Question about Ovens
Lamona 5 burner gas hob will not ignite, no spark although oven underneath will. only 2 months old,
Master_Tech
  • 770 Answers
SOURCE: Hotpoint EG54P ignition sparking by itself
The reason it stopped was you need to push down to activate the switch and turn on the sparking be careful about getting water down in the unit ..Glad to Fix Ya plz rate my answer
Posted on Feb 24, 2008
reg501
  • 413 Answers
SOURCE: oven won't ignite
In many cases, even if the igniter is glowing, the 'hot' resistance may not be low enough to turn on the gas valve. The igniter has probably gone bad. ($50.00 to $90.00 for igniter)
Posted on Jun 10, 2008
  • 1252 Answers
SOURCE: Oven burner will not ignite
http://www.southbendnc.com/downloads/manuals/500SeriesManual_1188716.pdf
try this web site for operations manual.
Sounds as if the thermocouple may be bad. It is enough to keep pilot lite but not enough to open safety valve. Some of their ovens have a "Mercury Switch" instead of a thermocouple. Look behind the kick plate. It will have a white ceramic base and have 2 wires going to it. The end sits in the pilot same as thermocouple. If there is a pilot valve, make sure that once the pilot is lit, you turn it to "on" if the position is available. Lots of options on these ovens as they custom build alot for certain companys. Check this out and let me know.
Posted on May 23, 2009
  • 16 Answers
SOURCE: Ignition switch on a gas hob/electric oven not sparking
Some have a AAA battery under the button - replace this, others use mains to create the spark, ensure you have the ignition wired up
Posted on Jun 01, 2009
mgprice
  • 744 Answers
SOURCE: Gas oven ignites only intermittent
I assume you are saying the oven will not light but you can see the igniter glowing....if this is the case you will still need to replace the igniter, igniters need to be drawing a certain amperage before the will open the gas safety valve. in this case your igniter is glowing unevenly orange and is old - it is not pulling enough amps to open the valve. Replace it and you should be good to go If you have any other questions please feel free to comment. Good Luck!!! Mike
Posted on Aug 18, 2009
Testimonial: "Yep, spot on! Ignitor replaced today. Reliably informed that the glow ignitors last about 4 years (ours did 5). That brand now has spark ignition."
Unable to find model number for electric oven
Hello, Smlmyers -
Look at the image for the location of the sticker with the oven model on this web page:
http://www.stockportrepairs.co.uk/Lamona/Oven
Scroll down the page. The image is near the bottom.
Best wishes from a volunteer answerer in the USA.
Jan 18, 2018 | Ovens
Cannon double oven
The quality of new stuff is not as good at the old, but they are shiny and clean to start with.
With the upper burners, they have just a standard gas igniter, but you say there is no gas. This can only be cause by two things, but most likely a blocked jet for some reason. The only other reason is a faulty control.
The grill is the same, some share igniters, some have one for each of the three department, hobs, grill, ovens.
So your choice is buy a new one or get a service engineer in. It is gas, so you shouldn't really work on this on your own for safety reasons.
Feb 02, 2018 | Ovens
Gas hob Luce(hotpoint) gas on glass 5ring burners keeps going out on low flame when pull pan drawer beneath out
Same problem with my hob. I adjusted the small jets to their lowest setting in order to be able to simmer -impossible on the bigger jets. The problem is the vents underneath the hob. These can't be closed off so the problem appears to be in the design. The solution I have to use while I save up to by a decent German model is to open and close the cupboard doors underneath the hob very, very slowly.
Nov 19, 2013 | Ovens
GAS OVEN WILL NOT GET HOT
see this instructions and fix it. God bless you
  1. eHow
  2. Home & Garden
  3. Home Appliances
  4. Other Home Appliances
  5. How to Troubleshoot a Gas Range Oven That Won't Heat
By Kefa Olang, eHow Contributor
Although gas range oven may prove useful for cooking and baking, they may fail to ignite if they aren't properly maintained and set up. Lighting a gas range often involves simply turning a knob; however, blockages from food particles and debris caught in the burners, improper burner cap installation and gas supply are common problems that interfere with your gas range oven's performance. A few troubleshooting guidelines may solve these problems safely.
