Question about Western Digital Computers & Internet
I have a WD40u1. My computer does not have an Drive A. Only a Drive C. Can I change the end of the Backup to be compatible with Drive C?
  • 6,487 Answers
Yes you should be able to use that drive for back up and you don't need a drive A, you can set to your back up software if you have to do back on it.
Posted on Aug 29, 2010
Tip
How to choose a backup device
Hello all,
I work in data recovery and I'm always being asked what kind of backup device my customers should use. The fact is, there are a lot of choices and a lot of different situations with different answers.
Whatever device you choose for backup, remember the most important part of backing up is to always have more than one copy. Your backup device does you little good if it holds the only copy of your files.
USB Flash drives:
Pro's Cons
Most Inexpensive Easy to damage
Easiest to Transport Easy to Lose
High Compatibility Difficult to recover
Fast copy speeds
External Hard Drives:
Pro's Cons
Inexpensive Some are bulky
Higher Capacity Greater damage if dropped
Easy to transport Can be expensive to recover
High Compatibility Some require external power
Faster Copy Speeds
Easier to recover
More rugged
Secondary Hard drive(internal)
Pro's Cons
Inexpensive Not optional on most laptops
Higher Capacity Not optional on all Desktops
Fully compatible Can fail simultaneously
Fastest Copy Speeds Does not protect data if PC Stolen
Easy to Recover Requires some knowledge to install
More Rugged
Less risk of damage
NAS Box or Small Server
Pro's Cons
Higher Capacity Higher Cost
Redundancy is Optional Requires more knowledge to setup
Accessible to all PC's
on your network at once
Fast Copy Speeds
Low risk of damage
Compatible with most PC
RAID5 NAS or Server
Pro's Cons
Highest Capacity Highest Cost
Highest Redundancy Requires most knowledge to Setup
Fastest Copy Times Requires specialized equipment or software
Accessible to all PC's Most expensive to recover if failed
Ability to survive single
drive failures without
data loss.
Now, armed with that short list of options, let's help you decide which option best suits you. If you move around a lot, you go to school, work out of the office or travel for work a USB flash drive is often the simplest form of backup and allows you to move data between home, office or school without lugging a large drive around. we recommend these as a part of most peoples backup solution. Next you will want a more stable form of backup(harder to damage).
For your tougher backup device you will have to decided what kind of budget you have, how much data will need to be backed up and how often. If you have a great deal of data from several computers in your home or office you will likely want to use a NAS box or setup extra drive(s) in one of your existing desktops to use as a server. If you only have one or two computers or the budget just won't cover a RAID or NAS solutions you can simply purchase an external USB or eSATA hard drive, usually less than $100. This can be moved between computers and used for backing up.
Now remember to Sync your data. This means anything you update or create while away that is saved on your USB flash needs to be copied into your computer and your computer needs to be backed up onto the external drive or server.
For more information on backing up, verifying backups and different types of backup devices, visit my blog at http://www.aitsavemyfiles.com/armor-itrecoveryblog.php or search through the other tips available here on FixYa.
on Mar 19, 2010 | Computers & Internet
My computer won't power on after using backup now ez
when it is not compatible with the configuration of the computer,how can windows 7 be installed! you can reinstall the OS but only try xp if it is not compatible!
Apr 07, 2012 | NTI Backup Now EZ
I conect to my pc a new hp md1000h hdd but in my windows explorer only see: unit CD (O:) HP Loncher.exe, buno responding
Hi, your external hard drive features and automatic backup function, that is what the "launcher.exe" is for. If you don't need such a function, you go to Control Panel>Administration Tools>System Management and on the left you will find a "disk management" section. There you will find your hard drive information, and will be able to format and create partition on it, by doing so you will most likely be able to use it properly. If, instead, you need the automatic backup function of your hard drive, you can try starting the "launcher.exe" as administrator, and, if that does not work, you can contact HP support to ensure that your system is compatible with your hard drive's functions. Hope it helped, Franz
Mar 09, 2011 | HP SimpleSave 1 TB USB 20 Hard Drive
What Windows-compatible "backup" software can
You can format it directly from Windows XP going in My computer then right click on your drive icon and hit format. Don't change anything in the fields but put a check in quick format.
For your backup needs, Acronis are making very good data management softwares.
