Question about General Electric WCSR2090D Top Load Washer
My GE washer basket makes a rattle sound when moved by hand. 5 years old
  • General Elec... Master
  • 17,129 Answers
The best option is to look at the source of noise than to specilate on a whole list of possibilities.
Please use a good lighting to look from the underside of the washer . Now rotate the main shaft, rotate the drum and check.
The fault can be poor spindle assembly, check bearings, belts.
Also it can be that some foregn objects have lodged into the tub from any clothes during the wash. so check this out, if so remove after dismandling.
Please proceed to check and respond.
Helpful?
Posted on Aug 29, 2010
  • armbruk Aug 29, 2010
    This is a model wcre6270 not a wcsr2090d.
GE adora front load makes loud rattling sound in spin cycle. nothing in drum. sounds like a ball bearing
its the inner baskets bearings behind this basket as water gets past the rear seal into these bearings and ruins them,you need to dismantle the entire unit to remove the inner basket from the outer tub to replace these bearings
Oct 27, 2012 | GE WSXH208A Front Load Washer
My washer is making a ratteling sound a few time in the rinse and spin cycle, and when i turn to the clean cycle i put affresh in it and its estimated time is 1:02 mins but it only takes about 5 mins...
Ya gotta be careful about over adding detergent. But the rattling to me sounds like the basket is having trouble engaging. That might be due to a small item of clothing between baskets. This will more often than not display a F-72. Bravos service manual
Mar 16, 2011 | Maytag Bravos MTW6600T Top Load Washer
Badger 5 is about 15 years old and is leaking from the bottom -- from the reset button, the plate on the bottom, and around the electric cord. Can I fix it or does it need replacing?
Once disposal rusts out, it needs replacement.
Usually if sink basket seal is broken or if dishwasher attachment is leaking, you can feel water near top of disposal.
Use paper towel at top to see if that area is wet.
If top area is dry, then water is coming from inside disposal, and disposal is rusted out.
If sink seal is still good, we used to buy same brand disposal and re-attach to same sink basket. That's the quick fix.
If this is inside your home, you probably want to install new sink basket that comes with disposal.
To install new disposal, also buy container of plumber's putty to seal sink basket.
Remove disposal.
Clean off old putty on sink. It will chip off easily.
Apply finger-thick amount of plumbers putty to sink opening.
Set disposal sink basket into putty and push down.
Tighten screws on bottom of sink basket.
Wipe away excess plumber's putty from sink so it looks nice and smooth.
Before lifting disposal into place, attach electric wires and attach dishwasher hose to disposal.
Use hammer and screwdriver to remove steel blocker located inside dishwasher stem ... the blocker is left in place if no dishwasher hose is attached.
Disposals can be different: But here's the usual sequence:
Lift disposal with one hand and hold level. Push up strong while rotating attachment ring until ring grabs bottom of sink basket.
If you cannot lift disposal with one hand while rotating attachment ring with other hand, use small bottle jack from auto-parts store. And put piece of wood between bottle jack and aluminum disposal so disposal doesn't break.
Here's how to handle tubular pipes below sink:
Any tubular pipe joint that moved while removing or installing disposal, has to be taken apart, cleaned and re-attached.
If washers are plastic, then clean and re-use.
If washers are rubber, then replace each washer with new rubber washer.
When reattaching tubular pipes, apply generous amount of rectorseal over each plastic or rubber washer for first-time seal of tubular pipes.
Nov 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
AGGITATOR NOT WORKING AND THE SPIN CYCLE NOT WORKING ALSO LOOKING FOR TEARDOWN INSTRUCTIONS.
how old is ure machine if it is about 5 years old and the drum is strugglin to spin u will need your motor brushes changing
Feb 03, 2010 | GE WNRD2050DWC 3.5 Cu. Ft. Commercial...
GE washer WJSR4160G0WW agitation is way too fast & hard
check the 4 rubber cords at the top of the tub. If the washer has been moved they may need to be adjusted, you can see them by looking between the top of the tub and the top cover. You can turn them with your hand, and you may need to tighten them after.
Jun 07, 2009 | GE WJSR4160DWW Top Load Washer
Machine does not agitate, will spin and rinse including.
Hi,does the top part of the agitator move freely when you move it by hand?Or does it catch,if it does not catch the the cogs other wise known as dog ears are worn out.Do not believe the little cogs that catch inside the top part of the agitator can be replaced.You may have to replace the whole agitator unit on some models they are around 40.00.
Apr 11, 2009 | Maytag PAV2300 Top Load Washer
Whirlpool washer does not start after fill with water
It sounds like the washer tub is off balanced. When it is, it will usually not start. Underneath the washer, there are 3 or 4 bolts or nuts, depending on your washer model, that hold the washer to these balance springs. make sure that the bolts or nuts are tight or secure. If this doesn't help, get on a website called Repairclinic.com. They usually will help with home repairs.
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire FTF530FS Front Load washer
Take off the lower panel. Inspect the shocks too see if they are damaged. If they are OK turn the wash basket by hand if the knock is heard then most likely you have a broken wash basket.
Jan 13, 2008 | Frigidaire FTF530FS Front Load Washer
Object between drum and spin basket
yes there is but you have to brake apart the hole machine and thats not ease I strongly recomend a tech and pay for this..good luck
Jul 26, 2006 | Kenmore Elite 45986 Front Load Washer
General Electric WCSR2090D Top Load Washer Logo
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
