Question about Sony STR-DE835 Receiver
Sony STR-K740P goes into protect mode when turned on. I have nothing hooked uo to it. Its plugged in and thats it.
5 Suggested Answers
tns_davao
  • 32 Answers
SOURCE: my reciever sony str-k740p reads (protect) and it
Grounded speaker wire check your lines going to the speakers
Posted on Jul 10, 2009
SOURCE: Sony STR DB-930 Receiver jumping into protector mode
I went through the amp/receiver and used small star washers on all the grounding screws I could find including the one securing the transformer, cleaned dust off all circuit boards, checked output transistors and fuses, all OK.
Re Assembled unit and it worked OK.
I will buy a fan and fan it to avoid sourcing heatsinks for the previusly suggested IC's.
Thanks for the technical help, sure solved my problem.
Regards
Darryl.
Posted on Mar 13, 2008
  • 92 Answers
SOURCE: goes into protect mode..
you probly have speaker wires arching. unplug them and replug thm in making sure no bare wire is showing
Posted on May 20, 2009
SOURCE: Sony STR DE-725 going into ''protection'' mode
Audio Amplifier IC damaged
Posted on Aug 23, 2009
How do i reset a sony STR-K740P receiver??? - Sony Str-k740p Radio Receiver
Tuner reset
You can change the AM tuning scale to 9 KHz or 10 KHz. After tuning in any AM station turn off the receiver. Hold down the Preset tuning + and - ve together.
All preset stations will be erased when you change the tuning scale. To reset the scale to 10 kHz (or 9 kHz), repeat the procedure. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 12, 2016 | Sony Audio Players & Recorders
Str-de310 goes to protect mode with nothing hooked up to it except the power
Speaker positive and negative terminals are short circuited, carefully inspect the back speaker terminal if a small single strand of a wire causing this.
-SS
Oct 18, 2013 | Sony STR-DE310
My sony STR-DE695 flashes protect with nothing hooked up except the power supply. Is it a grounding problem, or something else?
if it is in protection mode with no speakers connected, then youve got an internal problem which will need repaired
Feb 23, 2010 | Sony STR-DE695 Receiver
When iturn on my Sony STR-DE325 it goes into protect mode
Try disconnecting all of your speakers, and then turn on you unit. If you have a defective speaker, or a short in your wires, your unit will go into protect mode. If your unit seems ok with the speakers disconnected, then turn unit off, hook up one of the speaker leads and try it. This way you can isolate the problem.......
Good Luck,
Eric
Jul 09, 2009 | Sony STR-DE325 Receiver
Sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
Mar 15, 2009 | Sony STR-DE935
Sony STR-D460Z receiver
A common cause are failures in the amplifier output stage, the drivers, and some of the support components. You will have to send the unit out for service.
Jerry G.
Feb 08, 2009 | Sony Audio Players & Recorders
Sony "Protection" mode - STR-DE725
My sony used to do that to umm cant remember the model but yeh i could play it at low volume but as soon as i turned it up it would start clicking and telling me to turn of the power...
I resolved it by checking every cord connected to it, it turned out that because I connected two speaker cables together i didnt seal it properly and they were touching this was making it go into protetion mode.
Nov 25, 2007 | Sony STR-DE725
Stuck in protect mode
Speakers shorted out, blew a fuse. Replace the unit or (cross your fingers and) open up the box and find the blown fuse.
Nov 23, 2007 | Sony STR-DE425 Receiver
Sony STR-DE835 Receiver Logo
1,202 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
