Have a 37 inch flat screen LCD TV 1 year old last december. Watched this morning and was fine . In afternoon came home and sound only would work. Called sat provider and they checked everything it was ok. TV has a built in dvd player no picture either. Please help!!!!!!
  • 2,712 Answers
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try plugging in the TV through the USB on its panel to a computer or USB charger, and it may work. However, this is only a temporary solution.
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
4. A circuit board may crack about some of the larger components mounted on it. You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first.
5. If you want to go in for a long term solution, you can easily replace the whole power board or just change the faulty capacitors. You will have to open the back panel and take a look. You can make out which are faulty, because their caps will be swollen on top. Here's a sample pic (not same model):
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows how to do this kinda stuff do it for you, or get a qualified technician. Warning: If you do not have a background in electronics repair, or are inexperienced, get a qualified technician to do it for you.
REMEMBER there are very dangerous voltages inside a TV that can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECT THE POWER BEFORE YOU DO ANYTHING.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
Posted on May 07, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
Sanyo hdtv lcd flat screen--no picture and no sound
first just for trying--unplug set for a few minutes and plug it back to see if it resets.
If not someone will have to open set and check voltages on Power board to see if there or not.
There is another issue common if set 1-2 years old but that is the set at first has to be turned on several times to get it on--let me know if you had that one and I will still advise you.
Mar 19, 2012 | Sanyo Televison & Video
No picutre just black-loud pop when I turned it on
You may have blown parts, look inside and inspect the power supply module and the back light inverter board, I will leave the TV unplugged.
Please see my basic troubleshooting guide:
Parts: try or Ebay
Jun 25, 2010 | Samsung LE37B550A5 37 in. HD-Ready LCD TV
Tv repair
I soudcs like the backlight inverter board is bad or the power supply is npt supplying 24vdc to the inverter board.
Oct 31, 2009 | Olevia LT37HVS 37 in. LCD HDTV
I have a 37 inc LG LCD TV. While watching it the TV made a loud pop noise and the screen went black. We lost both the screen and sound. Tried it again this morning and after 2 minutes the same thing...
you have blown an internal fuse you might be suprized to learn that ther is someone veryclose to you who might be able to fix it a lot of people who fix tv's work from home bassically you just neeed ot repalce a small circut board inside it
just google and try to find them
take tc back it should sill be under warenty if they refuse you can say t othem this is not fit for its purpose and force them to fix or replace it
Sep 19, 2009 | LG 37LC7D 37 in. LCD HDTV
No power at all
Check the power cord, then socket and then fuse in the socket (if there is any) and in the TV, power surge can´t be ruled out.
Jul 08, 2009 | Televison & Video
I have a 32 in lcd ilo tv that want come on.
Yes I have the solution, I watched my 32 inch ILO tv and turned it off went to bed and when I got up the next morning it would not come on. So I got out my receipt, called Wal-Mart they would not offer me any help I had purchased this T.V. in December of 2007, since this is January 09 it was just by days past the year mark and Wal-Mart also informed me that they no longer carry this brand due to this problem, I called the company but they more or less laughed and said that it sounds like your going to have to pay a repair bill or purchase a new T.V. So I am a single mother with no extra money,especially 1 month after christmas. There is a fuse on the T.V in plain view, when you slip off the back of the T.V.on the right side, it costed me a hole $2.50 to purchase at my local auto parts store, works like a new one. The fuse was burt black, so this was a cheap and simple solution. Also Beware this rep from ILO also told me that there company makes Manavox, and Zennith so if there making them beware!!!!!!!!!
Jan 08, 2009 | iLO 3200 32 in. LCD Television
Sound but no picture
check with a flashlight against the screen for picture, if present backlight inverter has failed.
Dec 07, 2008 | iLO 3200 32 in. LCD Television
JVC i art 32" flat screen
Does anyone know where can I buy a screen for a 27" LCD Insignia TV. Model is NS-27LCD? My screen creaked. I checked out e-bay and have not found a broken TV with a good screen. Does anyone know where I can buy a screen at.
Thank you all for you time.
Jul 22, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
