Question about LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive
My lacie 1tb harddrive is not being recognised by my pc anymore, why is this?
  • 43 Answers
Try plugging it to another computer.if it is not working it may be damaged.else it may be your operating systems problem
Posted on Aug 29, 2010
My new harddrive have bean formated and the capacity is only 262mb instead of 1tb can i change to 1tb again?
You have to set parameter to high volume drive reform and go threw questions again set high volume
May 17, 2014 | LaCie F.A. Porsche (301177) Hard Drive
My PC does not recognise the La Lacie 1tb hard drive therefore I cannot access the data What can I do
First, try it on another computer. If you get the same problem then the USB controller in the Hard drive case may be faulty. You might be able to take the drive out and use another USB to PATASATA converter. These are available on the internet and in computer shops but you need to check the type of drive inside the case (IDE or SATA) before you buy one.
Feb 22, 2011 | LaCie Rugged All-Terrain (301017) Hard...
My Lacie external drive clicks but won't spin up. It is about a year old, maybe less. It was working fine and just stopped working. It has not been dropped. In fact it hasn't been moved.
Your harddrive is bad, the motor bearing that spins your cylinder heads is damaged, even though the harddrive hasn't been dropped, or removed, this is a result of faulty and cheap product. Theres nothing you can do to replace the motor bearing, you will need to just get a new harddrive and install into the external hd enclosure or get a new external drive. If you decide you want to recover your files, you will need to take this harddrive out and maybe take it to bestbuy/ office depot where they will have to send your harddrive out to a data recovery center. They might be able to recover some data, or all, or none. It is a pricey move to take this step.
Jan 28, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Was using my 1TB and then all memory (pictures) dissapeared. Still shows memory used/available, just all the files are gone.
Those files are hidden folders.
For that connect it to computer then open my computer go to tools menu->folder option.
then click view tab enable "show hidden files and folders" and disable check box of "hide system files" then apply then you can see your files as hidden folder.
then open it then copy all files to local drive also scan computer and harddrive with updated antivirus because it (harddrive) is infected of virus.
Let me know if you need further assistance.
Thanks for using FixYa.
Jan 09, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I have this Lacie 1TB hard drive and i recently uploaded about 150 GB of video on it at once. I did it over night and the next morning the drive was making some noise like its working on something. Now it...
Drive noises are typically a common and needed noise. Most run via magnetic (voice coil) technology and that is noisy. Slow play back may be related to connection, usually you need stuff on your harddrive (C:\) to avoid access delays.
Oct 03, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie 1tb external hard drive into ps3 is not regconised
I have the same issue, however with my verbatim 500g its ok. i believe it is because the lacie is a desktop external and therefore is compatable with windows xp and 7 alone.
Verbatim is a "portable" external hard drive which makes it compatible with several different systems. I would suggest returning it, I just formatted my old verbatim harddrive and set up mediaasharing. Through my router. You can actually route the lacie harddrive by going to my computer and right click the icon. Next go to share with; advanced settings and allow all. Then when you turn your ps3 on search for media servers... I would suggest to google media server for ps3 to get it all seet up. GOOD LUCK
Jun 07, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
Lacie extreme drive 1TB not recognised?
not sure if it will help, but try setting upnp active in your windows services. seem to remembrr my network assistant not being able to see my lacie network drive due to this in the past
Mar 14, 2017 | LaCie Big Disk Extreme (300797U) 1000 GB...
LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive Logo
109 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
