Question about Zenith LX-140 CD Shelf System
Clearing the presets on the radio HELP! - Zenith LX-140 CD Shelf System
  • Zenith Master
  • 17,130 Answers
I did not get to whatt is required by you? did you mean to reset the radio channels that is already on preset.
If so use the manual mode to search for the frequency, once the selected frequency is fixed , press the memory to flash and select the preset of the location you want to be stored.
If you meant the question to be clearing all presets , just press and hold to an blank channel the memory and select location.
Posted on Aug 29, 2010
I can change the time on radio clock but it just stays on that time
I had this problem after a main dealer repair that required the battery to be disconnected for a couple of hours. I put i right by leaving the battery disconnected for 12 hours until all the memory including radio presets had cleared. After reconnecting it returned to normal. I t may take yours longer or less time but the radio presets clearing seems to indicate it will restore the clock.
Oct 24, 2013 | 2007 Toyota Aygo 1.0
Hi Can anyone help me unlock my ford mondeo Radio? Serial Number M124058. Thanks?
your radio code should be 4944
follow these instructions to enter code
Switch the ignition ON using the key
Switch Radio ON - Display Shows CODE with " - - - - " flashing
Press Preset Button " 1 " repeatedly for 1st Digit of your KeyCode
Press Preset Button " 2 " repeatedly for 2nd Digit of your KeyCode
Press Preset Button " 3 " repeatedly for 3rd Digit of your Keycode
Press Preset Button " 4 " repeatedly for 4th Digit of your Keycode
If the display now shows the correct KeyCode number then
Press Preset Button " 5 " to Enter
May 09, 2012 | Ford Mondeo Cars & Trucks
I have the code for my ed station wagon number is 2602 problem is there is no zero number on radio how do you enter the code.Thanks for your help
The code entry instructions depend on the make + model of radio.
See if you can find your radio here
CLICK HERE
Many radios require the multi-pressing of Preset Buttons 1 , 2 , 3 , and 4 to be used for each digit separately
For example
Press Preset Button " 1 "repeatedly until the 1stDigit of your Code is displayed Press Preset Button " 2" repeatedly until the 2ndDigit of your Code is displayed Press Preset Button " 3" repeatedly until the 3rdDigit of your code is displayed Press Preset Button " 4" repeatedly until the 4thDigit of your code is displayed
Mar 02, 2011 | Car Audio & Video
Custom programing the radio
To set Radio options, press submenu in Radio
mode.
?? Select Add Preset to save current frequency
into presets.
?? Select Delete Preset to remove current
frequency from presets.
?? Select Delete All Preset to clear all presets, and
next time when you enter Radio Mode, Sansa
e200 will search automatically.
?? Select View All Presets to view all preset
frequencies. The autoscan option will replace
existing presets.
Jun 28, 2010 | SanDisk Sansa e250 MP3 Player
Radio Installation procedure
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} These are the working Code Entry Instructions if the Renault does NOT have the Steering wheel Remote Control
Keep pressing the Preset [1] until the correct first digit appears on the display
Keep pressing the Preset [2] for the correct second digit
Keep pressing the Preset [3] for the correct third digit
Keep pressing the Preset [4] for the correct fourth digit
If the correct code is now shown on screen, press and hold the Preset [6] for 10 seconds to save it.
Note: If Preset [6] does NOT enter the code , then try Preset [5]
Jun 06, 2010 | Car Audio & Video
How do I preset radio stations?
PRESET RADIO STATIONS
1 press RADIO BAND. AUTO PRESET to select the band.
2 Hold down RADIO BAND > AUTO PRESET for 2 seconds until "AUTO"flashes in the display
3 Press DSPL/ENT/MEM. The stations are stored in the memory from the lower frequencies to the higher ones.
if a station can not be preset automatically.
you need to preset a station manually.
2 tune int he station you want.
3 hold down DSPL/ENT/MEM. for 2 seconds until the preset number flashes in the display.
4 press PRESET + or - until the preset number you watn for the station flashes in the display.
5 press DSPL/ENT/MEM. The new station replaces any old one.
TIP the preset radio stations remain in memory even when all power is disconnected.
manual available at sony
http://www.docs.sony.com/release/CFDF10.pdf
Jan 01, 2010 | Sony CFD-F10 Radio/Cassette/CD Boombox
Zenith Z212G radio, Need preset modification instructions
Zenith Z212G radio, preset modification instructions
  1. Display desired station
  2. Press Memo Set button to make "Memo" flash on display
  3. Select desired preset number
  4. Press Memo Set button to save
Apr 12, 2009 | Zenith Z115S Clock Radio
Station preset on AWR1-1W bose radio
I found out you tune the radio to the station you want to preset, and hold the preset button (1-6) that you want to assign it to until it beeps. And it's set.
Jan 08, 2009 | Bose Wave Radio
How to code radio for suzuki ignis
press the disp button and hold for 2 seconds and then enter the code using the preset radio buttons 1 for position 1 and 2 for position 2 ect ect
Apr 05, 2008 | Car Audio & Video
Setting preset stations
Hi Gil, not sure what you mean by RE-setting presets but I assume your using a dock of some kind, and in that case you simply tune to the station you desire then hold down the preset number you'd like to set it to. It will overwrite the previous setting. hope that helps.
Feb 22, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
Open Questions:
See all Zenith LX-140 CD Shelf System Questions
Zenith LX-140 CD Shelf System Logo
56 people viewed this question
Top Zenith Audio Players & Recorders Experts
xalint1
xalint1
Gagan Telecom
Gagan Telecom
Level 1 Expert
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
