Question about HP Pavilion dv9000z Notebook
Laptop Screen SPLIT
After owning this laptop for approximately 1.5 years, the screen on my laptop has literally split. It appears that the hinges inside the screen itself have snapped from normal usage, thus splitting the side of the screen apart.
An image of this can be seen here: http://lauxnet.homeip.net/images/laptop_02.JPG
Any suggestions on where I can go to fix this?
  • 3 more comments
  • Nicholas Laux May 07, 2008
    I did try calling HP before, and they gave me the runaround of "Your laptop is out of warantee, you're gonna have to mail it in and pay us $300 or more to fix it."
    I've tried looking into replacements, but I can't seem to figure out where to get the housing from. I don't have pictures from inside the casing, but there seems to be a metal frame that holds the screen itself to the hinges, and the framing seems to have snapped in between the screen and the hinges, so I'm pretty sure that would need to be replaced as well.
  • Anonymous May 08, 2008
    I'm having the exact same problem. The sceen on the left side hindge is broken. I've contacted HP support and got the run around. Does anyone know who to contact at HP. This is a design flaw that they need to fix.
  • BenBarBlu May 15, 2008
    So glad I found this site, my notebook (Pavilion DV9260nr) has exactly the same problem with the hinge inside seeming to break and subsequently the cover splitting right down the side. HP customer service have already given me the run around but now that I have this (and a few other sites showing people with the same problem) I will not give up!!!
    Will let you know the outcome
  • Nicholas Laux Feb 25, 2009
    Stupid spam. The issue has been fixed. Spam links are unnecessary.
  • Anonymous Mar 02, 2009
    My Pavilion 5000 hing on the RIGHT side just broke. I can't close the laptop at all without causing the screen to split away from the frame. aarrgghhh ! I called HP and they offered to fix it for $298. They told me my laptop is out of warranty. It's just to years new !
    Any suggestions that don't cost $300 ??? My laptop is now considered a desk top because I can't travel with being unable to close it
    Problem Solver:
  • 9 Answers
I HAVE THE ANSWER!!!!!!!!!!!!!!!
I had the same problem with mine. HP is aware of the issue. All the PC's of this associated moddle have the same defect and HP will fix it with no cost to you. They will even send you a box to ship it in, even if you have no warenty! And to prove this is no hoax, I will perform a magic trick everyone! I will predict which henge it is. As you are facing the screen, it is the left! Oh, man! How did I know? you ask. How is this man so amazing?
Because the defect is only in the left henge. In fact when you call in your model number, the HP phone service actually says, "if you are calling about the left henge on your display, hang up and dial (866) 671-7362." You will notice this oddity if you dial HP support at (800) 474-6836 and say "technical support; computer; notebook PC; Pavilion" and your product model number. Real cute huh? If you look online, HP has put out a website with all the pc models affected by this defect and it is no small list. HP screwed up, but call the first number and have them check your model number and they are very nice about fixing your machine.
Posted on Jan 07, 2009
Although H-P will not admit it, they know all about the problem. As long as you aren't too far out of warranty, keep pestering them and they should fix it for free. They denied it the first time I contact them but when I showed knowledge of the problem the second time, the offered to fix it at no cost even though I was a couple of months out of warranty.
Go the to the following website if you want more information. In fact, refer the H-P to the website if they act like this isn't a design flaw.
http://www.notebookhingecrack.com/2008/04/02/notebook-hinge-repair-success-stories/
BMan
Posted on May 09, 2008
    President:
  • 778 Answers
Looks like a manufacturer's design flaw and HP should take care of this for you. Have you tried to contact their support and see if they have a recall/repair extension for this issue? Be persistent when dealing with their support as the saying goes "The squeaky wheel gets the grease".
FYI, it's not the screen itself that is split (at least that's what the picture shows) but just the housing/cover and you may find a replacement at an online auction site or other online source for DIY repair of yours if HP isn't any help?
Good luck
Posted on May 07, 2008
HP is finally fixing this problem for free, even if you are out of warranty. The problem is a design flaw with the left hinge that holds the LCD screen in place. It breaks in the lower left corner and then the screw receptors on the back cover that hold the front bezel in place come apart and everything splits apart. I have been fighting this problem for months, and finally got this info today from HP.
HP is offering a Limited Service Enhancement Program through
May 31, 2009 for the left display hinge on the HP Pavilion dv9000
notebook PC serial number that you registered. If you experience
a broken left display hinge before May 31, 2009 or previously paid
for a left display hinge repair, please refer to the HP website
at: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01611512
If you have not experienced a broken left display hinge, no action
is required on your part.
