Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
When I plug in tv and turn it on, the power button blinks three times and does nothing else.
SOURCE: Screen is Black Power Light Blinks Three Times
bad power sorse bring the tech in unless u know how to chage outthat part
Posted on Mar 15, 2008
Slinteriors
  • 8617 Answers
SOURCE: blinking power button
Blinking power light is usually due to bad capacitors on the power supply. See the tip for RCA atc336 under my profile that can apply to your set as well.
Posted on Apr 09, 2008
  • 18 Answers
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Posted on Feb 25, 2009
Slinteriors
  • 8617 Answers
SOURCE: model d52w19 rca projection tv,will not turn
Thats the eroor for the flyback and CP150 needing replacement you can get the flyback # 259296 and the CP150 at the following link and they give free step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Posted on Mar 06, 2009
HeXx13505
  • 65 Answers
SOURCE: I have an RCA Scenium 61
sounds like you need to replace the color wheel but most of the time that is almost as expensive as the TV itself best bet for this problem would be to bring it to a shop and have it serviced
Posted on Mar 27, 2009
When the tv plugged up the power led blinks 3 times. When the power button is pressed the tv comes on for three seconds and turns back off. What could be the problem? Could this be a convergence problem?
Do the self check when power light goes out:
ON front of set (not remote) press and hold both the Menu and Input (Device) buttons at same time for 5 seconds or longer and release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know code.
SD TECH
Sep 24, 2010 | Mitsubishi WT-46809 46" Rear Projection...
GE Tv, replaced flyback... still nothing.
Have you ck 3 capacitors on deflection board cp150 2200uf 16v, if it is bad other 2 caps are 220uf 35v cp114 cp120 Your TV is really a RCA
Sep 16, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
My toshiba 42HL167 won't turn on
Try this fix from the toshiba website. Q. I have no picture or sound, but I have a blinking power light?
Models: LCD-2007
REF:FAQLCD00090
1. Try resetting the TV by disconnecting the power for 30 seconds and then plugging it back in. If this has no
effect, try moving the TV to a different power outlet that has been tested and is known to be good.
2. If your unit continues to fail, please contact our Customer Solutions Department at 1-800-631-3811 Monday
through Friday, from 8 a.m. until 7 pm CST for a local Toshiba Authorize Service Station Hope this helps you with your problem.
Feb 27, 2009 | Toshiba 42HL167 42 in. LCD Television
Blinking Red Lights
Sound like an error code 14 (Audio supply) is beeing blinked...
You probably would want a qualified technician to take a look at it.
Jan 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
I'm having a problem with my Panasonic PT-53wx52
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Oct 30, 2008 | Panasonic PT-53WX52 53" Rear Projection...
Universal remote wont work with this TV
Questions: Who is "Sansui", the digital box ? or the TV? Is the "digital box=remote control"? turn on what you want to control.
Face the RC face down or away from TV,or whatever you want to control. Usually:: push & hold TV & SEARCH button until light blinks, two, three times? FACE THE TV and put the code for the [TV=Sansui ?] You said #189 try 0189 [zero,one,eight,nine]
2nd) TV power ON!,....HOLD down (and if you have a SEARCH) button and the tv power button on RC, two or three blinks, push up arrow once, press power button for TV on RC, nothing!, continue...up arrow, power button. when the TV turns off, you have found the code,. YOU MAY HAVE TO DO THIS 50-150 TIMES because the RC is looking through EVERY code!
Sometimes
Apr 26, 2008 | Sansui CDVD1300W 13 in. TV/DVD Combo
Power problems with philips magnavox 25TR19C1
aparece codigos en la pantalla MSD luego 55 sy
Dec 18, 2007 | Philips Magnavox 27MS343S 27" TV
Blank screen, no sound
If ti blinks three times, then it may be an issue with the flyback transformer. It's called "three strikes"...it tries three times to come on, and after that enters a safety shutdown mode to protect the TV. Might need to have a professional shop take a look at it.
May 02, 2007 | Durabrand DWT1905 TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
29 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
