Question about Philips Audio Players & Recorders
L have Philips DSP 2500 5.1 Home theater. I want to connect it to my TV having Tata sky connection , so that the output of TV is through home theater. Pl advise how I do it
  • 151 Answers
SOURCE: I have just connected my
To get sound from tv to your system you have to run a set of phono cables from the audio out on the back of the tv to the input on the system,these may be marked "aux".Once you have this done set the sound to prologic2 and enjoy.
hope this helps.
CABLE GUY.
Posted on Jun 30, 2008
SOURCE: how do i connect my
If your home theater has an hdmi in and out then you wuol be better of connecting the blu-ray hdmi to your home theater then to your tv. If all you have are optical connections to your reciever then what your doing will work fine. Additionally if your blu-ray has built in decoders not present in your reciever and also has 5.1 or 7.1 analog outs you can connect them to a six or seven channel in on your reciever if it is so equipped and have the benefit of true-hd or other current audio formats on current Blu-rays
bobrob59
Posted on Dec 11, 2008
SOURCE: I have an Archos 5
go onto the archos website and find the product and watch the tutorials on how to do these thing if you have tried that already then i don't know what is wrong
Posted on Jan 19, 2009
  • 10406 Answers
SOURCE: do we need an amplifier
Yes, you need an amplifier, since the "levels" of the sound-output from each device (TV, CD-player, cassette-player, Sony mini-disk player, turntable) are not sufficient to physically move the "cones" inside your speakers, to push air around, to produce sounds.
You need "watts" of power to push air, while the devices produce milli-watts (watts/1000) of power.
Also, the amplifier is also a "decoder", electronically processing the input to produce "5-channel" (left, front, right, back-left, back-right) surround-sound output.
Posted on Sep 30, 2010
  • 149 Answers
SOURCE: i want to connect my
Hi, to hook up a Tv to an home theater they are all the same process.
Instruction:
Make sure your playback devices are properly connected to your receiver. Whatever playback devices you use, make sure they are plugged into the appropriate inputs on your receiver. DVD and Blu-ray players, satellite boxes and cable boxes should all be plugged into video inputs, and CD players should be plugged into audio inputs. Your receiver will have labels on the back panel indicating into which input you should plug your devices.
Connect the video out to your TV's video input. Make sure you use the correct cable to make the connection. For newer receivers, the connection will likely be either HDMI or component. If your receiver has an HDMI output, use an HDMI cable to connect the receiver to the HDMI input on your TV. If your receiver uses a component output, use a component cable to connect your receiver to the component input on your TV.
Connect the audio output of your TV to one of the audio inputs on your receiver if you want to output your television's audio through your home theatre system. Most recent TVs will either use an optical cable or a digital coaxial cable to connect to the receiver, allowing you 5.1 channel surround from your television. If you have an older set, you will likely have to use standard RCA cables.
Turn on your receiver and press the "Setup/Menu" button on your receiver's remote. When "Input" appears on the display, press the right arrow key on your remote to select TV from the list.
After selecting TV, press the up or down arrow keys on your remote to select the audio input jack into which you have plugged your TV's audio cable. Press the "Exit" button on your remote to exit the setup menu and lock in the settings.
Tips & Warnings
Make sure you plug everything into the correct jacks or you will spend unnecessary time trying to troubleshoot why you don't have picture or sound.
Posted on Feb 17, 2011
How to connect Samsung hdtv to my Philips dfr 1600 home theater?
that would tell me it can't be done . have you tried the output from home theater to the antenna input on TV
Apr 25, 2015 | Samsung Audio Players & Recorders
Philips hts 3265
hi,lg lh d6230a home theater player display show the dvd error but not opening cd room .why this wrong please help me.send me reply
Jan 15, 2014 | Audio Players & Recorders
I have a philips DSP 2500/5.1 home theater its power ic for speakers has gone it does not have any name in the ic please help me
There is a service manual for a Philips model 2500, but I am not certain it's the same model as yours, as it uses the HST letters before the number. You can look at that it's free.
Jul 17, 2012 | Philips 5.1-Ch. Home Theater System with...
Hey ,,i bought new philips dsp 2500 mms system. but i cant connect it to my led tv.,becoz the speaker system has 3 input slots(hp stereo slots) n my led is havin only one output slot(stereo slot).....n...
audio out from the TV into the audio in/ Aux on the HTS2500.
Back connectors a AC MAINS~
Connects to the power supply.
b SPEAKERS
Connects to the supplied speakers and subwoofer c AUDIO IN-AUX
Connects to the analog audio output on the
TV or an analog device.
here's the link for the manual:
http://download.p4c.philips.com/files/h/hts2500_94/hts2500_94_dfu_aen.pdf
I hope this helps.
Sep 12, 2011 | Philips Audio Players & Recorders
I recently bought Philips DSP 2500 Home Theater. But in my LED TV the audio out is used only thro' optical able. But in Philip DSP 2500 Home no option for connecting optical cable. so kindly advice if...
There is a website that provides an Opticle Audio to Digital SPIF converter. I have listed it in the link for you below. The item also apears to be quite inexspensive, so it would be worth looking into.
Optical to SPDIF
I would be interested in knowing how well this works for you.
Aug 30, 2011 | Televison & Video
I have purchased a new Philips DSP 3300 hometheater. I have installed the same. However I have not connected the DVD player to the TV and have not changed its factory setting. Its conencted as is from the...
i have purchased philips dvd and philips home theater 5.1 3300w model. how to connet to the home theater to dvd and tv. because i miss my home theater manual book.
Oct 06, 2010 | Philips Audio Players & Recorders
How to connect 5.1 home theatre to sony bravia lcd tv
how to connect philips home theatre dsp 2500 to sony bravia
Jun 07, 2010 | Altec Lansing VS3251 Speaker
I want to connect dsp 2500 with my pc. how it is connect please tell me
ya u can do this my doing some specific converter. thats all which u get it from ebay.
have fun
Jan 29, 2010 | Philips HTS3450 System
Connection
Your TV should have an audio output which are red and white colored jacks, labeled audio out, on the back of your TV. There are also be the same inputs on the home theater system. You would have to buy an RCA cable which is inexpensive. You can then connect the TV from the audio out jack to the AUX 1 or 2 jack on the rear of your home theater system. Then select the AUX 1 or 2 input option (the one you hooked the cable into in the rear) on the home theater system, and you should be in business.
Feb 05, 2009 | Philips HTS3450 System
429 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