Sincerely,
Hewlett-Packard Company
Posted on Nov 25, 2008
    Problem Solver:
  • 10 Answers
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
Posted on Jul 23, 2010
I have the exact same problem and took it back to Best Buy Geek Squad. They sent it out for repair last week and I just received a phone call today. The technician told me that there is an HP recall and thus are fixing the problem for me for FREE!!
Posted on Aug 03, 2008
How do I fix or replace a broken Hinge on Dell 500 Laptop
The hinge rarely breaks, the fixings come loose and split the plastic case.
Disassemble the laptop to find out where your problem is,
DELL Vostro 500 PP29L SSD
If the plastic has broken off, I use epoxy resin to repair around the hinge or look on fleabay for a replacement hinge.
Dell Latitude D500 Laptop 14 1 034 Screen Hinges eBay
Feb 06, 2017 | Dell Computers & Internet
How do I remove the split screen from my laptop
To remove split screen: From the View tab in the menu bar at the top of screen, uncheck "Split View".
Dec 23, 2014 | Acer Aspire Computers & Internet
Find solution for display problem
It will be the cable for the screen i have had to do a few of these, the cable snaps on the hinge, you will need to replace this cable they dont cost to much. take the screws out of the back of the laptop and remove the key pad then the top cover, you will then see the cable /s unplug them and on the back unplug the wifi wires and remember what way they go, push them through the hole so they are on the top. undo the screws for the hinges and carefully remove the screen from the base. now you will need to take the rubbers off the . screen lid and undo the screws and split the cover seam, when it come apart you will see where the wire is and replace it, you will find a few of the wires on the cable have split. there are two types of cables one type is for if you have web came and other is for no web cam. you need the cable that is right for your screen. put back together in reverse and it should be fine put a bit of grease on the cable were the bend is in the cable around the hinge will help it no split so easy. hope this helps.
May 29, 2014 | Compaq Computers & Internet
White screen
Do you always shut down and unplug the laptop when not in use? Has it been cleaned recently? Fan, Vents, heatsink? Has there been ANY damage? It sounds like your Graphics Adapter. screen, Inverter, is going? Have to say exactly. Does the Laptop Overheat?
May 12, 2013 | Dell Inspiron 1545 Notebook
Split screen
Maybe your graphics card built inside the computer is operating at it's max. But if you are seeing a split screen, you either have a lcd screen problem or a video problem. Have you tried plugging an external monitor into the laptop to see if it gets the split screen?
Mar 31, 2012 | Dell Inspiron 1420 Laptop
My lg laptop screen seems to be split in 2 almost. It only shows three quarters of the screen and at the bottom the screen starts again
Try to turn off the pc and remove the cables and battery on the laptop. Press and hold the power button for 5 seconds, then reinsert the battery and the cables on the pc. Turn on your laptop and check if the screen will finally splits sucessfully...
May 15, 2010 | Computers & Internet
Dell inspiron 6000 screen splitting
This is a generic problem in most of Dell Laptops ( mostly inspiron ). It is caused due to a fatal fault or breakage in the Hinge Assembly. You need a new Hinge Assembly. Is it splitting more on decreasing the angle of the monitor. If yes, Hinge assembly is the only culprit. If you are under Warrenty then Dell will be liable for it and replace it free. If not under Warrenty, I approx. costs 300$. Thank you Sir, Have a nice day.
Sep 18, 2009 | Dell Inspiron 6000 Notebook
Laptop Screen Appeared Split Into Four Windows
that usualy happens when the screen has been replaced and it is not compatible with the laptop (is the screen blured too?)
can you see the same on an external screen?
Mar 02, 2009 | IBM ThinkPad A22m Notebook
Broken laptop screen HP Pavilion ZV6000
I have a HP Pavilion zv6000 laptop too, and I have the same problem. A year ago, the screen was getting loose and finally it just broke. Won't stand up. I've been propping it up against a wall for a year. I can see what is wrong: my laptop has gotten so hot that the back of the laptop where the hinges are has warped and ruined the hinges. Do you notice that? The split in the seem and the actual bend of the plastic? Anyway, the computer itself works perfectly. I was going to buy new hinges and replace them myself, but it was too much of a hassle, and I needed a new laptop anyway. The hinges are inexpensive. And the laptop isn't TOO difficult to take apart (search for the manual. it's easy to find). I took it apart with my Grandpa, and he's old, and I'm a girl. (okay, sexist, gender...ist.) I actually received a new laptop as a gift. Luckily. No solution, other than replacing hinges. I just wanted to let people know I too had the same problem.
Aug 13, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP Pavilion dv9000z Notebook Logo
4,126 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
