Question about Dishwashers
The dish washer approximitly two years old now top of door control panel is dead
  • Anonymous Mar 31, 2009
    Any answers on what is happening?
    Genius:
  • 1,073 Answers
What is the model of the dishwasher
Posted on May 08, 2008
I have a loose door handle .what tools do I need and how do I repair it?
Hello;
My name is Peter. I am a retired field service appliance technician.
This is a difficult question to answer because you did not provide a model number. When you open the dish washer door you will see a metal label. Your model number is on this label.
Generally, manufactures use a special screw called a torque screw. The head of the screw looks like a star. It may be a different head screw.
Dish washer door handles are made of plastic. It is not uncommon for the handle housing, the handle or the retention spring to break.
On some dish washers you have to remove the inside door panel to access the handle assembly and on others there is a cover plate for the dishwasher control panel at the top of the inside of the door.
Before you attempt this task - do not go blind. Give me your model number.
Apr 03, 2015 | Dishwashers
Dishwasher will not start. All option buttons light up except the Start/Stop button and the cancel button. I have turn the power off and on but still no wash cycle. Inside float is clear and so is spray...
Hello, I am sorry that your dish washer isn't working. One of the biggest problems with these new dishwasher is they install the control on top of the door and the operational circuit board below the control panel. Inside the door is acceptable to moisture which creates all kinds of problems. It not the spray arm or the float, or the pump. it is where they put the circuitry to control the dish washing machine.
I hoping that all you will need is a push button control strip for this dish washer. moisture get in the micro switches and make them inoperable. These button in the control strip are hermetically sealed against moisture....for a while.
Remember, it depends on how long has the dishwasher been working and what will be the cost to repair your dishwasher. Dishwasher are really good for 10 to 12 years of service. I worked on a Kenmore that was 25 years old. I told the lady of the house it is time for a new dishwasher. I could have repaired it, but really it not worth it when it is this old. GB...stewbison
Sep 06, 2011 | Maytag Dishwasher
Pump running continuously, Yes there was a drain pack, have emptied water, float switch clicks when moved with screw driver. Only one red light shows ( last cycle - pots ) what else can I do... James
What type of dishwasher do you have? Has your kitchen floor flooded? If it has. The tray under dish washer isn't water tight. Moisture creates some unusual problems. Some of newer dish washer the there control panel under the top of door this also create problem especially if the switches are on the top of the door. Another moisture problem. I have repaired a new Electrolux dish was three times in less than 6 months. The floor would flood from the Maytag side load washing machine. The Madam of the house didn't tell me that the washing machine flooded the kitchen floor. No window in the door and sometime fill water solenoid would stick and fill the tube. When they open washing machine door, 12 gallons of water would spill. So I fix both of them. GB...stewbison
Aug 21, 2011 | Asko Dishwashers
Dishes are not drying
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jul 12, 2010 | Electrolux 23 in. ESL6114 Built-in...
My washer went on control lock and now it wont turn on i tried to unplug it but nothing works
Would plug something else into outlet to make sure your power supply is ok. If you remove bottom panel in front(three screws) or top panel(three screws in back and slide panel back slightly to raise off) there should be a tech sheet with some suggestions. If it is less than a year old call for warranty service. Keep kids away with panels off. If unit is completely dead a guess would be main control board on top, but that is just a guess.......
Jan 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We own a Jenn-Air JDB7900. This morning the
More then likely the washer control panel has failed.
Apr 24, 2017 | Jenn-Air 24 in. JDB7900 Built-in...
My washer is only a year old and it will not turn on...it is locked and i can not get it open????
If it is electronically controlled, you probably need a new electronic control or a new door latch. If it is under a year old it should still be under warranty.
Jan 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Top loading washer door locked
check the panel for triped breakers - check the plug for the washer - the door latch usually release itself after fewhe latch minutes- if nothing works try to force lid open with a thin screwdriver from the side were the door latch is
Sep 14, 2008 | Kenmore 24032\24036 Top Load Washer
Dishwasher Heating element not working
rclay How old is your dish washer? It has up to five years limited (parts only) warranty on the electronic control. If it is within this period of time, then you can call Maytag and they will send you a new part. If you are not sure how old is it, you can find it with Maytag by the model and the serial numbers (on the door frame). The warranty for your dish washer you can get here: http://www.maytag.com/cust_serv/pdf_use_care_manual/6_915728.pdf Gendos...post back
Jan 31, 2007 | Maytag MDB9100A Dishwasher
Dishwashers Logo
Top Dishwashers Experts
