Question about Graco DuoGlider 7924 Twin Seat Stroller
Can't fold up.....
When I purchased this on ebay there were no intstructions. Model # 17048FRK. The rear of this double stroller has a pull up handle to release the catch in the rear but after that it won't budge. Can you help me?????? Barb Kolterman
Follow this link for a pdf version of the manual.
I did not see the 7924 model but there is a link for the 7923 and 7925. One of those should be similiar enough to get your problem solved. Please rate me well if this helps out.
Good luck and take care,
Posted on May 07, 2008
Instructions on how to fold
Kindly follow the steps to below to fold the stroller:
  • Use the ball of your foot to push down on the brake lever, located near the rear wheels of the stroller. Gently push on the stroller to confirm that the brakes are set. Grip the front edge of the stroller's canopy, if present; pull the canopy back towards the rear of the stroller.
  • Push the tabs securing the ends of the harness straps to the harness buckle. Pull the straps aside and remove the child from the stroller.
  • Kneel down next to the stroller's front wheels. Locate the locking mechanism set in between both pairs of front wheels. Use the locking mechanism to disable the swivel feature on the front wheels.
  • Pull the stroller's seat back down to the lowest position; some models may feature locking mechanisms located on the sides of the stroller or built into the handlebar. Lift any latches securing the sides of the stroller in place.
  • Push the handles of the stroller downward. Push the rear section towards the front of the stroller until the device is fully folded. Clip the storage latch located on the side of the stroller to the side of the handlebar.
Apr 24, 2016 | Baby Gear
How do I fold a Baby Jogger II 15
Baby Jogger's patented Quick-Fold Technology, this stroller is the only in-line stroller to fold flat in one simple step. Just pull the clearly marked "FOLD" handle and the stroller or jogger collapses into an easily loadable and storable unit. This is quite possibly the easiest fold on the market today.
Sep 16, 2012 | Baby Jogger Twinner II Stroller
Where is the serial number and the manufacters date on the stroller
It is engraved on the frame, on the right rear, above the right rear wheel. (City Elite Single )
It is engraved in the frame, on the right side of the stroller, on the lower side of the right folding handle, under the logo. (City Elite Double )
Dec 03, 2010 | Baby Jogger Onyx 2010 City Select Stroller
How do you fold down the valco runabout trimode stroller? I bought a used model and I can get the top half to fold over but that's it. Can it fold over more compactly? I'd like to travel with it. Thanks!
to fold the stroller yo need to:
1.fold the hood back up against the handle.
2.release the locking clamps at either side of the stroller.
3.simultaneously lift the secondary safety catch and swing the handle forward.
4.holding the frame at the rear, press down on the rear basket tube. also can lock the frame with the strap next to the frame.
here you have the manual, could be easy with de graphics!
hope to being helpful!!
(if so, dont forget to rate me!)
Sep 25, 2010 | Valco Runabout TriMode Single - Stone...
How do i close a eddie bauer double stroller of model 010478
I will just try and tell you how I did my stroller, on the back of each back wheel you have to push down the knotch left and then right, then you grab a metal bar in the middle back pull it slightly then click the handle and push the stroller forward and usually it magically folds up. However don't get frustrated you will have times when it doesn't work well for open and close and you may injure a finger or toe enough to make you curse. : (
Oct 13, 2009 | Eddie Bauer All Terrain Tandem Double...
How to fold peg perego 2008 Pliko P3
You also have to pull on the middle part by the basket it has like a handle.
Oct 02, 2009 | Peg Perego Pliko P3 Stroller Umbrella
Cannot figure out how to fold the stroller back down
if you pull up both sides of the stroller handle you will find the stroller to fold toward you.
put your hands on the handle at the sides of your stroller pull up and the stroller will fold towars you.
Sep 12, 2009 | Baby Trend BabyTrend Reebok Jogger
I cannot close milano stroller
Above the wheels at the rear of pram there are small levers that you must activate. I'm pretty sure you press the left one first (do not need to hold down) then hold down the opposite side's lever and push forward and down on the handle of the pram. If this doesn't work try pressing the levers in the opposite way first. Originally the pram would have had stickers "1" and "2" on the levers to dirict you how to fold. If in Oz look up Karisles on google and follow the prompts to download instruction manual.
May 28, 2009 | Peg Perego Milano XL Stroller
Folding the pliko matic
To fold the Pliko, first the both handles have to be pulled out. To do it, grab the plastic (1) which is just under the handle (with a little hook on it), and pull it upwards. Pull the whole handle upwards, so it gets out of the catch situated near the front wheel (2). Do the same with the other handle (maybe it is possible to do it with both at once - I'm not sure yet). And then lift the back handle (3) (between the rear wheels) up, folding the pushchair. To lock it folded, you have to use the same catches, which had to be released earlier, to hold the handles - but this time they catch the handles somewhere in the middle (4).
Aug 22, 2007 | Peg Perego A3 Newport Standard Stroller
Graco DuoGlider 7924 Twin Seat Stroller Logo
71 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
