Question about Sony Grand WEGA KDF55E2000 55" Projection HDTV
My sony grany 60'' tv is blinking 6 times. i ried replacing the lamp but still doesnt work
mistersony
  • 320 Answers
SOURCE: Sony Grand Wega 60" indicator lamp blinks 5X green then 6 red
It is unusually to see BOTH of these flash codes together. I have never seen them at the same time. A 5 flash is a lamp driver error, which is possibly related to your lamp failure. You may have to replace the lamp driver or "ballast" to correct this problem. The 6 flash is a power supply problem and more serious, as it will likely take a technician to narrow down exactly where the fault lies. It may be a thermal fuse open OR a failure in the power supply itself. What was the original symptom that caused you to replace the lamp? Did you use an original Sony lamp as a replacement?
Posted on Nov 27, 2008
tvtechnician
  • 105 Answers
SOURCE: Sony Grand WEGA KDF-60XS955
the g1 board is your issue. 6 blinks means there is no or low b+ coming from the g1 board.
Posted on Oct 12, 2007
  • 113 Answers
SOURCE: 60" Sony KDF-E60A20 - Red Light Blinks 6 times
The problem you have is a failed thermal sensor. Depending on how tech savvy you are you can replace it.They have changed the way the thermal sensor looks but it isnt too bad too put in. Any repair shop should also be able to do this for you.
Part number is 1-910-006-44 Themal Fuse Sony Part.
Posted on Feb 04, 2008
  • 556 Answers
SOURCE: Sony Grand Wega 60 inch LCD Projection TV goes dark.
most likely, buy you a lamp and install it yourself, the owners manual tells you how to do this.
Posted on Sep 11, 2009
SOURCE: My sony wega 60 inch tv will not turn on. The
I bought a new blub for it and the light still goes green then red.Anybody know?? mg
Posted on May 19, 2010
Sony kdsr60xbr1 standbuy blinks red 6 times. Pulled lamp out, it was broken. I heard lamp pop. Do I just need to replace lamp or is it something else as welll?
If your not sure, google name and make of tv and "red light blinks 6 times". That usually is a code for what is wrong.....My money is on the lamp....especially if it was working fine before. Hope that helps and gd luck to ya
Mar 13, 2012 | Sony KDS-R60XBR1 60" Projection HDTV
Series of 3 blinking lights. manual says lamp door isnt fastened properly. it is. i tried unplugging tv, have opened and closed lamp door 3xl. still blinking.
After I unplug and then plug tv to reset I get a solid standby light,then when I push the power button I get a green light that blinks 6 times then it blinks red 6 times and then red 6 times continuosly with a slight delay between the 6 blinks of red.
Oct 11, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony KDS-R60XBR1 bLINKS 6 TIMES
When I try to look up blink codes I'm getting conflicting info. On this model is the lamp on side of TV? If so 6 blinks is showing as lamp door error, the micro switch the lamp door makes contact with is either not closed all the way or possibly defective.You can try reseating door or check the switch and wiring connections coming off it. You could try temporarily by-passing the switch by making your own short across the plug it connects to.
If the lamp mounts in front 6 blinks is a defective thermal fuse.The fuse is mounted right next to the lamp.From the back you can disconnect the plug for the fuse and check for continuity if its open its bad.
Apr 30, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Nov 27, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony KDFE60A20 TV turns off and on with Red light blinking 5 times
Same problem here. 5 blinks is video related. I've been told to clean the screen by the lamp, as they could be clogged and causing it to over heat. Going to give thet a try first. I'll post what happens...
Oct 07, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Oct 08, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Red Power Light Blinking 6 Times
THIS IS HOW I FIX MY SONY TV WITH FIVE BLINKING RED POWER LIGHT.
PULL OUT LAMP - FIND THE INSTRUCTION ON LINE (SONY WEBSITE OR YOUTUBE) EASY
THERE ARE TWO METAL CONNECTION TABS (on top of the lamp) ON THE LAMP. CLEAN THESE TWO METAL FLAT TABS. THESE two tabs MAKE CONNECTION TO THE THERMAL FUSE. IF IT IS DIRTY IT WILL NOT MAKE CONNECTION to the fuse.
CLEAN YOU'RE LAMP WITH A VACUUM. GET ALL DUST OUT.. CLEAN OUT THE TV...THE FAN SUCKS IN DIRT. THIS WILL FIX many ISSUEs. like over heating! dog hair, dust, gets sucked inside the TV by the FAN....hmmmm
ALSO DO THIS TO ALL YOU'RE ELECTRONICS THAT HAS A FAN.
(I FEEL ALL FANS ON ELECTRONICS SHOULD BE REVERSED) but i am sure there is a stupid reason that they want the fan to **** air inside the electronics. Like hmm
THIS cleaning SHOULD BE DONE EVERY 6 MONTH
Aug 13, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Sony Grand WEGA KDF55E2000 55" Projection HDTV Logo
115 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
