Question about Toshiba 46H84 46" Rear Projection HDTV-Ready Television
Smudge marks??? I'm not even sure if this is where I can get help, but I'm going to try. I've had a Toshiba 46H84 for about 2 1/2 years. Just the other day I noticed two smudges on the screen. It looks like someone touched the screen with dirty hands. Anyway, I cleaned the screen over and over again, but it doesn't come off. It almost looks like it's underneath the plastic screen. Does anyone have any idea what this is and how I can clean or fix this? Confused.
  • lgriego May 07, 2008
    My screen doesn't have grooves though...it's a smooth surface. I'll try the warm water and dish soap. It's really wierd. It looks like someone touched the screen surface, but the marks went into the screen behind the clear plastic.
  • eric Jan 15, 2009
    I have same problem with Sony Grand Wega 60 inch LCD. Was told "smudges" are from whats called an optics unit within the set. This part costs $1900.00 Can you believe this. I had the tv for just over 3 years and now I need a 1900,00 repair. SONY SUCKS!!!
I have this same problem with my TV and can't figure out how to clean it. Was thinking I might have to call a TV repair man.
Posted on Jun 30, 2008
Not see nathing en
Posted on May 08, 2008
Not see nathing en
    President:
  • Toshiba Master
  • 1,779 Answers
If they are grease marks you can use a warm water a soft cloth like a t-shirt and little dish washing liquid. Gentley wipe the area only stroking down or up--- NEVER SIDE TO SIDE---. Have a dry cloth ready if you drip water down the screen. Now if those are scuff marks, your done, they cannot be removed. They are like the old record albums with the grooves, once the grooves get distorted that's it. Good luck.
Posted on May 07, 2008
  • Jim Krause May 08, 2008
    Your safety screen does come off the set. It sounds like something got in thru the top molding and went down, does this sound likely?
Hi, i've tried to install sound drivers but they are not working
Try downloading the latest audio driver from the Toshiba WEB site.
You can download the audio and device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Feb 16, 2013 | Toshiba Satellite L505DGS6000 Notebook
Toshiba 47 inch lcd just developed a yellow smudge to one side of screen
does it take new bulbs? whenever i have this problem with my projectors it needs a new bulb, hope that helps
Aug 25, 2012 | Toshiba REGZA 46RV530U LCD TV
Maytag gas dryer about 10 years old leaving black smudge marks on clothing. The wheel was hanging up on the dryer drum. Could there be other causes for the smudge marks?
your clothes are getting caught between the drum and the rim due to bearings out of the wheel guides. These guides are what the drum rests on when it is turning. Most dryers you can access these guides by taking the front off the dryer. Not a big expense just a little difficult to get to .
Apr 12, 2011 | Dryers
How do I get smudge marks and dust particles off the front border
use dry soft cloth use some eye glass cleaner, windex on paper towl make sure itz off first
Dec 17, 2009 | Audio Players & Recorders
I'm getting black smudge marks on copies. After
I also had this issue, waste tone was comming from the transfer belt, had a good clean out been good for months now.
Aug 11, 2009 | Samsung CLP 300 Laser Printer
Printer is printing two smudge marks on my documents.
Two parts of the printer can affect this.
1) the toner cartridge
2) the fuser
Testing can be done to determine the problematic part.
Do a print using manual feed. Once the last bit of paper goes into the machine, open the printer door.
Remove the toner to check if smudge is there.
Replace toner cartridge if there is smudge, replace fuser it not.
May 29, 2009 | HP LaserJet 3330MFP All-In-One Printer
Toshiba dlp
Sound like you light engine is going bad. A major problem to fix! Especially if you are sure it is a dlp
Jan 07, 2008 | Televison & Video
Dark picture (HELP)
Open up the back of the set but be very carefull. Notice a large black block with a large red wire that runs up to the picture tube. on one side of that large block where the thick red wire is comming out of are two controls, one should be marked focus or F and one should be marked screen or S. With the set operating normally and not touching anything else, slowly turn the control marked screen or S clockwish till the picture gets bright enough. If you go too bright the set will shut down or you see small thin white lines so back down on the control. then touch up the focus and your good to go. good Luck.
Dec 01, 2006 | Toshiba 32A42 32" TV
Toshiba 46H84 46" Rear Projection HDTV-Ready Television Logo
335 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
