Question about Ricoh Office Equipment & Supplies
Have a Ricoh Aficio 3025 with an error code of SC 548 What is the reset procedure. I had removed the fuser unit and drum unit for inspection
  • Anonymous Mar 19, 2014
    i already reset it thru using 5 810 and then i pressed ok. still not working
    i changed thermistor, still not working
ERROR SC 548
Posted on Nov 07, 2008
Error 365 what the solution of it
SC-365 Image storage error VI out of specs, drum, drum potential sensor, charge corona, dirty optics FT 7950, 7960, 7970
Nov 24, 2014 | Ricoh Aficio Mp161 Copier Photocopier Copy...
How do I clear error code sc542 on model 3510sf
go to maintenance mode. press clear/stop press 1 0 7 and start key(hold) until maintenance mode is displayed. look for fuser SC reset.
Sep 18, 2014 | Ricoh Aficio SP 3510SF
Ricoh error sc541
Fuser Error. Check fuser thermistor. reset fuser error. go to service mode press clear modes, 1, 0, 7, hold clear/stop. once in service mode turn off main power switch on the left side. turn back on.
Aug 05, 2014 | Ricoh Aficio Mp161 Copier Photocopier Copy...
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Service Call SC819
I found that this 'SC 819' occurs if you use the bypass tray for the scanner. I found also that this error can be fixed with an firmware update. See link. http://www.copytechnet.com/forums/showthread.php/32934-Ricoh-Aficio-2035-SC819-Error-Code?p=132762&viewfull=1#post132762
I have no idea how to do that at the moment, and I can't report the success of this way.
Jan 22, 2014 | Ricoh Aficio SP C240SF
Err 553 Ricoh aficio 2018D
SC 553 is a fuser error code, could be thermistor or thermal fuse or fuser lamp
Sep 27, 2013 | Ricoh Digital Copier Toner for Aficio...
How can i fix a SC- 546 error on my NASHUA Aficio 2018D all in one problem
You could try to reset the error, but it may come back. Here is the key sequence for resetting:
CLEAR MODES
7
STOP (hold down for three seconds)
You can then switch the machine off then back on. If the problem comes back, then you will need to have your fuser unit repaired.
Mar 13, 2011 | Office Equipment & Supplies
I have a Ricoh Aficio 2045esp copier - it is displaying a error code of SC542. How do I get the machine into service mode so I can clear the code??
Press the Orange Clear/Stop key, then 1, 0, 7, then press and hold the yellow key. Once the screen changes touch Copy.
Then towards the bottom left touch data log. Use the page down to flip pages until you see "SC/Jam counter reset".
Touch that then the "execute" tab that will pop up. Then turn the main power switch off then on again and that will reset the SC code. However, if you have a fuser problem the code will come back usually within 1 minute. If so then you are going to need repair to the fusing unit. Also DO NOT make any changes or play around in the service mode. You can really screw things up in there if you do not know what you are doing.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Office Equipment & Supplies
618 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
