Question about Linksys Wireless-G WRT54G Router
USB adapter Hi - we have a WRT54G router on the main house computer, added our laptop with no problem but am trying to add another desktop with no luck. Boutght the Wirelss G Adapter on your advice - everything set up, transfered files, the Linksys icon is working, etc but I get so far & then it keeps saying to turn on the wrielsss radio in the computer. Can not find anything about that - it is Windows XP. Any sugestions? Do I need a better adapter? Thanks
  • glb919 May 08, 2008
    I am also adding a desktop (with Windows XP) to a network using a Linksys WRT54G router, but I haven't purchased an adapter yet. Can you recommend a compatible adapter for this router?
  • 70 Answers
You can try using the WZC (wireless zero configuration) utility instead of the linksys utility. Just right click the icon and select "use windows to configure my wireless settings".
You can also check for wireless interfence that could be blocking the connection of your wireless computer to the router. Try changing the channel of the router and make sure that the wireless settings are personalized.
If all those failed, you can try updating the driver on your wireless adapter and the router's firmware.
If you have any other problems, just click on ask me and ill answer it as soon as I can.
Posted on May 07, 2008
Added a linksys wusb100 adapter to my desktop and it has poor signal strength. The desktop is located on a floor above the router and the distance is about 20 feet. Laptops in the same area as the...
Check to make sure that you don't have any cordless phones in the area or ductwork directly below your computer between the adapter and the router.
Jan 18, 2011 | Linksys WUSB100 Wireless Adapter
My main computer has connection to internet but i cannot cnnect to my wireless computers in the house they can find netgear but windows will not let me connect microsoft said it was a problem with my...
at first see in the router wireless is enable or not then find the range of the router then in range you try to connect then you get it after then also not solve the re-installed the usb adapter driver in the laptop or desktop then try it
May 18, 2009 | Computers & Internet
No. The same adapter should work. If it is USB try moving it to a different USB port. If it is internal then try reinstalling the CD that came with it.
Jan 24, 2009 | Linksys Wireless-G WRT54G Router
My wireless has gone capoot.
Most desktop computers are not by default wifi capable (barring a few models that include an internal USB wifi adapter in the case.) If you have added wifi to the unit by installing an internal PCI-Card Wifi adapter or plugged in a USB Wifi adapter into one of your USB ports then that capability will be added. As far as a Keyboard command to activate the Wifi, that is usually dependent on the Computer and/or the brand and model of the adapter installed. What brand of Computer and model are you having problems with? If the Wifi was added after it was purchased, what brand and model of adapter are you using?
Jan 07, 2009 | Medion md40298 Notebook
Desktop won't connect with printer connected to laptop
Make sure both computers can share files and can ping each other, if not, it's just a firewall issue. Try to disable your firewall first.
Oct 23, 2008 | Linksys Wireless-G WRT54G Router
Cannot connect to WRT54g
think you have to connect a cable to the ethernet adapter of your desktop in order for you to connect to the wrt54g. uless you have a wireless lan on your desktop. also check your channels. and manually config your router through
Aug 31, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
Connecting WUSB100 to Wireless G WRT54G
laptops have a wide range reciever built around the screen and tend to be far better than a normal usb dongle.
The fact that your pc is downstairs will be effected a lot because the signals from the router will be bouncing around in an area around the antenna and above, signals below will be effected by floors, doors and wall partitions.
Your best solution would be to place the router on a phone line downstairs and see if the signal is increased.
Aug 18, 2008 | Linksys WUSB100 Wireless Adapter
Wireless router
hi frank its a new thing to have to go out and decide what router to purchase and install i use a linksys and have had good luck with the wireless connection quality . does his laptop have a wireless lan card installed most new laptops do have one but its worth a look to make shure it does. depending on how much you want to spend how far away does his laptop sit from location of router ? if not more than 10 ft go ahead and purchase a cheaper one 60.00 now if you want a better quality one go with the twin antenna linksys for about 130,00 and please make shure that he installs the security software that comes with the router and make a password and secure it for shure .i hope ive helped you decide on what router to purchase they all work fairley good .
as far as how they work they are all plug and play install the cd software first then follow instructions carefully and set up is 10 minutes away good luck by for now
Jul 03, 2008 | Linksys Wireless-G WRT54G Router
We have one router hooked to our main computer in one room, we have a lap top that is functioning perfectly through this router. We are having problems adding an additonal desktop to this router? What...
if you will connect the desktop hardwired or dierctly to the router, make sure that the ethernet adapter is properly installed and the ethernet cable is working.
if you will connect the desktop wirelessly, make sure that the wireless adapter is properly installed on the desktop and make sure that the wireless settings are properly configured.
May 06, 2008 | Linksys Wireless-G WRT54G Router
Networking question
Ok, you have several options. Go to a website such as Type in linksys and look of wireless access points, wireless usb adapters or a wireless desktop adapter. I would go with the third one.
Mar 30, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router Logo
71 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
