Question about Saeco VIA Venezia
I have the Via Veneza, I use Starbucks coffee pods and for past few months, water is coming out of the top of the filter. It doesnt' do this when I use ground coffee but ground coffee is messy and I prefer the pods but hate the water coming out of the top of the filter. It looks like the silver part that holds the pod does not fit properly in the porta filter unlike the ground filter, it sits securely in place. The pod filter does not fit securely and that might be why. THough I did try using the portafilter from our machine and work and it still did it. That one is the same and eventually I feel it will start doing the same.
    President:
  • 1,618 Answers
Sounds like you need a new group gasket.
Posted on Sep 01, 2010
Coming out in short spurt will not coffee cut up
there are a few things that can cause this;
1) You may need to clean the needle in the coffee exit where the coffee pod sits and gets pierced when the top is closed. You do this with a needle, be careful the point of the piercing nozzle is sharp and the needle point is as well.
2) There is also a needle in the cup holder under the pod that cuts the hole for the coffee stream, this needs to be cleaned with the needle.
3) The filter in the water tank may be plugged and needs to be cleaned.
4) The pump may be clogged with lime and scale.
5) The heater element may be scaled with lime.
6) Items #3 to 5), to fix this use DE-scalier, or vinegar solution, the pickling strength works better than household variety, but both are OK.
7) run the cycle for coffee, no pod, 3 times, this should clear the taste of the vinegar.
Hope this is your solution.
Mar 17, 2015 | Keurig B70 Coffee Maker
My Senseo Coffee Machine works fine on the one coffee duck. But, when I use the 2 cups duck, nothing - just a few dribbles. Then I can't open the top either - it appears to be suctioned closed.
The 2 pod strainer it clogged. If you hold it up to the light you should be able to see light coming through the other side. Try soaking it in hot water for a half hour and than blow it out the center of the pod strainer with one of the compressed air/ gas duster cans. If this doesnt work than try a needle.
Mar 02, 2015 | Fire Sense Pool & Spa
Verismo 580 leaks clear water in spout behind pod spout
Be sure you put the silver lever (embossed with the word Verismo) down before pressing the coffee button. (The small cup illustrated on the top right.
Mar 02, 2014 | Starbucks Single Serve Brewer, Verismo 580
Starbucks verisimo clogged and the spout is shooting off
If your machine is clogging, try running the water through the machine, Press the button that [looks like a little shower icon on the top left] first. May need to do it twice. Do that each time before you put a coffee pod in the Verisimo.
Feb 28, 2014 | Starbucks Single Serve Brewer, Verismo 580
Starbucks Saeco Italia Digital Barista Fully Automatic Coffee Machine will not prime!
Here is what is said in the manual:
"Direct the steam arm on the drip tray.
Open the steam/hot water knob until a
steady stream of water is dispensed. Close
the knob. Insert the filter holder into the
brew head to pre-heat the filter holder.
The machine is now ready to dispense
coffee."
Apr 26, 2017 | Starbucks Saeco Italia Digital Barista...
When i place pod into machine it doesnt have any water or coffee come through when i switch it on
A few initial steps:
  • Insure that the water reservoir is full, and that the machine is plugged in.
  • Check the water inlet tube for kinks.
  • Ensure that you are using the correct portafilter or insert for ESE pods.
Here is a link to the manual.
Krups contact:
Phone: 1-800-526-5377
Monday through Friday 8:00 AM to 9:00 PM EST
Saturday 10:00 AM to 2:00 PM
Mar 03, 2011 | Krups XP4030 Espresso Machine
The water or coffee does not come out correctly anymore. When making a cup of coffee (w/ pod) or just hot water (no pod), the hot liquid does not come out in a steady stream, it goes everywhere. When i...
211333Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 21, 2010 | Keurig Elite B40 Coffee Maker
We just got a Via Venezia espresso maker. When I
put the rubber gasket in, then the pod basket, then the pod
Feb 22, 2009 | Saeco VIA Venezia
Saeco VIA Venezia Logo
122 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
