Question about Vacuums
The shower does not heat up the water but the power is there
  • 17,130 Answers
Possible failure of the heating coils inthe geyser. If there is power you will need to check the resistance of the heating coil to confirm if the heating coil is open.
there can be no other reason if the switch and power flows.
helpful?
Posted on Aug 29, 2010
Setting water in right temp,after couple minutes hot water goes off
makes for a quick shower eh . but back to the problem what does the hot water do say in the kitchen sink .
Mar 14, 2015 | Alsons Delta" Handheld Showerhead - White
Low power from steam mop
Try to be a little more vague! Model? Age of steamer? Rate of use?...Try a couple of drops of vinegar in with the water you use to fill your steam mop. The heating element that heats the water is probably oxidized, especially if you use tap water to fill it. You should only use distilled water in these mops. Some lower end steam mops have a handle that compresses, as you push the mop forward, which essentially makes the mop steam more, the more you "pump" the handle. Hope this helps!
Jan 29, 2015 | Vacuums
My steamer spits out water but not steam
It sounds like you may have mineral buildup in the system. You can try filling the water tank 2/3 with water and then filling it with white vinegar. Steam until the tank is empty. This should clean the buildup out of the machine.
By the way, Rather than just running the vinegar/water out, this solution is good for bathrooms, kitchens, sinks, showers, and windows.
Feb 26, 2011 | Scunci 900 Handheld Steam Vacuum
Shower works fine when cold but hotter it gets the less water flow there is
Sorry to read about your problem, I hope this helps you out.
if you have strong hot water pressure in the other parts of the house, you may have a clogged or defective shower control valve.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | Vacuums
I have a galaxy obsession deluxe 9.5 kw shower which will run for a little while but then trips the fuse, what could be causing this to happen?
your cable supplying power is not correctly sized for the shower causeing it to overheat and trip the fuse, or your main board fuse isnt matched to the power of the shower
Dec 19, 2010 | Galaxy Vacuums
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissel power wash pro heat
Look under neath there is a **** hole. It may be plugged
Feb 09, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Don't know how to use carpet shampooer
You should have the new aquamate, it has a blue top to fill with the water and water/soap solution that pops down into place. You will need to use your power nozzle hose and tube, connect it to your shampooer (make sure to connect the power connection just like the power nozzle). Fill your water up, large compartment is for cold water only and the smaller compartment is for one cap full of soap then the rest filled with cold water. Start with just a splash of water or an empty basin in the rainbow. The trigger will control your water spray and the brush underneath. There are two levers on the back of the shampooer marked with a shower head and a bar of soap. Use the soap with the shower head and the soap on and the water only with just the shower head on. You will want to also go over the area shampooed with both off to **** up the remaining water. Make sure to clean your floor thoroughly before shampooing.
Aug 13, 2009 | Rainbow E series Canister Wet/Dry Vacuum
My bissell pro heat 2X will not work, no water or solution comes out, what can I do?
I think the instructions should have the user rinse the solution passage with water. The soap probably clogged your spray nozzles. I had the same problem, I used a toothpick to poke to hole open again. The solution sprays only. I can't figure out why the water is not spraying out though.
Jan 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
94 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
