Question about Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
I have a cyote spa hl code is on..and temp is cool at 96 ,,i unplugged for 10 min,,reset the f cycle from 6 to 4 ,,,,,nothing,,
  • 310 Answers
This probably means the the circulation pump is failing. It sounds like the temp sensor is good, but the high limit sensor is either bad or really reading a high limit. This is very typical of a small undersized circulation pump that is starting to fail.
Posted on Oct 28, 2010
Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
Janet McDonald,
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
-Best Regards-
Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
Kitchenaid DW KUDS30FXSS Cycle starts then I hear a solenoid actuate 4 times then unit goes into cancel drain cycle
Here's a link for the repair manual for your dishwasher:
http://www.appliancerepair.net/kitchenaid-dishwasher-repair.html
Concentration should be on Chapter 2 subsection 2-3 "No Fill"
Then go to Chapter 6; subsections 6-2, 6-3, 6-3a, 6-3b, 6-3c, and 6-3h for testing procedures on relays, actuator valves, etc.
Nov 30, 2013 | KitchenAid KUDS30FXSS Builtin Dishwasher
I have recently installed 1Te Voltas 2 star A.C. I need clarification on the following 1) In cool mode, what is system of auto cut. Suppose I put on remove temp 27deg C. Temp of the room goes up to 26 deg...
Dear Mahesh
In Cool Mode
Temp Diff - + - 1 deg C in Room Temp & Set Temp
This is auto cut
In Dry Mode
Comp Runs for 10 mins then get off for 5 mins then again get on for 10 mins this cycle continuues.
Oct 15, 2013 | Whirlpool ACQ158XP Wall/Window Air...
The HL indicator light comes on and I can not get it to reset. I shut spa off and the HL light was on again when I checked an hour later. I live in Wisconsin and don't want my tub to freeze. Tub was used...
It sounds like a flow issue. When the HL comes on, its sensing a higher temp than it is supposed to. This is usually caused by bad flow in the circulation pump.
The most likely cause of the bad flow in residential spas, is a bad filter element. Even if a filter looks clean, they do get clogged with particles we cant see. To test this, make sure the spa is free of debris, and remove the filter element. Run spa for a while and see if the code comes back. If it doesnt, get a new filter.
Otherwise the pump could either be failing, or clogged. Check this next.
Finally if these dont work, check the temp sensor (thermistor) .
Jan 24, 2011 | Arctic Pool & Spa
Simpson eziloader 5.5kg washing machine When i turn it on and select a program the machine clicks and the light flashes three times and then turns off the cycle (the cycle does not commence).
1.Turn off machine 2.unplug from power 3.leave unplugged for 5-10 mins 4.open door (if has water in drain via pump/lint filter (botton right flap). 5.empty contents(if wet turn drum by hand( may be unbalanced) close door) 6. turn on power 7. select colours 40 cycle 8. press start button 9.wait a moment ( chip reset ) 10.hopefully machine will fill with water and let complete cycle
Jan 11, 2011 | Washing Machines
Displays HL and has been on for hours but not heating. Help!
HL usually indicates high limit which will shut down the unit. if power is turned off for a min or two it may result the fault. on some units there may be a reset button in the control unit. if it doesent reset it is most likely the hl thermal (temperature) sensor hope this helps
Aug 20, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I have two ptac units, both want to run 5 or 6 mins. and cut off
Make sure there is nothing in front of the units, Chair, Couch ect, if you take the cover off the Units, you will see a little black Thermoster attached to the coil.
If the air bounces back off of something then it will cool that Thermoster and shut the unit down before the desired room temp is acualy reached.
Also make sure your Thermastat control knob is turned far enough to the right so that its asking for more cooling, Or desired temp.
Hope this helps.
Good Luck!
Oct 26, 2009 | GE Zoneline Deluxe Series Cooling &...
SN ?Non Functional High Temp Sensor? error message
unplug and plug after 20 sec. turn pump fast and wait for 1 min if nothing air is trap anf need to be out
Sep 07, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Kenmore 80 Series Heavy Duty washing machine suddenly will not drain. Tried different settings, nothing.
Unplug washer for 10 min to reset curcuit board. Then select the spin cycle. Selecting too many cycles in a short period of time can confuse the little brain in the board.
Apr 30, 2009 | Washing Machines
Qca Spas Dream Series Dream Master Hot Tub with Flex Cover Logo
122 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
