Question about Lexmark X4270 All-in-One Multifunction Printer, Copier, Scanner, Fax
Unable to get power
We have a fax machine that we moved from the home office to the main office and we can't get it to turn on but yet theres a slight buzz sound coming from it. I checked all the cords & lines already. Please help
If its a buzz you probably have a loose pin thats not attached probably if its more hissing like than you have a leaking capacitor that has aged.
try this
unplug the fax and try it on diffrent sockets .if it works there then the former socket has bad contacts get it replaced else get someone to chech your fax machine.
hope that helps lemme know if that helps
Posted on Jul 09, 2008
Mfc 7360 unable to print 7a
Error code 7A
A synchronized signal of the main motor cannot be detected.
Turn the power off and then back on again.
1 Flat cable connection failure of main motor
Check the flat cable connection of the main
motor and reconnect them.
2 Main motor failure Replace the main motor.
3 Low voltage power supply PCB failure
Replace the low voltage power supply PCB ASSY.
4 Main PCB failure Replace the main PCB ASSY.
Jan 14, 2015 | Brother MFC 7360N - Multifunction fax /...
Need to set up machine was given as gift
There are two ways to use a fax machine in your home or office. You can either have a standalone fax machine, or you can use your computer for this purpose. Either way, setup is very simple. You don't even have to be a tech guru to do it. First, decide if you'd like to have a separate phone line for your faxes so they don't interrupt communications at the office. If so, have the phone company install the line before you get started with fax setup.
Setting Up a Traditional Machine
  • Step 1.Set your fax machine on a flat and even surface. Plug the power cord into the wall. Fill the paper tray and slide it into the front of the machine.
  • Step 2.Plug one end of a standard phone cable into the phone jack and the opposite end into the port on the fax machine. It's usually on the back or the side.
  • Step 3.Turn on the machine and pick up its telephonemag-glass_10x10.gif. If you don't hear a dial tone, check your phone cable to make sure it's secure. Then turn to the LCD screen and start programming your options. Since all machines are different, see the instructions in the owner's manual.
  • Aug 03, 2010 | Office Equipment & Supplies
    Brother Intellifax 2920 Error "Unable to Print"
    Check the flux capacitor, those usually go out on brother faxes.
    I just replaced mine last week, same problem.
    Jan 05, 2010 | Brother IntelliFax-2920 Fax
    HP Officejet Pro L7680 All in One - cannot send faxes - keeps jamming and says "scanner failure unable to scan copy or send a fax. Turn the power off and on and try again" I have done this several times...
    The scanner is the problem, the scanner is the real bright light that comes on to scan the orginal document. Does your Scanner lamp come on? mite be burned out? stating scanner failure, doses your scanner move when it scannes the document? Motor or cicruit board that control scanner mite be bad, check the scanner "Home " position sensor maybe the scanner board and main board don't know where the scanner is phyiscal when it goes thur its routine.
    Jul 08, 2009 | Office Equipment & Supplies
    On hook dialling
    on hook is for dialing out some machine you push this button and dial the number to fax out.
    there should be a off hook or stop button to release it
    Aug 11, 2008 | Sharp Office Equipment & Supplies
    Move to a different phoneline
    You need to change the phone number in the settings menu to reflect the new location. Erase the old, enter the new. Dont forget the area code, if different.
    Jun 10, 2008 | Muratec F320 Plain Paper LED Fax
    Canon Laser Class 3170 - Change Display Number
    Here is the manual
    http://www.procopyoffice.com/Manuals/LC3170/LASER%20CLASS%203170%20Series%20Users%20Guide.pdf
    Oct 30, 2007 | Canon Laser Class 8500 Printer
    Lexmark X4270 All-in-One Multifunction Printer, Copier, Scanner, Fax Logo
    523 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
