Question about Transcend 8GB SSD, 2.5- Inch, IDE, SLC Hard Drive
My computer does not detect the external hard disk drive since of late and it is also not detected on another computer. What could be the problem and what solution is there. There is no light on the external hard disk to see whether it is on.
  • 43 Answers
Check the drive status on the disk management
if not shown ti may be physically damaged
Posted on Aug 29, 2010
How to fix my external hard drive not detected?
If a replacement usb adapter doesn't fix it, your hard drive has failed and usually not recoverable.
Jul 11, 2017 | The Computers & Internet
Not detecting hard disk
first thing to do is to remove and reconnect the hard disk to the system. devices like hard disk not detected often is just a result of loose connections. if this will not work, may be a good idea to test another hard disk with your computer or test the hard disk on another computer to isolate if the hard disk will need to be replaced.
Sep 04, 2010 | Computers & Internet
P4pe x cannot detect hhd drive
If the BIOS cannot detect the hard drive then :-
1. The hard drive data cable or power connector may not be inserted properly.
2. The motherboard disk controller is faulty.
3 The hard disk is faulty.
To test the motherboard disk controller, connect another hard disk to the motherboard and go into the BIOS to see if it detects the hard drive.
If it detects the hard drive, then the other hard drive is faulty and need to be replaced.
Another way to test the "faulty" hard drive, connect the hard drive to an USB hard drive adapter and plug it into a working computer's USB port. If this computer sees it as an external hard drive and you can open the folders and files the the hard disk is OK, and the fault is a faulty disk controller on the motherboard.
Jun 14, 2010 | ASUS P4PE-X Motherboard
External hard drive is not detected
Check Following Instructions:
1. Check your USB cable properly connected to the computer.
2. Go to My computer - right click on property - Hardware - Devices Manager - in below - USB Mass storage device - right click on this - and Uninstall - then again right click - click on Scan - it should be reload your USB drivers
your External Hard Drive will be detected
Apr 25, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
Hard disk ST9120822AS ATA Device
If the computer cannot Bootup with an error message that hard drive nor detected or no boot device then you could have a faulty hard disk.
Go into the BIOS configuration and see if the BIOS detects the hard disk. If it is not detected then it is probably faulty.
Next reset the ATA data cable on the hard drive and at the motherboard. Bootup the computer again, also check the BIOS configuration again to see if it detects the hard drive.
If it still does not find the hard drive then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer does not detect it as an external hard drive then this proves the hard drive is faulty.
To get your computer working again, replace the hard drive and install Windows together with the device drivers and your programs.
Nov 06, 2009 | Dell InspironTM 1501 Notebook
My computer worked properly. but at once my IDE devices started giving troubles. my 2 IDE devices are not detected at the start up.
The BIOS will have trouble detecting faulty IDE devices, eg the hard disk etc.
To check if the IDE devices are faulty, connect the hard disk to an USB hard disk adapter and plug it into a working computer's USB port, if the computer detects it as an external hard drive and you can open the folders and files then the hard drive is OK and the fault is the disk controller. If the hard disk is not detected then it is faulty and a new hard disk is needed, Windows installed on the new hard drive together with the device drivers and your programs to get an fully functioning computer again.
Sep 01, 2009 | Intel D865GBF Motherboard
Acer aspire one hard disk cannot read
Check the BIOS configuration for the hard disk, if the BIOS does not detect the hard drive then the hard drive is faulty or the disk controller is faulty.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. This computer should detect the hard drive as an external disk drive. If this computer cannot detect it and/or cannot open the folders etc. the the hard drive is faulty.
Then you need to install a new hard drive in the Acer and install Windows, the device drivers and your programs to get the laptop operational again.
Aug 19, 2009 | Acer Aspire One D150-1587 Netbook
Computer cant find hard drive
If the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
May 25, 2009 | Sony VAIO Notebook
Bios not find hard disk
May 24, 2009 | Acer TravelMate 2303LCi Notebook
Won't boot off of the external drive
when u power on your system start tapping F2 key
you wil get system setup screen
it will be somthing like this
Boot Sequence The computer attempts to boot from the sequence of devices specified in this list.
Default Setting:
  • Onboard or USB floppy drive
  • Onboard SATA hard disk drive
  • Onboard IDE hard disk drive
  • Any add-in hard disk drives that are detected (listed in the order that they are detected with USB device usually being detected last)
  • Onboard or USB CD-ROM drive
  • Any other bootable add-in devices that are detected (listed in the order that they are detected with Onboard Network Controller usually being detected first)
Apr 12, 2008 | Dell Latitude X200 Notebook
Transcend 8GB SSD, 2.5- Inch, IDE, SLC Hard Drive Logo
151 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
pankaj rautela
pankaj rautela
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
