Question about Insignia IS-LCDTV32 32 in. Television
No pic no sound, no nothing; went off in middle of program; repair shop said it needed inverter board, bit they could not fine one
  • 1,684 Answers
We should be able to repair your TV, please contact us at 318-447-9040. In most cases when this happens it is caused by blown capacitors on the inverter board. We can replace them and repair the board instead of replacing it, this is much cheaper too.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on Aug 29, 2010
Hisense TV: Dim pic. 2 wks later the pic just went out. Still had sound and could only see the pic when lights were off. Now the TV won't turn on. No sound. No back lights.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Oct 12, 2016 | Hisense Televison & Video
Have sound but no picture on my lcd tv
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
Jul 02, 2016 | VIZIO P602ui B3 60 Inch Ultra Smart
Toshiba lcd 42x3030db sound but no picture. just went black screen??what do i need to fix if possible.
In some models of LCD TVS; the backlight inverter will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, it can't be replaced. In this case; a panel replacement is the only repair.
Feb 01, 2015 | Toshiba Televison & Video
I have a 32" Sansui led tv that turns on and runs fine for about 5 minutes then the picture goes black. The sound works but no pic. If I shut it off and turn it right back on it does the same thing. I
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Aug 21, 2014 | Televison & Video
Sanyo DP42849 no picture but has sound
Sounds like an inverter problem. On some of these sets, the inverter and the power supply are on the same board. These boards tend to be quite pricey, $100 + range. I've worked on your particular model with the same problem, and it was a bad inverter/power supply board. I would recommend you get a diagnosis to be sure.
Oct 28, 2012 | Sanyo DP42849 42 in. HDTV
The tv will not show a picture it just gets a sounds. Called the manafaucter and they said it might be the bulb that went out. Recently just bought the television in 2008.
It takes anywhere from 7-15 years for the backlight to go out depending upon use so that is unlikely. It is more likely that you need a new inverter board or the connections to it are loose. See if a small local repair shop can assist you with a quote for repairing a loose inverter or inverter board problem.
May 07, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
I HAVE A 37" LG TELEVISION AND THE SCREEN AND SOUND JUST WENT OUT THE POWER BUTTON IS ON BUT NOTHING. IS THIS WORTH FIXING OR SHOULD I JUST TRASH IT...THE NUMBER ON THE BACK IS 37LC2D... CAN ANY ONE HELP...
The power LED lite indicator is solid green,but no pic.?This tv is very fixable,take it to the shop,they will order a refurbish circuit board call a T-con board from some wesites source and repalaced it for u.This should cost u half the price of a new tv.If ur power LED lite indicator is blinking and no pic.,they will replaced defective leakages capacitors in the power supply board,or replaced the power board all together.
Apr 28, 2010 | LG 42LC2D 42 in. LCD HDTV
Westinghouse 29" lcd stopped working all of a sudden. no picture, no sound. nothing.
The inverter provides power for the backlight for the screen, I would have thought you would have sound for a short while if it were that. I would go for power supply capacitors.
Apr 09, 2017 | Westinghouse LTV-20V4 20 in. EDTV-Ready...
Viewsonic n4060w
HI I AM A TECH. I WORK FOR A COMPANY THAT REPAIRS LCD TV'S. IF YOU HAVE SOUND AND NO PIC YOU WILL NEED AN INVERTER BOARD THERE IS A WEB SITE CALLED SHOPJIMMY.COM THEY MAY HAVE IT
Dec 06, 2007 | ViewSonic NextVision N4060w 40 in. LCD...
I have sound but no video at all
A defective backlight.  I've had the issue several times now with my sharp 32" lcd tv and in the process of trying to get a replacement tv.
Oct 27, 2007 | Olevia LT42HVi 42 in. LCD Television
Insignia IS-LCDTV32 32 in. Television Logo
27 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
