Question about Indesit W 123 Front Load Washer
W 1121 washing machine
I need to reset HOW ????
    Scholar:
  • 150 Answers
Try unplugging for several minutes
Posted on May 07, 2008
I have a jazzy 1121 and my seat moves around a little bit. How can I lock it?
Pride Mobility Jazzy 1121 - USA TechGuide
www.usatechguide.org/itemreview.php?itemid=570
19 posts - ‎16 authors Medium Back Seat Contoured Medium Back (standard). ... Comments: My jazzyscooter goes forward and side to side but the reverse makes a quick .... Strengths: Tough chair - town I live in doesn't have many curb cuts, but chair will climb ....Maneuvers poorly through (Handicap) doorways, due to rear locked caster wheels.
Nov 29, 2015 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
No sound out of the pioneer vsx-1121-k
Try removing all the speaker and the HDMI connections; then use a headphone to listen to music from the tuner or a CD in stereo mode. Better in direct mode. If you hear your music correctly the receiver could be working correctly. If no music is heard, you may need to have it repaired professionally.
If you can hear music, connect the main FL & FR speakers and verify you can hear music that way, without the headphone connected.
If you can hear music that way, connect the center and rears. Try a mode that uses all channels to verify all sound channels are working.
Then, and only then start adding your HDMI connections.
Good luck
Jan 19, 2015 | Pioneer Vsx-1121-k 7.1 Home Theater...
Jazzy 1121 can the joy stick be reset to factory default with out a programmer, and if not what programmer would i need or any idea on a dealer to reset it?
You would need a programmer to set the factory default on this model. The 1121 typically had a Penny and Giles VSI controller. You would need a PP1 programmer to adjust it. Call around to your local dealers and see who has one in their shop. It is a very popular and available programmer. If you bring the chair into them, they will probably program it for no charge while you are in the chair. I know that was my service philosophy for years. The shop will get your business down the road as a loyal customer. It should take less than 15 minutes to dial you in. Hope this helps.
Oct 04, 2012 | Pride Mobility Jazzy 1121 Electric...
98 Mercury Mystique 2.5 6cyl., I got a scanner code of 1121. Issue, car would hardly start then not start after a few tries. Disconnected MAF and car started and runs, a little sluggish at take off. What...
PO 1121 ---Throttle Position Sensor Inconsistent
with MAF Sensor
PCM monitorsTPS to MAF readings
If readings are not consistant with calibrated load values
the test fails & a DTC is set on your dash (1121)
Air Leak between MAF & Throttle Body
Bad TPS
Bad MAF
With the MAF disconnected you have no way to
monitor the air intake or air temp.
I would suggest you let a repair shop diagnose your issues
Sep 20, 2011 | 1998 Mercury Mystique
1 red and 3 amber lights flashing after stopping and goes around in circle on a jazzy 1121 powerchair
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
The powerchair going in circles may indicate a motor is bad and needs to be replaced.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Aug 23, 2010 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
I need a select knob for model #10mw42k-d part#a5 1121 22410-001 1121-900000-001 knob broke
If you need one quick I buy generic knobs from my local ACE hardware store they work fine and are cheap. good luck
Aug 10, 2010 | Emerson Quiet Kool 6GC53 Air Conditioner
I need the serial no of adobe page maker 7.0 try out
1039-1121-2998-7586-7388-7545
Jul 11, 2009 | Adobe PageMaker 7.0 for PC
Indesit model 1121 water on all the time even during spinning
Your inlet valve is faulty, open up the top after disconnecting the mains, you can change it yourself.
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
Mar 21, 2009 | Washing Machines
Indesit W 123 Front Load Washer Logo
67 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
