Question about JVC Audio Players & Recorders
I have a JVC AK 300 amp and output to the right speaker channel is intermittent or non existent. It sometime will correct itself after 3-4 hours of use. I checked connections, replaced wires, and rotated speakers with same result. Additionally, the display screen shows output to the left channel only when problem exists. The same problem exists regardless of input source so the problem is definately the amp. Any ideas to save the amp?
SOURCE: JVC RX558 VBK, Crackling noise from speakers
A quick quess of mine is the following:
The OVERLOAD indicator lights up when the receiver is maxing out on the current it is sending to the speakers. My guess is there is possibly something wrong with the receiver itself, especially since the B speakers won't play. Either that, or something is broken in your speakers or you are using a set of speakers that have too low an impedance rating for your receiver.
Posted on Jun 22, 2008
marsrover
  • 682 Answers
SOURCE: DENON PMA520 Amp. Suspect left channel
you have malefunction in your left output stage-but can i ask you did you forget to press left speaker button in your amp (if you have one in your amp).
Posted on Jul 27, 2008
  • 4234 Answers
SOURCE: fuzzy sound from right front speaker output
The main issue is to determine where the distortion is coming from. Does it start in the front and and get amplified or does it appear in the output section only? This will require a fixed signal and an oscilloscope to trace. Check for leaky coupling caps or leaky transistors in at the diff-amp section.
Dan
Posted on Feb 02, 2009
techman
  • 3130 Answers
SOURCE: I have bad static from my Pioneer vsx 49 Elite
sorry no easy solution as it sounds like the output transistors blew out or the emmitter resistors. you will need a service manual and an multimeter to measure the resistors on or around the audio output transistors they are a low value resistor usually around 1 to 2 watts in size. Do not replace any bad , burnt or discolloered resistors around the audio output transistors as if tou do you might just cause more damage to the output transistorsor audio output stage including the audio driver stage of the amp!!!!!!
Larry Dillon
Posted on Aug 27, 2009
Testimonial: "Thanks techman for the great answer! This is definitely not something I can do myself so I'm glad I just ordered a working one on ebay. rarejem1908"
  • 4234 Answers
SOURCE: I have a Fisher RS-717 stereo receiver, amplifier.
Yes you can use either A or B without a problem. The restriction is when you have both A & B connected. In that case, the speakers MUST be a minimum of 8 Ohm impedence. Using either A or B, you can use speakers of 4 Ohms impedence.
Dan
Posted on Nov 24, 2009
Testimonial: "Prompt answering, appreciate it very much."
Not sure where to plug my amp in on back of my head unit it's has multiple rca jacks on the back... It's a jvc kw-av61
Run the speaker wires from the stereo to the amplifier high outputs, or get a converter fr your stereo speakers wires to rca, most older amps have a high output witch have a left +-, Right +- depends on how many channels your amp is..
Oct 25, 2016 | JVC Car Audio & Video
In my JVC RX 8SD only works a channel. How do I repair this defect?
Start with the simple things.
  • Check left right balance
  • Swap output speakers left to right
  • Swap the speakers at the receiver to make sure no wire open/short
  • Swap input RCA cables left to right red/white - white/red
Ok No JOY!
JVC has thermal overload circuits/overload on most of there Amps.
Remove power for a minute or two to see if there is a reset.
Rewire speaker connections to speaker set 2.
Connect REC out to Rec In swap cables and see if problem is in pre-amp or power amp.
Check internal fuses.
Jan 19, 2016 | JVC Audio Players & Recorders
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Dec 12, 2015 | Audio Players & Recorders
Preamp intermittent channel
Getting the connections right is a problem. One thing I find helps is the THX DVD discs that certain movies have on them. They have a sound set up to get it right. It makes a tone for each channel so you can hear which channel is working. It should help you set up the system right and determine if any channel has a fault on it.
Feb 08, 2014 | Adcom GTP-870HD 7.1-Channel Amplifier
How can you bridge a 2 channel 300 watt amp to a 4 channel 300 watt car amp?
if you have (4) 4 ohm speakers (No Subs), then you simply take the (2) positives from the two right speakers, and the (2) negatives together and put them on the right output of the amp. Do the same for the other side. This will have the amp at a 2 ohm stereo load on each side, which will max out the power of the amp. Will sound great with any small power amp.
Sep 07, 2011 | Car Audio & Video
How do you balance sound between two speakers. Where is the balance control? JVC RX5000v
On the front panel ONLY:
1. Press ADJUST so that the MULTI
CURSOR up/down buttons work for
adjusting the sound.
2. Press MULTI CURSOR up/down
repeatedly until "BALANCE"
appears on the display.
3. Press MULTI CURSOR left/right to
adjust the balance.
• Pressing left decreases the right channel
output.
• Pressing right decreases the left channel
output.
please rate my solution.
Jul 04, 2011 | JVC RX-5000V 5.1 Channels Receiver
Right channel cutting out.
connect right channel speakers to amp left out if the problem fixed you will have a problem in amp itself.
if the problem remained you will have a problem in speaker itself test first with new cable and second with speaker cabinet,
Apr 14, 2009 | Audio Players & Recorders
Hi i have an audio source 300 watt amp with a&b speaker outputs. the problem is that no sound comes from the left side outputs a or b. the right side works fine thank you mike
You have a blown channel. If you are experienced with electronics repair, use the right channel to assist in diagnosing the left. Both channels should be efectively identical. In most cases, the defective parts are the output transistors. You should be able to A/B the output amp sections.
Let me know if you need further assistance.
Dan
Jan 14, 2009 | Audio Players & Recorders
Surround Sound Pioneer Amp # VSX-604S 10 to 15 years old- All functions work well EXcept Left channel produces frequent crackeling noise. Sometimes it is intermittent--Sometimes it's clear for an hour or...
Try swapping everything external to the amp with another channel to see if it follows. Could be the speaker wire or the speaker. If it stays on the same output then it's time for a new amp.
Nov 20, 2017 | Pioneer Audio Players & Recorders
343 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
