Question about Edelbrock 18064 650 Cfm Avs Carburetor With Endurashine
When the car sits for a week the carb goes dry and is very hard to start.It also idles fine one day and the next day it idles rough and runs rich.
If you want to prevent the Carburetor from dry after sitting for a while I suggest letting the car run for 5-10 minutes . I do that with my 78 El Camino SS 350 and after the carb is primed it starts right up
Posted on Sep 20, 2012
I have a small 4wheeler that is hard to start and will not idle it will run at speed but if you stop it doesn't idle it dies
Your pilot jet in the carb is plugged up or to small you will have to pull the carb out and clean it if you have a wire brush you can use 1 of the needles off it that will fit in the tiny hole in the pilot jet push it through and then spay carb cleaner through it and the main jet put back together and it should run fine
Nov 26, 2013 | RTO 125cc Full Size Adult Quad ATV
I have a 2004 VW Jetta. A few days ago my car after sitting in the hot sun all day idled very roughly then died at stop signs. The next morning it was fine, but the same thing happened in the afternoon. ...
run fault codes and look for a fuel supply sensor/servo failure. The heat is affecting the fuel system and is causing a fuel vapour lock or is over pressuring the injectors.
Sep 14, 2013 | Cars & Trucks
328 gts 1986 very rough idle, running rich you can smell the gas from the exhaust . runs fine once the throttle is pressed
you need to adjust your idle screw on your carb i could tell ya how on that type of car but your running to high of an idle and flooding your cylinders thats y it is idleing rough and you can smell the gas, adjust your idle screw back a little and then you might want to check your plugs and make sure you didnt fowl and of them with it running rich
Apr 21, 2011 | Ferrari 328 Cars & Trucks
I swapped out the plug wires and plugs with Denso, while I had the covers off decided to wash engine, engine ran fine. Next day started engine and the idle constantly oscillated between 1200 to 1400 RPM....
You are right this is a classic MAF problem or rather the air mass meter AMM which is the MAF working with the closely associated intake air temperature sensor IAT(a little bead like thermistor on wire sitting close to the MAFF in the air stream). The ECU was getting poor information from the MAF. The ECU had to rely on slow input signals from the IAT and feedback from the oxygen sensor on the exhaust to keep the engine running. The ECU hunted for the right mix, first rich and then lean but never settling hence the 'surge and slow' of the engine revs. When you disconnected the MAF you also disconnected the IAT and now the ECU had just the one signal from the oxygen sensor to depend on and so now provides a slightly rich mix giving the rough idle. You have done the hard work just change the MAF and IAT assembly.
Aug 19, 2010 | Lexus LS 400 Cars & Trucks
My 1983 toyota pickup runs rough and black soot come from exhaust
carb automatic choke sticking closed or your float setting too high causing flooding engine.
Nov 19, 2009 | 1983 Toyota Pickup
Recurring Mystery Problem in a 1986 Suzuki Alto. (Idle related)
Bad fuel, water in the fuel, dirt in the fuel.
Drain the fuel tank completely.
Pour in a gallon or two of fresh fuel.
See how it goes.
Put some of the old fuel in a glass bottle, hold it up in front of a light and see if you can see any foreign material in it...
Aug 19, 2009 | 1989 Suzuki Swift
Hard start and rough idle.
Sounds like it's time for a tune up of the ignition system. That would be easiest. If not, have a mechanic check your cylinder compression.
Feb 26, 2009 | 2000 Chevrolet Silverado
83 toyota p.u. 4x4 running rough.
I think you must have the carburettor plunger not going well as you are getting flat spots under sudden acceleration, I think the best way to go is to get the carburettor overhauled.
Dec 15, 2008 | 1983 Toyota Pickup
Ran out of gas and now she won't run!
i would say that you have a bad fuel pump or if you have a carb on it the float inside the carb is stuck check these and i'm sure you will find it's one of these.
Sep 06, 2008 | 1987 Ford F 250
Edelbrock 18064 650 Cfm Avs Carburetor With Endurashine Logo
247 people viewed this question
Top Edelbrock Toys Experts
ray gallant
Are you an Edelbrock Toy Expert? Answer questions, earn points and help others
