Question about Haier Heating & Cooling
What do i do when my air con is leaking water out of the top where the air comes out of?
    President:
  • 3,074 Answers
You can check to make sure it is draining, as if it is not then sometimes water will spit out and air will feel warmer. Hope this helps Tim
Posted on Aug 29, 2010
Model 645. Why did driver side rear footwell fill with water?
Water leak check:
1. Plenum chamber leaks at loom exits (Accident damage or corrosion)
2. Water leak at air con fan inlet (Accident damage or gasket wear)
3. Water leaking from air con heater pipe (corroded water pipe to/from heat exchanger)
Oct 28, 2015 | BMW Cars & Trucks
2005 Chrysler Town and Country Coolant Leak After running Air Conditioning?
You do not say if you are losing coolant or not , if not every thing is ok as its condensation from the air con, If it has coolant loss it could be over heating, make sure the extra fan comes on with the air con.
Aug 20, 2014 | Vehicle Parts & Accessories
Water leaks under portable air con unit
Look for a crack on the water tank or a dried up gasket on the tank. Loose hose clamps can allow a leak as well.
Jan 04, 2014 | Heating & Cooling
Leaking coolant but cant find the leak?checked the radiator and pipes but still cant find it!could it be something to do with the air con unit? only leaks when started and will drain the water out of the...
There is absolutely no way possible that the air con unit is going to cause an engine coolant "leak". The air conditioner can cause the engine to overheat if the fans are not working properly, but you will see coolant coming out of the radiator cap if it is overheating.
To find a coolant leak you just have to look for it while it is leaking. If you can see it dripping out on the ground, then you should be able to follow it up to see where it is coming from. Cracks in the plastic radiator tanks are common in all Honda vehicles. These cracks can have the characteristic of only leaking after reaching a certain temperature. You will probably have to remove the plastic shrouding from under the vehicle to see many of the leaks that can be coming from the front radiator area.
Water pumps can also leak at only certain temperatures. Sometimes they can fool you also because there are channels on the back of the pump that will direct coolant away from the water pump/ timing belt area in the event of a leak. It can look like it is leaking from the side of the engine that is away from the water pump. Again, you have to LOOK to see where it is originating from.
Apr 28, 2011 | 1990 Honda Civic
1999 grand jeep cherokee limited air con prob water coming out vent behind driver seat and water drops noted under glove box front passenger side ???? what to do air con recently regased works well but...
You have a leak in your air conditioning compressor Your system works on the reheat principle All air passing through the system is cooled and reheated before it enters the cabin this sould be dehumidified air but it passes through the heater core and sence the air is not dehumidified you are getting condansation as the air flows the heater core that is heated by the engine heat and the water is from condencation because of the leak in the ac compressor The unit is a press fit in the center of it and fials unfortinatly a lot with this disgien of compressor
Nov 26, 2010 | 1999 Jeep Grand Cherokee
Water in the footwell????
air con evaporator drain pipe blocked or missing. condensation forms on evaporator and and must be ablr to drain out under vehicle. if drain blocked water will build up and leak into foot well. if missing water will drain directly into foot well.
May 20, 2010 | 1999 Volkswagen Passat
Heating & Cooling Logo
57 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
