Question about Transcend StoreJet 320 GB USB 20 Hard Drive
I got my external hard drive dropped..wen i used it again, files contain in it cant b open..the hard drive has a loud ticking sound on its spinner..whats d problem with this..tanx
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
Dropped my Transcend Storejet25p 5oo gb on floor !
Your hard drive is damaged beyond repair.
When a hard disk makes a clicking sound and the computer does not detect it then the hard disk is faulty. This is commonly known as "The click of death".
There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.
Oct 18, 2012 | Transcend StoreJet Computers & Internet
Fix syntax error external hard drive
It's likely the drive is failing. For remote data recovery or do-it-yourself data recovery see http://freedatarecovery.us
Sep 04, 2012 | Western Digital Computers & Internet
Why i cant copy files to hdd external (pqi h567v)?
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now
click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or
you might tick one box then return after its finished the first repair then return and tick the second box
you should not do anything while the chkdsk utility is in progress any input may damage this drive
hope this helps
Aug 29, 2012 | PQI 2.5" Portable External 750g Hard Drive...
How can I recover my files after I drop my external hard drive?
First of all - STOP using your WD drive immediately! If you continue using the disk drive, you significantly increase the risk that the files you want to recover will be lost forever due to overwritten. Every new file or action will take up more "free space" and reduce your chances of retrieving your deleted files from WD. So really, you need to act quickly.
The next step - get a good HDD data recovery software to retrieve the data as most as possible.
Learn more from: http://www.western-digital-data-recovery.com/
Jun 22, 2012 | Western Digital My Book Essential 1TB...
I have a toshiba 500GB portable external hardrive....it still has 50GB more space left...however when i tried to open it...it wont open and i cant see my files...the computer says that it cannot fix the...
You can recover data from portable hard drive with data recovery software.Tenorshare data recovery is one of the bests. It can recover data after deeply scanning your hard drive to look for lost data due to drives crash, physical damage,bad section, virus attack etc.Download it and scan your external hard drive for free to preview whether your files can be recovered.You can get it here: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm After you recover your data,you can format it to check out whether it can be fixed.
Jul 10, 2011 | Toshiba 640GB USB 20 Rocket Red Portable...
Hi i have a a portable WD BAAA5000ABK-00 500 gb hard drive, i dropped it a while ago , and when i connect it to my laptop it spins for like 10 seconds and i hear a ticking sound,then it stops spinnig, i...
You could purchase another identical external disk-drive, and "transplant" your "old" disk-drive into the new case, to see if you can read from the "old" disk while inside the "new" casing.
If not, then re-insert the "new" disk-drive into the "new" casing, and use the "new" external disk-drive as a 'BACKUP' for your files (not to hold the ONLY copy of your files).
Jun 01, 2011 | Computers & Internet
I have a cavalry CAUE37500 500GB 2.0 that I have literally used less than 50 times since I bought it a few years ago. I haven't used it for the last 6 months, but thought it was a good time to delete...
> ticking of a watch ...
A typical sound from a disk-drive that has malfunctioned.
If it still has a valid WARRANTY, exercise the warranty to get it repaired/replaced.
If the warranty has expired, then open the case, remove the disk-drive, buy a new "compatible" disk-drive, connect it, and thus "revive" your external storage device.
Oct 23, 2010 | Cavalry Storage Cavalry 500GB 3.5 7200RPM...
Drive sounds like tick tick and not mounting
Hi, If you have warranty remaining then you can definately replace it but if not then you'll have to search for some Hard disk repair stores & there u can ask for the data backup too.
Regards
kunal
Jul 14, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Ext WD500GB drive not being recognised by my computer,but seen in device manager
try downloading this and and scan may be it might locate yr drive since windows can still see it in device manager. and with these u can recover even deleted and formated files. try it
http://services.seagate.com its trial version so u can get a full version n pay little or find similar software but i know yr drive can still work fine its just that we r missing something here.
thank u
May 27, 2008 | Computers & Internet
Transcend StoreJet 320 GB USB 20 Hard Drive Logo
87 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