Other People Are Reading
Things You'll Need
  • Toothpick
  • Paperclip
Instructions
    • 1
      Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
    • 2
      Clean the burners if you have gas but your burners still won't ignite. To clean the burners, lift the burner caps 9b4f010f-be4f-4db6-8a88-4c3fd17e3339.gif
    • 3
      Inspect the small vertical holes on the side of your burners for dirt, food and debris. The gas won't ignite if they are clogged. Scrape dirt, debris and food from the vertical holes using a pointy object such as a toothpick or paperclip.
    • 4
      Reinstall the burner caps properly. If they are tilted or wobbly, the gas may not ignite. Install the caps on the right burners. Some burners are smaller than others, so match the caps to the appropriate burners.
    • 5
      Move the burner knob to the "Lite" position and wait for the gas to ignite. If it ignites, rotate the knob to your desired setting. If it doesn't ignite, contact a qualified appliance technician.
Jul 18, 2013 | Ovens
Has anyone had a problem with the inner glass on the Lamona oven door exploding. Mine just has! It's only 18 months old and hardly used. I wonder if it's the difference in temperature betweeen the hot oven...
We bought our kitchen from Howden's as well about 15 months ago. They installed a Lamona double oven and hob. Last night when opening the door to the bottom oven our glass on the inner door exploded as well. Maybe there was a batch of defective ovens as ours sounds as though they mat have been bought/manufactured at the same time.
Mar 07, 2011 | Ovens
I CLEANED MY CANNON CARRICK COOKER TODAY AND NOW THE IGNITION WILL ONLY WORK ON THE TWO RIGHT HAND HOBS. OVEN ANG GRILL ARE FINE AND LEFT HAND HOBS CAN BE LIT WITH A MATCH.
More that likely your just got the cleaning solution you used on the igniter/in the burner. Light the burners with a match and let them burn for a little bit of time. This usually works. If not you might have to clean the igniter and make sure it is creating a spark for ignition.
Gas hob continually clicking, as though wanting to ignite gas rings, all 4 of them pleasr help its driving us mad, cant switch off at mains as i it switches others off.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
Jan 05, 2011 | Ovens
PRODUCT DETAILS For MSP60SS
Matsui MSP60 Stainless steel Built-In Oven and Gas Hob Package. Matsui MSP60 with Hob: 4 Burner Gas Hob, Fan oven, Minute Minderand B Energy rated top oven. Matsui MSP60 Stainless steel Built-In Oven and Gas Hob.
Product Features
•Dimensions (cm): (H)59.0 x (W)59.5 x (D)57.0
•Ovens: Fan oven
•Timer: Minute Minder
•Hob: 4 Burner Gas Hob
•Colour: Stainless steel
•Energy rated top oven: B
Hope this helps. Your generous rating will be much appreciated.
Oct 20, 2010 | Ovens
Vulcan convection oven model SG4d-1 will not ignite burners
Gas does not ignite. No spark. No Ignition light is not ON.
1. Shorted electrode on igniter/flame sense.
2. Igniter cable (high voltage) OPEN.
3. Heat relay malfunction.
4. Centrifugal switch in blower motor inoperative.
5. Transformer inoperative.
6. High limit thermostat open.
7. Interconnecting wiring malfunction.
8. Ignition module malfunction.
Sparks but gas does not ignite.
1. Gas solenoid valve off or inoperative.
2. Manual gas valve closed.
3. Gas supply OFF or insufficient gas pressure.
4. Inerconnecting wiring malfunction.
5. Igniton module malfunction.
Feb 23, 2010 | Vulcan Convection Oven - VC44EC-208-1
Jun 01, 2009 | Ovens
Ovens Logo
874 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
