Question about Zephyr Venezia ZVE-E30 Kitchen Hood
Speed control on fan
The speed on fan blinks the letter A while running can you help me the fan is about 4 yrs old thank you
It means that the filters on the hood need to be cleaned. You simply pop them out and can wash them in the dishwasher. Once clean, dry and replaced, you hold down the fan speed button (the second button from the left or " - " minus for more than five seconds.) When you first hit the button the A will appear, hold the button when the letter disappears, the timer has been reset until time for the next cleaning. The microprocessor in the system will flash every 30 hours of operation.
Posted on Oct 06, 2009
  • Fran Gonzales
    Fran Gonzales Jul 10, 2014
    I just had hood replaced and after using it for about 2 weeks the fan started blinking. I took the filters and they were still clean. I just held button down for a couple of seconds and it quit blinking.
Casablanca fan intelli touch
there is a starter solenoid inside it works the speed setting. controls speed 1-2-3. 4 it bypasses it. in side the fan you will see a black box with c66 somthing that will need to be changed as that is the part that controls the speed.
Oct 17, 2013 | Dryers
Hunter Ceiling fan lost medium speed, kept hi and low. Speed control capacitor melted. Replaced both capacitors (speed and start) AND switch. Still no medium speed. Is it possible part of the motor...
well, they could have. but before you throw it out, go to the hardware store, and buy a new pull switch. either that, or just run it with the high and low speeds. It shouldn't hurt it at all. But, if there is any clicking sounds, or wierd noises coming from it , DON'T USE IT!! it may catch fire. but it did last a long time. 20 years is good for a modern celing fan. though I like my antique 1907 westinghouse 72 inch 2 blade fan. It hasn't died yet!!!
Aug 12, 2010 | Hunter Ceiling Fan Control Switch
We have a Hampton Bay ceiling fan (about 10 yrs old) don't know the model. It will only turn 1 speed? When trying to change speeds with the chain pull it stays the same. It quit working for a while and I...
the fan changes speed by inserting a capacitor of different values in series with the motor .. direct drive to the motor is the fastest speed .. a large capacitor in series slows it down a bit and a smaller capacitor slows it down more ... so if your fan is running at full speed all the time then one of the capacitors is shorted or the switch is bad .. if its stuck on one of the lower speed settings then the switch has a bad contact .. the capacitors are mounted together in a small box with several wires going to the pull chain switch .. you can replace the capacitor box .. and you can replace the 3 or 4 position switch ... or you can remove all that stuff and put in a remote controled system .. that involves a box that just fits inside the fan .. it is hooked to AC power and neutral .. it then hooks up to the lilght and the fan giving you control over both .. you can vary brightness and fan speed .. you would no longer need the fan or light pull switch or the capacitors ... you could also get a new fan having such a controller .. since yours is fairly old it might be worthwhile to upgrade .. some of the remote controls allow you to set a temperature ..if the room goes above that temp then the fan turns on automatically and the speed is determined by how much higher the room temprature is from that set value .. some remotes also give you an additional very low fan speed .. thats nice at night when you just need a gentle breeze .. some also allow you to set a delay before the lights go out after you have clicked "turn off" ... that gives you time to exit the room or get in bed before the lights actually go out ... kindof nice features that might make it worth while to up grade .. to get parts for your old fan see this URL
http://www.ceiling-fans-n-more.com/hampton-bay-ceiling-fan-parts.php
since Home Depot sells hampton bay .. then they might have parts as well .. worth a try .. you can also see new models there ..
Jun 06, 2010 | Hampton Bay 52 In. White Redington...
My whirlpool dishwasher clean light blinks on and off,and I can no longer run dishwasher.Unit is only 3 to 4 years old
Hi- One of two things- fault in touchpad/control, or bad motor. If you pull bottom kick panel, with a bright light look underneath for water deposits on botom of aluminum motor case. Any motor seal leak will show up here. If you see any crud on bottom, motor must be replaced. Not uncommon to fail 3-4 yrs.Anyway- motor is about 100$ - control 150-175$ Labor varies.- Hope this helps- ED
Mar 01, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
I replaced the pull chain control as instructed and now only get one(low) speed
it seems you replaced the old switch with a single pull single throw switch or you did not install it correctly..
Nov 12, 2009 | Casablanca Fan (TRIH45) Ceiling
G E side by side refrigerator is not working properly....
Could be the start relay device on the compressor. Does it try to start every minute or so?
Sep 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
New cpu fan has 3 prong connecter, old has 4. what is,or does the 4th blue wire have to be connected?
You can connect the CPU fan as normal but it can only run at one speed and voltage hence only having 3 wires.
Your other CPU fan which had 4 wire was able to run at 2 different voltages and speeds and are mainly used to keep the noise down and run quietly.
Regards.
Jul 10, 2009 | eMachines T5048 PC Desktop
Fan constantly running,have comp presario sr1420nx about 4 yrs
If blowing the dust did not help your only other options are replace the fan or replace the heat sink with a newer one that incorporates a quieter fan.
Jun 09, 2009 | HP Compaq Presario SR1420nx...
Oven, broiler don't work
The main control board is what you need to replace here.Please Rate This !
Jul 06, 2008 | Kenmore Kitchen Ranges
Zephyr Venezia ZVE-E30 Kitchen Hood Logo
444 people viewed this question
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
Tom Chichester
reliableservice
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
