What temperature should the hot water be to the washing machine?
  • 135 Answers
It will be whatever your water heater is set for minus some degrees for heat loss for the distance the pipes have to travel to get to the washer.
Posted on May 07, 2008
Don't think machine is washing clothes in hot water . What could be wrong ?
1) Improper water temperature selection, 2) no hot water to machine due to: a) being valved off, b) clogged filter or strainer, c) kinked hot water supply hose, d) failed hot water solenoid valve or bad / of loose wiring connection inside the washer or 3) depleted hot water in domestic hot water tank due to previous laundry washes / bathing / etc..
May 19, 2015 | Zanussi Washing Machines
Error code F20
The F20 error is a no water detected entering machine error and yes it is related to the hot water not being hooked up.
Newer washers sense and control the incoming water temperature. If you select cold wash and cold rinse you may think that it will not ask for hot water so you don't need it hooked up but you can't do that on this washer.
Even on a cold wash the temperature sensor will read the temperature of the incoming water. If your cold water is 60 degrees then the control will sense this and it may cycle the hot water on to bring the temperature up to 70 degrees.
Jan 11, 2011 | Whirlpool WFW9400S
Whirlpool washing machine water not hot enough
This so called "energy saving" ...That's why they build in this nonsense. Some dumbo in some office somewhere just thought it up thinking that will save the energy. I fact ,that way I have to wash same stuff twice because water is not hot enough ...
Apr 07, 2010 | Whirlpool WTW5300SQ Top Load Washer
Our washing machine is putting out hot water when the temprature setting is on cold ...and cold water when it is on hot. All rinses are hot. What part could be bad?
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected. If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Jan 03, 2010 | Washing Machines
Washer only has cold water. Hot water is good to machine but only cold water enters machine on warm cycle, no water ar all on hot cycle.
Hello there
The Water System temperature sensor is normally what is wrong with these units with this condition that you are experiencing
The water system consists of the hot and cold water inlet valves, a water temperature sensor, a water
flowmeter and control and the dispenser distribution system along with a traditional pressure switch.
Water Inlet Valves -
The hot and cold water inlet valves are located at the back of the washer. These valves receive a control
signal from the Central Control Unit to manage the temperature of incoming water. The temperatures
are determined by the specific wash cycle selected and a temperature sensor located in the wash tub.
To improve cleaning of heavily soiled clothing and to provide a sanitizing feature, the water temperature
can be increased through the use of a heating element located in the bottom of the tub
Dec 25, 2009 | Maytag LAT3600A Top Load Washer
What is the F20 error code?
F-20 error code in Whirlpool Duet Sport washing machine is indication of inadequate water supply. Check both hot and cold water supply lines to make sure machine gets enough water intake. If you do not have a hot water supply to the machine you can only run it with the cold temperature setting. This machine does not have an internal water heater and relies on the hot water supply from the house water heater.
Jul 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cold water Washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Apr 07, 2009 | LG WM-1832C Front Load Washer
Washing machine doesnt heat the water
Most washing machines do not heat water, they merely let the hot water into the wash tub that comes from your house hot water heater.... when selecting warm, hot and cold water will be mixed together to get warm or when selecting cold.. only the cold water is allowed into the wash tub.. Please provide brand and model number of machine so I can tailor a reply toward your specific washer...
Sep 21, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
