Question about Cisco Media Convergence Server 7835H-3000 (mcs-7835h-3.0-ipc1) Voice / Video / Data Server
I recently bought a cisco MCS 7835H-3.0 Server off ebay minus the hard drives. I cannot find any kind of spec sheets or anything that specifies the type of hard drives needed to get it operational. I believe they are scsi ultra320. But I just need verification. If I buy a 146gb 10k scsi ultra320 hdd, would it work with this server? Thanks a lot.
  • 10,319 Answers
Refer to the links below
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_end-of-life_notice0900aecd801c09b5.html
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
Posted on Aug 29, 2010
Where can i get 2 onboard Broadcom NetXtreme 10/100/1000 for IBM server
Variety of places, depending where in the world you are, and the MPN of the part you want I guess.
Ebay,
BrokerBin,
Local IT Supplier,
Discount Cisco,
ComTek,
IWantTheBestDeal,
Jan 09, 2012 | Cisco MCS 7816-I4 Media Convergence Server...
Hi i forgot the password how to recover it
You can reassign the administrator on this server by following the instructions here:
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/products_tech_note09186a00801d6e61.shtml
This page tells you how to reset the password.
Please rate my answer.
Many thanks,
Chris
Mar 05, 2011 | Cisco IPCC Express (MCS-7835I-3.0-CC1)...
What is cisco cobo
Cisco cobo is ment for small businesses its a Network attached storage server running a small linux operating system. There are different sizes of hard drives and in most cases more drives can be added.
basically its the same as a USB hard drive, but its connected to a network and all computers in that network can access the files on it.
Nov 30, 2010 | Cisco COBO SMALL BUSINESS NSS3000 NAS 1TB...
Good day! How Cisco 7911G IP Phone can connect to the Call manager Cisco 7912G IP Phone?
You must have a valid functional callmanager. You then set option 150 in your DHCP which specifies the IP address of the TFTP server which is ultimately callmanager.
Nov 04, 2010 | Cisco 7912G IP Phone
How to reset password of pix 506e
You only need a PC and a serial terminal. First of all you need to know the PIX software version you run. After that you must go to Cisco web page and get from there the utility for the password recovery corresponding to your version of software.
After that you must connect to the PIX console port. Press ESC key after the PIX is booting and a special prompt it will appear (monitor>). Issue the "interface" command to specify which interface to be active. Inside interface it will be the default one. Then use the command "address" to go with the IP address of the above interface. After that, you will need also an TFTP server where you must upload the software utility specified in the beginning of the solution (the one downloaded fron Cisco). After the "address" command, issue an "server" command to put the IP address of the TFTP server. Than, use the command "file example.bin", where the example.bin is the file downloaded from Cisco. Maybe you will need also to specify the gateway of your network. This you can accomplish by using the "gateway" command. Finally, use the "tftp" command to start the download.
The default Telnet password after this process is "cisco."Go into configuration mode and issue the passwd your_password command to change your Telnet password.
Best regards,
T
Apr 24, 2009 | Cisco Computers & Internet
Could not detect ATA drive
Get into the bios/setup of the server (hit either of f2 or f10 or del keys during start up) and somewhere you should have an option to set the ATA/SATA hd to legacy mode, that should do it.
Regards
Mar 13, 2009 | Cisco MCS-7825I1 (MCS7825H1ECS1) Server
Hard Drive
u have to boot xp on it with your cds set bios to cd 1st then put xp cd in it ask hit any key to boot in ten formattt new hard drive make partions ect then install xp ok
Jan 23, 2008 | HP nx9110 Notebook
My operating system will not load
Try removing all of the hdds or just leave one that you think it works. See what happens.
Nov 07, 2007 | Dell PowerEdge 2500 Server
Open Questions:
See all Cisco Media Convergence Server 7835H-3000 Questions
Cisco Media Convergence Server 7835H-3000 (mcs-7835h-3.0-ipc1) Voice / Video / Data Server Logo
129 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
