Question about Motorola Mobility RAZR V3
My Motorola Battery Refuses to Charge!!
This morning I realized my phone didn't charge overnight.
When it finally died, I tired to charge it, but it refuses to charge.
For some reason, the keypad light keeps turning on as if it's going to charge, but then turns off after a brief 2 seconds.
My phone won't even charge with the USB cord like it always does.
It can't be the battery getting old because it is a relatively new, barely used battery. What could the problem be? I need help...fast!
  • fastglanza May 07, 2008
    i have the same problem as you..need help asap
    Problem Solver:
  • 18 Answers
You may have a damaged battery contact, my suggestion is to get it serviced
Posted on May 07, 2008
O plz help me with motorola v3i charging
Run the phone till the battery dies, remove battery for at least 5 mins. Replace battery, charge overnight with phone turned off
Nov 26, 2009 | Motorola Mobility RAZR V3i Cellular Phone
My cell phone died and now it wont charge!!!! :'(
It won't turn on because battery is too low. Another benefit of lithium ion batteries. When they are depleted, the internal controller / charge circuitry on battery disables it.
You didn't mention what kind of phone other than Motorola. If it has a USB connector to charge through, make sure that you are using a motorola approved charger. There is a way to make the USB connectors (charger side) indicate a particular class and rating. If this doesn't match what the phone expects, then you will likely get a Cannot Charge message or similar.
That being said, this usually only happens with AC wall chargers. I have yet to see it happen with a vehicle charger, though I don't rule it out.
Aug 25, 2009 | Motorola Cell Phones
Battery going flat early even after charging
sounds like its either the battery is bad or its a defective phone very popular for the v3 razors
Jul 06, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Phone line gets glitched and phone gives one very short ring with error message on readout.
phones not working people are trying to call they tell me there getting a busy signal and cant get through me. I have three motorola E51 cordless phones and they are showing parallel set on the lcd screen how can i get my phones back working
Nov 18, 2008 | Motorola Mobility E51 MD7151-3 Trio...
Won't charge or turn on
maybe the problem was your battery, i just think that youve overcharged it. try to replace another battery. hope that helps!
CHARCOIS
dont forget to rate my post thanks!
Jul 27, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Motorola v710 cell phone
Is the battery lithium -ion? If not, you have an older generation of battery.
Having mentioned that, some batteries need an introductory "conditioning period". Continue your excercise of charging and draining (dont drain too too low) and hopefully you will start seeing some decent longer lasting charges.
Hope that helps!
Feb 08, 2008 | Sony Ericsson W200i Cellular Phone
Wont charge or is locked
if you plug the charger in and you can see the battery bars going up and down then it is phone problem if the scrren is blank then it is either the charger but if you have a car charger aswell and both chargers worked before then it is probably the phone that has a problem check where the charger plugs in that their is nothing blocking the terminals like fluff or bit of paper check that none of the terminals are bent or coroded if you have used phone in rain they might have got coroded this can be solved by cleaning the terminals on the charging part of the phone but be carefull when you do this not to wreck any thing check the charger make sure nothing bent or blocking the charge the problem with these phone is the pins on the bottom where the charger plugs in these get damaged really easily and they can be replaced but will have to take to phone shop and get repaired hope this is some help to you....................................
Nov 12, 2007 | Motorola Mobility L6 Cellular Phone
Bad phone or bad battery?
hi
try replacing your batt...
if samething happens worst is you have a hardware prob...
but try replacing your batt first...
Oct 14, 2007 | Motorola Mobility RAZR V3
Stupid phone
Contact Motorola directly. They are very good about warranty and will most likely overnight you a replacement.
Aug 09, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
65 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
