Unable to turn on
When trying to power on nothing happens then i connect wall charger try again light starts to flash but still wont power on
  • 1 more comment
  • lungmanjack May 14, 2008
    having the same problem. Push the start button, and nothing happens. The green a/c power comes on when it's plugged in to the power cord. No noise, no beeps, nothing. I tried taking the battery out and disconnecting power cord...still nothing. Won't power up with the battery in OR out. For a while it would power up after a few tries when I took the battery out. Now there's nothing no matter what I do. I've heard it could be a voltage converter, or possible the a/c cord. However, if the cord is bad, why does the power light come on? Any other ideas? Are compaq just crappy systems? It seems alot of people have this very same issue with Presarios.
  • demoderby116 Dec 01, 2008
    bought a new power supply for this laptop, and the blue and green lights come on, but otherwise, i get nothing.
    thanks!
  • Anonymous Jan 27, 2009
    exactly the same as mentioned above. nothing works!
    President:
  • 2,712 Answers
Try to remove battery and plug into wall charger and see if it works. If it works, your battery is defective and you have to replace it.
If it still does not work, it could be a problem with the power supply unit on you laptop. I recommend you consult a qualified technician in this regard.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 07, 2008
    President:
  • 778 Answers
Leave it plugged in for a while (like long enough for the battery to fully charge) and try again. Your battery could be shot causing this problem. After a full charge cycle and testing you'll know better what to do, so please post back your results.
I face the same problem.It only turns on after several tries.If i remove the battery ,its not responding.
The thing is that even when it wont turn on ,the fan is turning instatly.
Posted on Oct 16, 2008
Roomba 4220 light says charged but wont turn on
Try resetting
to reset the charging system. You can do this by removing the battery from the robot and unplugging the charger from the wall and robot. Please hold the power button down for 30 seconds. You then should charge the robot....."
Dec 29, 2012 | Vacuums
Basically when i charge my laptop it wont turn on and the lights dont flash either i have tried checking the charger on another eee pc 4g laptop and worked i also tried swapping batteries but still...
Hi
Try to remove the battery, hold on power button for about 50-60seconds, then plug-in the charger and turn the laptop ON, see what happens.
Then, un-plug the charger, an pluig-in the battery, try turn the laptop on.
Please tell us your results
Good Luck
May 15, 2011 | ASUS Eee 4G Notebook
Laptop wont start at all. plug in to power supply and battery charging light comes on.still wont start up...
try diconnecting the charger and holding down the power up button for longer, then try plugging in charger- turn on charger at wall then hold down power on button till power button on key lights up, i hope this helps you out ;)
Feb 07, 2011 | Computers & Internet
My laptop is an Asus 1005HA-V and I'm having trouble turning it on. I've had it for about a year and when I try to turn it on it's lights flash and then turn off again. Also sometimes when it's on the...
Things that you can try:
1. disconnect the charger and the battery. 2. press and hold the power button for 15 secs. w/o the charger and the battery (the reason for that is to drain flea power). 3. connect the laptop straight from the charger w/o the battery and turn it on. It should turn on fine. If nothing happens, the motherboard is bad or the charger.
Jan 17, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Hi i have put power supply in anbd powered up my power supp;y shows green light but when i press power on butoon on my e1705 nothing happens no lights flash nothing totally dead
Hi
Please can you try the followinf
1) remove wall charger
2) Remove battery
3) Press and hold power button down for apporx 30 seconds
4) Plug in wall charger
5) Power on laptop
6) If successful plug in battery
Regards
Shauqat
Apr 19, 2010 | Dell Inspiron E1705 Notebook
Nothing happens
The charger connection is sensitive on the Reflex Pro. It isn't uncommon to plug in the charger, see the light flashing, then when setting it down a slight movement of the cable stops the charging (light will stop flashing). Try connecting the charger again (if you haven't already) and let it charge for about an hour. While getting a good charge can be frustrating, it is worth it for the 4 minutes of fun to follow :-\
Aug 16, 2009 | Spinmaster Air Hogs RC Reflex Micro...
Won't turn on
Did you try to disconnect the battery and connect you mac book to the charger? If it turns on with the power connected and without the battery, probably your battery is broken.
May 04, 2009 | Apple MacBook Mac Notebook
My Ipod Nano Wont Charge on the wall Charger.
Hello Kawase,
I would suggest you try charging the unit this one time by connecting it to the computer. I suspect that the charger may be defective if plugging the wall charger into the iPod has no effect on the low battery warning. If the iPod is able to be charged from the USB port on your computer that would tend to confirm that the charger is not working. If the iPod does not charge when connected to either the computer or the wall charger then you may very well have a another defective iPod.
Best Regards
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Apple iPod nano 3rd Generation
Dead Creative Zen M
Usually this problem is due to the firmware. When the firmware is updated to version 1.62.02, this problem usually will be corrected. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
You will need a wall/AC charger for the operation. Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected to direct AC power via the wall charger. Once it is powered on, connect the USB cable to your computer. Then begin the firmware download.
If your Zen does not power on when connected to the wall charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
If the upgrade button on the firmware window is not available, it is also time to replace your motherboard due to corruption of a chip on the board.
Mar 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Computers & Internet Logo
383 people viewed this question
David Payne
David Payne
