Question about Sony PlayStation 2 (PS2) Console
Memory card no data
I posted to a problum about a memory card say no data when it is put in the slot and the memory is missing and no data can be loaded or saved, you said to unscrew the back and push the chip forward what i am wanting to know is that won't that erase the saved games on the memory card.
  • 49 Answers
Dont open the case! you might have the prongs snapped of in the ps2 or memory card
Posted on May 21, 2008
My problum is when i attached ram 1 gb after its system restart and show belue screen and i sure my rem is ok tell me what is problum here????
A) FixYa T.O.S. (Terms of Service) states to NOT post your email address.
The TOS is read when you join.
B) How about posting the MOTHERBOARD manufacturer name, and Model Number?
Also post what ram memory ,manufacturer, and manufacturer code on the ram memory module.
Ram Memory HAS to be in Slot 1. (May state DIMM 1 next to the ram memory slot. Can also be Slot 0, or DIMM 0 )
Slot 1 is the ram memory slot nearest the Processor.
A Processor reads ram memory Slot 1 first.
Do you know;
1) What is the Maximum TOTAL Amount of ram memory, for the motherboard?
2) What is the Maximum Amount for EACH ram memory slot?
3) What type of ram memory is supported?
For an example;
Can it use DDR Sdram at either 333MegaHertz, or 400MHz?
(PC2700 and PC3200, respectively)
4) What ram memory slots have you put ram memory in?
Post back in a Comment.
Regards,
joecoolvette
Feb 18, 2012 | Computers & Internet
I have a play station 2 and I like to play Crash Bandicoot 2.Gortex strikes back,but the memory card won't work is this because it is a play station 2 memory card. thank you John.
First, check to see if your memory card has any room on it by turning on your PS2 while there is no game in the machine. Select your memory card, and see how many blocks are left on it, then see how many blocks are required to save Crash Bandicoot 2 games (should tell you on the game's box).
If there isn't enough room, delete some saves to make room.
If there is room, or you cannot view the saved data on your memory card then try putting it in the other slot. If putting it in the other slot does not fix the problem then your card is either damaged or the data is corrupted. In either case, you will simply need to use a different memory card.
Mar 11, 2011 | Sony PlayStation 2 (PS2) Console
I bought a new ps2 and a datel 32mb card and the game i put in says there is no memory card,
Try these steps. If this doesn't work you may want to take the card to Game Stop or something and have them test it to see if it's working. Hope this helps!
  1. Insert the Memory Card into the PlayStation 2 console. The port is located directly above the controller port. Note that there are two different memory card ports; there is no difference between the two. Some games, however, will attempt to auto-load from slot one so it is recommended that you keep your memory card inserted in slot one.
  2. Plug your controller into the PlayStation 2. Power up the system without a PS2 disc inserted. You will be taken to the system menu screen. Select the "Memory Card" menu to examine any data on the card. If the memory card is new there should be no data on the card, if it is used you may see old saves from the previous owner on the card. If you no longer desire to keep these saves, you may highlight them and press the "Triangle" button to delete them.
  3. Insert your PlayStation 2 game disc into the system. When the disc appears on the system menu, select it. Load the game, and play until you are prompted to either create a user profile, or to save your game. Once you have saved any data to the memory card, reset the system.
  4. Select the "Memory Card" menu and examine your memory card. You should see a new icon representing your game's save data. If this data appears on the card, you have correctly set-up your PS2 Memory Card.
    If the data does not appear on the card, you will need to format the card. If the system detects corrupt data on the card it will automatically open a prompt asking if you would like to format the memory card. Select "Yes" and the PlayStation 2 will format the card.
Dec 31, 2010 | Datel Max Memory 32MB Memory Card
Memory Card Corrupted
you cannot save another file until you delete previous one.Corruption occurs if the memory card is removed from console or if you reset the game while saving or loading game remember this also happens when you are saving or loading game and electricity turns off.
May 29, 2009 | Sony PlayStation 2 (PS2) Console
I put my wii powersaves card into sd slot but they wont load
To use a wii powersave, you need to follow these easy steps.
1 Go on to the Wii oprion menue.
2 Go into the data management section.
3 Click save data
4 Click on Wii.
5 Click on SD card.
6 Search for your game title.
7 Click on it.
8 Copy the game data to your Wii.
Hope it helped!
Dec 30, 2008 | Datel PowerSaves with 512MB SD PowerSave...
I can't save my KH Re: Chain of Memories
there is something wrong with the memory card i would buy a new one
Dec 12, 2008 | Sony PlayStation 2 (PS2) Console
Memory Card Guitar Hero 3
Try this... if you have another Mem card then insert it in second slot and start Sony browser now copy your save game data form Mem card 1 to Mem card 2. Place the second mem card in first slot and start game now load your game. Best of luck.
May 08, 2008 | Sony PlayStation 2 (PS2) Console
No data
Sounds like the memory card became corrupted, beware of buying massive memory data cards for ps2 as the bigger they are the more chance of problems, sounds like you will have to get new card.
May 07, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 won't read ps1 memory card
PS2's don't read PS1 memory cards outside of the browser screen. It can only be used as access memory. Hope this helped. As for the slots it might be only fixable by a mechanic.
Dec 22, 2007 | Sony PlayStation 2 (PS2) Console
Ps2 memory card
Hi Lofatman,
If this problem happens with the memory card when its in either slot 1 or slot 2
I suggest you clean the contacts of the memory card.
If it just happens when you have in Slot 1 or Slot 2 only,
 Go to Radio Shack and get a Can of contact cleaner that has a Brush built into the Spray nozzle.
  1. Turn off the PS2 and disconnect the power cord.
  2. Use a small screwdriver to press open the memory card slot. Do not use too much force, its delicate.
  3. Push the Brush sprayer up into the memorycard slot and spray a little and brush away at the memory slot contacts.
if you do not have success with that, you must open the PS2 case, and Remove the Controler ports and clean up the whole controller port assembly.
If that doesn't work, and your frustrated and not Electronically skilled enough to do this.  I can get the PS2 in tip top shape, for $32 and that includes return shipping.  I run the website www.playstationclinic.com
This should put you in business.
Oct 17, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
52 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
