Question about LG Televison & Video
I used LG 29FS4RLX, my screen got shrink in the middle and the picture small a bit. Colour was little blurring. Please how to solve this, going to repair shop, need to change board, it is true?
Coldcut
  • 1554 Answers
SOURCE: Philips LCD model 26TA1000, vertical lines and blank white screen with no picture
it would be easier to find it stripped from a damaged set on ebay.
I see several there but need the part number to search
of course you may purchase that and find it to be the lcd driver.hopefully not.
Posted on Feb 18, 2008
rulds2008
  • 3866 Answers
SOURCE: I have a Samsung SP-S4223 42in. EDTV.
This is called tiling and this happends because of a weak signal from whatever device you have hooked to it weather it be cable or a sat dish. Try checking and makie sure you have good signal to this. If this matter gets wrose then you would need a repairman. Thanks
Posted on May 24, 2009
  • 109 Answers
SOURCE: i have a 42
you have to buy the main board check at
www.shopjimmy.com
Posted on Aug 25, 2009
promo7uk
  • 19 Answers
SOURCE: screen problem with my LG 50" Plasma TV
its the buffer driver board the big long board that plugs into your tv,, i have one for sale if u need one,,30£..promo7uk2@hotmail.com
free+p+p
this will cause the lines on your tv after replacing the ysus it could well be that ysus mabe faulty still if u replace buffer and find u still have the lines 9/10 times when the ysus goes it normally takes out the buffer board on these worst cases the control board,, but im 98% shure its buffer board.. let me know on here if u find out.
Posted on Jun 26, 2010
budmrtn
  • 11361 Answers
SOURCE: my lg 42px3rv had no
Download LG training manuals here. it may help you narrow down the problem, they suggest to replace both Y and Z boards at th same time.
Try study the manuals:
http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=TRAINING&kategoria=tv&kat2=all
Posted on Dec 23, 2010
Our lg tv no picture is coming on screen, just sound we can listen, in the middle of tv screen a small light is coming lika a tube light. what is the correct problem & how to solve
Hi sathiavl,
If in the middle of tv screen a small light is coming lika a tube light, i'm afraid that broken panel. ( like hit by hard material). You must replace panel, but that very expensive. Or, that problem may because t-con, Open rear cover and you will see pcb t-con which attached on panel.
Clean connection between pcb main and t-con first, than turn it on.
if still problem , replace t-con board can solve your problem.
Mar 29, 2011 | LG Televison & Video
Shrinking screen
check the user manual also can be misconfigured or check the source voltages and convergence
Sep 09, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Dark horizontal bands appear on projection
Your matrix is failing. If the unit is under warranty, send it back.
The matrix is the bit that allows light to come through of each colour. If its failing one colour won't get through. If the circuitry is failing, more than one colour wont get through.
Jul 12, 2009 | LG LP XG2 Multimedia Projector
Images blurred on toshiba satellite laptop pictures from the internet are blurred and boken into picilated squares or just blury like water is washing over ...
Its either one of two of these problems,1 select control panel,then control panel home,then adjust screen resolution, then pump up the resolution to max and make sure the colour field is at 32 bit and apply these changes........2 is that LCD display is busted for sure.
Jan 09, 2009 | Toshiba Satellite P100 Notebook
Taking pictures with a Samsung digimax A502 and the screen is blurred, the picture seems to have a "swirling" colour effect - also there is a black mark in the middle of the screen
Hello!!!
Try hard resetting once!!! Switch off ur camera , remove the batteries and press the power button for few seconds. then put the batteries back and try powering on!!
Nov 04, 2008 | Cameras
Picture blur display
If the picture shrinks and expands you can get a repair kit from www.tvrepairkits.com.
If the screen is just foggy looking my guess is the CRT fluid needs to be replaced.
Oct 19, 2008 | Philips 9P5034C 50" Rear Projection...
The shrinked screen with two white vertical line in the middle
B+ line going hi.
probably bad capacitor on hot's collector.
could also be leaky dual diode.
if non of above, look for swollen cap on main board.
Jul 12, 2008 | LG Studioworks 700S 17" CRT Monitor
Blurred picture
Have you tried lowering the Screen Resolution and Screen Refresh Rate of the PC in its Display Properties?
It could be that you PC's current settings are way above what the Samsung can handle.
Good luck and kind regards.
Thank you for using FixYa
Mar 22, 2008 | Samsung 793S 17" CRT Monitor
Televison & Video Logo
Computer Repairing
Computer Repairing
