effects with diamond-shaped lens flares, etc. Not ideal, but nothing to worry about, really. It won't detract from the beauty and sharpness of your images.
Sep 11, 2005 | Sony Cyber-Shot DSC-F505V Digital Camera
LG Vu CU920 Cellular Phone Logo
105 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