Feb 10, 2011 | Verbatim 160GB USB FireLite: The "drive...
I have had to replace my hard drive on my pc how can i get my music back on to pc from my ipod and back into i tunes
Backing up your iTunes library to a CD or DVD To burn a CD (CD-R or CD-RW), your computer must have a compatible CD burner. To burn a DVD (DVD-R or DVD-RW), your computer must have a compatible DVD burner. Check in iTunes Preferences to see if a drive is compatible. See below for steps.
To create your backup disc
  1. Choose File > Library > Back up to Disc.
  2. Select the option you want from the resulting dialog and click Back Up.
  3. The two options you can select from are:
    • Back up entire iTunes library and playlists
    • Back up only iTunes Store purchases
    Whichever of these two options you choose, note that you can also choose "Only back up items added or changed since last backup" to perform an incremental backup.
  4. Insert a blank disc (CD or DVD) into your computer's optical drive. iTunes will scan the disc and begin burning.
  5. Note: If the disc you insert does not have enough space to hold all of the content you will be backing up, a dialog will appear asking whether you wish to backup to multiple discs. You can click Data Discs to continue.
iTunes burns the number of items that fit on one disc and then asks you to insert subsequent discs to continue burning the remaining files. Don't eject a disc while a backup is in progress.
Spoken programs purchased from the Audible.com website are not backed up.
Discs you create using the iTunes backup feature can be used only to restore; they can't be played in a CD or DVD player.
Restoring from a backup disc
  1. Open iTunes.
  2. Insert your backup disc.
  3. iTunes will ask whether you want to restore from this disc. Click Restore.
Check drive compatibility
  1. Choose a playlist on the left side of the iTunes window.
  2. Click the Burn Disc button on the bottom right corner of iTunes.
  3. If the drive is listed, it's compatible.
Aug 16, 2010 | Apple iTunes
How do I transfer my itunes to another computer?
Cucusoft iTunes to iTunes Transfer is an easy to use iTunes utility designed to help you backup/recover/transfer your whole iTunes library and media files. It's a simple way to keep your iTunes in sync everywhere. You can use "iTunes to iTunes Transfer" to backup your own iTunes library or synchronize multiple iTunes on different computers. The backed up library file is pretty easy to transfer to other iTunes, and it's easy to manage. So with this iTunes Transfer software, you can manage your iPod/iPhone/... on different PCs
Transfer photos, music, videos from iPhone iPad iPod to computer or Mac by this software:
http://www.mustsoftware.com/Cucusoft-iPad-iPhone-iPod-to-Computer-Transfer-guide.html
For iphone/ipod/ipad to Mac transfer
Jul 27, 2010 | Apple iTunes
My drive is full so it won't back up anymore!
Check the backup settings in the software that came with the device. You may be saving every backup instead of saving incrementally. An incremental backup will back up the files that have changed after doing one full backup.
You can also view the files on the drive through Windows Explorer.
The files should be dated. Delete the oldest files making sure that they seem to be the same size as the next oldest file.
If your computer is not faulty, and the files on the backup are not the only place that they are copied, you can start over with the backup drive, change the backup settings and create an incremental backup routine.
Depending on the size in Gigabytes of the backup drive, you are limited to the amount of data you can back up.
Example:
If you have a 500Gigabyte drive in your computer and the external backup drive is 250 Gigabytes,a full system backup will not fit.
Go to Windows Explorer, Click on My Computer and view the available space and total size for each drive.
If you need more help, Use Fixya's new Phone Call Service. For $29.99 an expert will walk you through the setup and drive check.
Mar 17, 2010 | Western Digital My Book Essential Edition...
New pc is 64 bit and old hard drive backup says it
The old HD backup was created with a 32 bit os, you now have a 64 bit os
The HDD is still usable just not the backup..
Aug 15, 2009 | HP Computers & Internet
No Compatible media found in HP Tape Drive
Try a brand new tape fresh out the wrapper.
If that doesnt work make sure you are using the right drive in your backup software!
It sounds like a message often seen in windows backup where you have selected the wrong tape drive from the list and it just tells you "No compatible media found" when actually the drive listed isnt even connected to your system still
Nov 27, 2008 | HP StorageWorks Ultrium 448 LTO 2 Tape...
Computers & Internet Logo
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
