Question about Blue Rhino Portable Patio Heater
I have a charmglow ( Bue Rhino) deck heater 200605, that shuts down after 10 minutes of use. Sounds like a thermostat issue?
My totaline thermostat model #p474-0100-a the backlight is staying on and when the furance is running after only a couple of minutes it shuts off and my furance shuts down .
Multiple issues that are not related. If the pilot light goes out then the thermocouple might be bad. If the pilot ignites the gas and everything shuts off, it sounds like the over temperature sensors are detecting heat in excess of what is allowed in the firebox. The thermostat issue has nothing to do with this.
Nov 19, 2014 | Heating & Cooling
Ventless wall heater shuts off during operation
Sounds like thermostat may have a battery going bad as to not supply sufficient power to turn on the relays. As safety procaution when a signal is weak or no longer detected the heater shuts down.
Nov 16, 2017 | Procom Heating & Cooling
The heater does not stay on long enough to heat my garage. it will come on for 3 to 5 minutes and shut off. it comes on again in 5 to 10 minutes for 3 to 5 minutes again. the heat is good when it runs....
You could tripping the high temp limit this will be located near the heat exchanger When it shuts how long does the blower motor stay running? Do you have a meter?
Dec 15, 2010 | Fahrenheat FUH5-4 Heater
Charmglow 810-7400-S Propane Grill: have a charmglow patio heater, the pilot comes on ...
I have a Charmglow Patio Heater Model SRPH02, it needed a Thermocouple and searching the net was hard to find an ariginal part, but here it is, call 1-866-814-0585 $3.95 +6.00 shipping the original part.
May 16, 2010 | Brinkmann Charmglow 810-7400-S Propane...
Broken thermostat for the Charmglow HBL-15SDLP/M20
you can get your parts at this web site.................www.grillstuff.com......scroll down to CHARMGLOW parts..enter your model # ...they will ship the part to you...I was just at that web site to verify.....GOOD LUCK..!!!
May 09, 2009 | Heating & Cooling
Need manual for Charmglow vent free freestanding fireplace
i have a manual, if you would like a copy? do you know if it can be converted to Propane?
thanks,
Rand
Mar 28, 2009 | Heating & Cooling
Blue Rhino Portable Patio Heater Logo
364 people viewed this question
Top Blue Rhino Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Blue Rhino Pool and Spa Expert? Answer questions, earn points and help others
