Question about ViewSonic KP202, VIEWMATE OFFICE KEYBOARD BLACK/ SILVER PS2 W/ 48 OFFICE HOTKEY (KP202EMJNRP)
Keyboard is locked up. Looks like Function Keys
Keyboard is locked up. Looks like Function Keys Lock is on. How do I unlock the keyboard. BTW: I have already rebooted several times. Have Window XP OS. Thanks
Is scroll lock on? if so turn it off and engage number lock.
Posted on Aug 29, 2010
  • 4 Answers
If key-combinations do nothing to remedy your Fn-problem, try this:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=dk&lc=da&dlc=da&docname=c02035108
Posted on Nov 10, 2010
I need a keyboard manual for an Aires K3 seven colour keyboard
Function Keys(for Aires 3 colour keyboard , so i'm guessing will be the same)
Fn + Esc:4 levels backlit brightness adjustable,suitable for use days & nights
High light - Medium light - Respiration light - Extinguish (High brightness by default when starting up).
7 Multimedia Shortcut Keys: Stop, Fast forward, Rewind, Play/Pause, Volume-, Volume+, Mute
3 levels keyboard speed adjustable:
Fn+F1 : 21 byte per sec(80/S)
Fn+F2 : 30 byte per sec(60/S)
Fn+F3 : 63 byte per sec(40/S)
Fn Multimedia Combination Keys:
Fn + F4 Mute
Fn + F11 Lock/Unlock all keys
Fn + F12 Lock/Unlock Windows Key
FN + W : Switch WASD keys and Arrow keys.
Fn + Tab:3 colors adjustable backlit
Jan 28, 2017 | Audio Players & Recorders
Unlock the security chip for a ibm t 60 thinkpad
IBM-branded Thinkpad T60 laptops from Lenovo are mobile computing devices that feature a keyboard lock for data security. When the lock is enabled, pressing the keys on the keyboard does not result in input to the computer. The lock hampers attempts by an unauthorized user from gaining access to your computer and your files. Lock your Thinkpad using the Function key. The Function key used in conjunction with other keys on the keyboard expand the laptop's number of available features.
Locate the "Fn" key in the lower left corner of your Thinkpad keyboard. Locate the "F2" key in the upper left area of the keyboard. Press and hold the "Fn" key, then press the "F2" key to toggle the "Lock" feature. Release both keys. Hope this helps.
Jan 14, 2013 | IBM Computers & Internet
I am not able to work with my keyboard function keys and num keys and function keys . but the the touch pad key is onlyworking .please send a solution to unlock the keyboard. hp pavilion g6-2102tx
Examine your keyboard to ensure your "Number Lock" key is not activated. This activation is indicated by the key being lit up. If the key is activated, press it to deactivate the lock. The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor. In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon. Hope this helps.
Dec 10, 2012 | Computers & Internet
How to unlock keyboard
I just think you accidentally locked your keyboard and touchpad by pressing the function key!
Just press: FN + F6
this will unlock the keyboard and touchpad!
Thanks
Nov 30, 2011 | Acer Aspire One D260 Netbook
My keyboard types numbers for several keys unless i hold down the function key. how do i turn off this feature/
Sounds like Num lock has been turned.
Looks for num lock on the keyboard and press it.
You may have to press FN & Numlock.
This will resolve the issue.
Apr 26, 2011 | Fujitsu Siemens Fujitsu Lifebook P7230...
When i type the letters on my keyboard, the numbers show up instead. i don't know how to revert the system or functions back to normal. i must've accidentally pressed a button to change the characters when...
Sounds like the keyboard is in NUM LOCK mode
They keys map like this:
7 8 9 = 7 8 9
u i o = 4 5 6
j k l = 1 2 3
0 . = m .
Look for the NUM LOCK key on your keyboard.
Typically, you press the FN key (lower left corner) and the NUM LOCK key (typically towards the upper right) together to put the keyboard back into regular mode.
Apr 21, 2011 | Twinhead DURABOOK N15RB Notebook
How do you lock/ unlock a keyboard
Press the "Windows logo key + U." This will open the ease of access center. Click on the "keyboard." It will say, "make the keyboard easier to use" next to it.
Select "turn on sticky keys" and "turn on filter keys." Select "save." Your computer will now only make sounds when the keyboard is hit.
Follow steps 1 and 2 to unlock your keyboard. Unselect the "sticky keys" and "filter keys" and click on "save
Lock your workstation. Press "Ctrl + Alt + Del." A blue screen or a box will pop up that has a variety of options, such as restart or shut down the computer. Click on "lock this computer
Lock your work station using the keyboard. Press the "windows key", it looks like a flag, and the "L" key at the same time. This will lock the computer. To unlock press the combination again.
Nov 10, 2009 | Computers & Internet
Keyboard keys that have purple numbers are locked. Can't type.
Your "Num Lock" is on.
Look for the num lock key (it's similar to the "caps lock" key in function)
If the "num lock" is blue, you may have to hold a blue "fn" key when you press num lock
There's is probably a light at the top of the keyboard that'll tell you when num lock is on.
Sep 20, 2009 | Compaq Keyboard
Acer Notebook Keyboard is locked
Just hold down Fn then press F7 or F8 keys to unlock keyboard.
Good luck.
Aug 14, 2009 | Acer Aspire 4315 Notebook
ViewSonic KP202, VIEWMATE OFFICE KEYBOARD BLACK/ SILVER PS2 W/ 48 OFFICE HOTKEY (KP202EMJNRP) Logo
641 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
