Question about Toshiba Satellite A45-S150 Notebook
Can my Toshiba Satellite A-45-S-150 support RAM chips with different densities (1/1Gb and 1/256kb)?
  • Toshiba Master
  • 6,487 Answers
Yes you can use here a RAM with different size like 1 GB and 1 256MB of RAM your system will just add up the total of the RAM that you have on it.
Posted on Aug 29, 2010
Add ram Satellite u845
Power down your Toshiba Satellite.
Unplug it from the wall.
Turn the machine over and remove the battery.
Locate the RAM compartment cover, which is usually located somewhere in the middle of the underside, and is about 4-by-4 inches.
Unscrew the RAM cover screw with a Phillips screwdriver and set aside.
Ground yourself by touching a metal object.
This will release any static electricity built up in your body, which can harm computer chips and components.
You can also use an anti-static wristband while you are working.
Remove RAM modules if needed.
This is most likely if you are upgrading the present RAM capacity with a larger RAM chip.
Press your fingers on the clips on either side of the chip to pop it out of the socket.
Pull the chip out of the RAM compartment, holding it by the sides of the circuit board rather than on the chip.
Insert the new RAM module into the socket. Align the RAM module so that the notch lines up with the tab on the side of the socket.
Gently lower the module into the socket. Press into place with your fingers.
Replace the RAM compartment cover. Insert the screw and tighten.
Replace the battery and secure with the lock.
Plug the Toshiba Satellite laptop back in and power up the system.
The upgraded RAM should be automatically recognized.
hope this helps
HOW TO INSTALL MEMORY UPGRADE TOSHIBA SATELLITE LAPTOP
not sure if this is the right laptop
http://www.youtube.com/watch?v=RdCzsjDp_lc
Oct 12, 2012 | Toshiba Satellite U845-S402 14" Notebook...
Will this model accept windows Vista?
Yes and No. In order to accept Windows Vista you would have to make sure you have sufficient RAM memory. These older Win XP based laptops usually only have 256KB or maybe 512KB of RAM memory. Vista needs 512K minimum, but you should relay max out the Toshiba to 1MB of RAM for Vista to run smoothly. You would also have to try to find all the proper device drivers for Vista, and Toshiba has not provided them for this model laptop. You may find that some device drivers just are not available for Vista, I could not find a Vista video driver for it.This will impact performance. The bottom line, is that you can surely put Vista on this laptop but it will probably not run as efficiently and as fast as Win XP.
Sep 05, 2011 | Toshiba Satellite A15-S129 Notebook
I added 2GB of memory on a A55-S1063 satellite and all it does is beep a few time and not start up.
Check the Bus Speed of that 2GB RAM chip (333,3356 etc) it must match the other RAM Chip otherwise remove it and put 2 chips of 1 GB each.
Dec 29, 2010 | Toshiba Satellite A55-S1063 Notebook
Cant find ram chips in a Toshiba Satellite A45-S151
The memory is under the keyboard on this laptop. You should be able to pry up the keyboard with a small screwdriver between the keyboard bezel and the keyboard itself.
Be very careful not to break the wires connecting the keyboard to the internals of the computer.
I hope this helps.
Feb 22, 2010 | Toshiba Satellite A45-S151 Notebook
Toshiba Satellite 1005-S157 shuts down periodically by itself. Replaced fan/heatsink. Still shuts off.
you need to check a few things... when the fan/heatsink assembly were replaced, did you make sure that the thermal pads on the CPU and GPU are NEW/Good.... Make sure that the Heatsink GPU pad Firmly sits in the chip....
You can test the thermal controller by using a hair dryer or heat gun.... Point it onto the heatsink pipes and see if your fan spins when the pipes get hot, then remove and see if the fans slow after a minute...
You might have faulty RAM or Misseated RAM... Pull The RAM chips and reseat them...
Also Make Sure Your CPU Is Locked Down....
Periodic Shut Downs Can Be Caused By Quite A Few Different Things...
Typically it's due to Thermal Damage
Though Failing RAM or A Failing Hard Drive, Overheated Video/GPU Chip, Or Even Failing CPU can as Well Cause This Issue...
Nov 16, 2009 | Toshiba Satellite 1005-S157 Notebook
Planning to upgrade my RAM(motherboard K7SOM + V7.5C). Ram have high & low density. What is the difference? Which suit my motherboard? Thanks.
Look at the sticks of RAM -- "high" density means fewer chips on each side of the stick, i.e., newer technology and production methods have packed more bits into each chip, while "low" density usually means 8 chips/side, using older RAM chips.
Older motherboards do not expect to find "high" density RAM, and typically will only detect 1/4 or 1/2 of the RAM on the stick.
If you buy a new motherboard, it will support BOTH densities.
Oct 22, 2009 | EliteGroup K7SOM (K7SOM W/CPU) Motherboard
Memory upgrade not working
check front side bus for new ram & old ram ,sometimes if both are working on differant f.s.b. then also this can be happen
Mar 15, 2009 | Toshiba Satellite A135-S4527 Notebook
My laptop has 256K memory installed. I purchased 512 RAM (max I can add is 1024) and installed it in my hp Pavilion zt1230 laptop. Per Kahlon.com instructions, I cleaned gold leads with eraser and popped...
Is it a High Density memory? There are two different types of memory, High and Low. Low density is the universal but High density, may be cheaper but the motherboard needs to be compatible with High density memory. Although your memory fits in the slot, I think you have High density memory hence why it won't boot up and does when you remove the memory.
Dec 06, 2008 | Computers & Internet
New RAM for Satellite 1400 won't work
Hi this problem has arisen on both desktops as well as laptops, the reason for it is quite simple. a lot of the RAM available on the market now is HIGH DENSITY RAM and unless your satellite is specificaly designed to run high density RAM it will not recognize it.
You will find all the major RAM brands are low density and will work fine. A brand like Kingston is an ideal option.
Regards mistyman
Aug 14, 2008 | Toshiba Satellite 1400-S151 Notebook
Toshiba Satellite A45-S150 Notebook Logo
43 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
