Jenn-Air JJW8230D Electric Double Oven Logo
Posted on Aug 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Beeping and blinking F1 - Jenn-Air JJW8230D Electric Double Oven
Fix Your Board
Level 3:
Guru:
  • Master 310 Answers
  • Posted on Aug 29, 2010
 Fix Your Board
Master
Level 3:
Guru:
Answers
310
Questions
0
Helped
124295
Points
1016
This is a failure in the control board. You can have the board(s) rebuilt at fixyourboard.com.
What could be the problem if F1 code and beeping in GE wall oven/
F1=Touch control pad and or Clock defective.
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part.
Jan 11, 2011 • Ovens
F1 keeps flashing and beeping
you can google your oven model for its codes. on our maytag oven the F1 code means defective touch pad or control board.
1helpful
F1 beeping
hello there:
Please read this carefully and follow the tips and this will help you find out what is exactly the problem ok
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
1helpful
2answers
The stove just says F1 and beeps won't let me do
Hello with the limited information and no make or model I can only give a generic response to this one. Most manufacturers F1 code indicates a bad control board (EOC) and or a bad touch-pad. If you have any other questions please feel free to comment. Mike
Nov 03, 2009 • Ovens
4helpful
Dacor oven beeps and shows F1 code
-F1- Alarm “System Watchdog Circuit”
The system will detect a failure in the internal watchdog element relay circuits and will activate a
cancel feature. F1 will be displayed in the time digits and will beep until the cancel button or another
function is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure
the ERC is picking up a command to supply heat without receiving an input from the membrane. The
watch dog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control (ERC)
Dacor
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
4helpful
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
5helpful
"F1" DISPLAYED AND BEEPING
F1-->Failed Thermistor Control Replace ERC
you will have to replace the ERC or Electronic Range Control or the touch pad.
Dec 18, 2008 • Ovens
1helpful
2answers
F1 error on SS Amana Convection wall oven
The control panel has a design problem, and it gets dirty and worn over time. I have replaced mine once, and it happened again less than 2 years later. I took the panel out, and inspected it. I found a web solution that said to shim the panel out away from the housing slightly because it rubs on the metal housing around it and damages the control board contacts. I could see little scratch marks on the plastic skin around the edge of the button area, so that made sense. I tried it, and it still did not work.....panel was still beeping. Mine seemed to be the timer control buttons that were going on and off. So, I took it out again, and actually peeled the control surface off of the control board. No going back now, I thought. I got it off and looked at the control panel. It looked fine, but there was a lot of gunk and wear marks around the edge of the plastic button area. I cleaned it up with alcohol swabs, and put the cover back on the board. It was still sticky enough to go back on. I reinstalled it, and "bingo" no more problem. It has been fine for 3 months now. Yahooo!
Top Jenn-Air Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
