Question about Husqvarna Sewing Machines
How to know if thread is too tight, starts to sew then stops and hard to get out of bottom holder
  • mccartan0332 Aug 30, 2010
    just that was great
    can i ask another question. I am a senior never used a machine in my life, but am really trying to get this going properly if possible. Pls. let me know, I would appreciate it.
  • 4,924 Answers
To see of the bottom thread is too tide..just get the under bobbin out with the holder...and put the thread into the position into that location by that cover blade...and pull on the string ...and feel the tension ...It do not have to be too tide or to break the thread when you pull it ..
Too loose it up a little ...unscrew the side screw..that keeps the cover blade ...
After that insert it in place..and pull the thread out by rotating the wheel one time ...when both threads are in place ...pull by hand each one at the time ...and they have to feel like they have the same tension ...If any of them is too tide...for example the bottom on e...the stitch will end up with a tensioned bottom thread...and with little loops of the upper thread sticking out on the back side..It is very visible ...and in normal conditions you do not have to see the upper thread on the back side..or other way around..
My advise is to loose them both ...a little ...and when you have them into position and pull them by hand ..they have to feel even in tension ..and the stitch to not have visible upper thread on the back side..and the other way around ..bottom thread visible on the upper side of the stitch ..
so ..to loose them ...the upper thread has the wheel button o the arm ...and the bottom thread from that side screw that holds the blade under which the thread is put ...
Posted on Aug 29, 2010
Bernina 1008 thread tension is way too tight
Remember to raise the presser foot before you begin the upper threading process. May not be the problem, but you might try changing the needle and the type of thread you are using. Good luck with getting it fixed. Going back to the service provider is probably the best bet. You already paid for the service and they didn't fix the issue. Be sure to bring them a sample of how it is (mis)sewing.
I also pull the bobbin thread to the top of the fabric and gently hold both threads behind the presser foot until the machine completes the first stitch. That helps prevent the "thread nest" that is frequently created under your fabric. This is a procedure that is taught by Bernina instructors, and it does work.
Jun 23, 2015 | Bernina 1008
Buttonhole
The needle thread breaks
1. The needle thread is not threaded properly
2. The needle thread tension is too tight
3.the needle is bent or blunt
4. The needle is incorrectly inserted into the needle holder
5. The needle thread and the bobbin thread are not set under the presser foot when starting sewing
6. The threads were not drawn to the rear after sewing
7. The thread is either too heavy or too fine for the needle
Bobbin thread breaks
1. The bobbin thread is not threaded properly in the bobbin holder
2. Lint has collected in the bobbin holder
3. The bobbin is damaged and doesn't turn smoothly
Mar 13, 2015 | Sewing Machines
My minghui is sawing just top and bottom is just mess can u help me???
Thanks for the question.
If your machine is not sewing on the bottom or making stacks of thread called (bird nesting) there are several simple fixes for this and some not so simple.
First you need to make sure that you are threading the bobbin into the holder correctly, Insure that you pull the end of the thread through the little slit on the side of the bobbin and that the thread is somewhat snug but not hard to pull.
Once you have done this replace the bobbin in the bobbin holder and thread the feed thread over the top from the spool or thread. making sure that you run it through the auto tensioner.
Set the auto thread tension to +1 to start, go ahead and thread the main feed through the bobbin feed so that you have both strings on the sewing deck.
Now with a piece of used material, pull both bobbin feed and Main thread behind the machine, insert your test material, drop the material tension foot onto material and start to sew a 1 inch spot.
After about one inch check to see if your machine is still nesting thread, if it is you need to add more tention to the main thread by moving the auto tensioner to +2. Now test sew again a short distance and recheck. If you still have a issue move the tension up until the nesting of string stops.
If you reach the stop. than it\'s likely that the bobbin holder needs to be adjusted.
The bobbin holder has two small screws in it generally that allow a very small screwdriver to adjust the bi metal pensioner on the bobbin holder. This is the area where you slide the string through the little slot in the bobbin holder.
You can tighten those screws until the string is harder to pull out of the bobbin holder. You may have to repeat this step several times until you get the tensions just right.
but make sure that you reset the main Thread tension to 0 before you start adjusting the bobbin tension.
If after all this work fails you may have to replace the bobbin holder to correct this issue.
There is one other fix that you can try before replacing the bobbin holder and that is to purchase more expensive thread. The reason behind this is that the more expensive thread is thicker and causes more friction in the bobbin holder..
I hope that this has helped you, I know what it\'s like not to have a working sewing machine.
Best of luck and thanks for using Fixya.com
Oct 16, 2013 | Sewing Machines
LOWER BOBBIN BINDING UP
Readjust the needle timing and check the thread tensions top and bottom.
Jun 09, 2013 | Kenmore Sewing Machines
Thread breaking
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Aug 13, 2012 | Janome Sewing Machines
Need to know how to properly thread , the problem is once we start to sew it moves a little then stops thread tangles on bobbin and breaks from top. we try different ways of threading
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out. This might not be exactly the same as yours but should give you an idea of the position.
Mar 08, 2011 | Euro-Pro 473
When im sewing my bottom stitch looks good but my top stitch is real loose and sometimes my bottom thread gets pulled up. i have played with the tension but dont help
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 24, 2011 | Brother CS-6000
I am having problems with my bobbin. Every time I load it and start to sew it gets jammed and the needle stops. There is a mess of thread around the bobbin.
Feb 24, 2011 | White Sewing 2037 Mechanical Sewing...
I have two problems the first is that as i sew sometimes the fabric on the back side gets stuck and there are many pieces of thread coming up from the bobbin and get stuck the second question is everytime...
Feb 22, 2011 | Necchi 6011
Multiple threads are coming out of the bottom from the bobbin and stopping the needle.
Feb 21, 2011 | Husqvarna Husky 165
Sewing Machines Logo
81 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
