Dear Madam/Sir Please help me to solve a problem. Since there is no email adres for support in holland i try it this way. I bought a Packard Bell Ixtreme I9501NL SNID: 90400220718 SerialNR: PTU140X0059040089F1800 Purchase date 14-02-2009 When i bought this computer it said, and that what the salesman of Dynabyte said, has an Network card which was 10/100/1000 MB/s I have a lot of file transfer because i am an video editor. I suspected that the transfer rate of the card was not that fast. so i investigated. On my Linksys router only the 100 MB/s lamp burned when i connected the computer Also Sisoft Sandra implies that this was a gigabyte card but running on 100 MB/s I tried to make a ticket on the Dutch site of Packard Bell but this did not function well, so i could not make a ticket. Please can you help me to solve this problem or try to explain why the transfer rate is so low. Perhaps something has to be changed in the properties of the card which you can do in the network connections under configuration and then advanced. But i am not an expert enough to understand everything about the properties. My Operating system is a legal Windows Vista Home Premium 64 Oem version SP2 1 x WDC WD6400AAKS-22A7B2 HD 1 x WDC WD1001FALS-00J7B0 HD This is what Sisoft Sandra found about the Card. As you see a whole lot but what matters is the peace in RED (more below) As you will see it gives Speed : 100Mbps and that is what I do not understand. Regards A very satisfied Packard Bell PC user Jan Masmeijer Hesselterbrink 213 7812 CG Emmen, Drenthe, The Netherlands jp.masmeijer@home.ml cell: +31621550364 SiSoftware Sandra WinSock Library Version : 2.02 Description : WinSock 2.0 Status : Running Host Name : PC4 Node Type : Hybrid IP Gateway/Forwarder : No DNS Service Enabled : No ARP Proxy Enabled : No IP TLL Value : 64 IP v6 Support : Yes Bluetooth Support : Yes Network Adapter Name : \DEVICE\TCPIP_{C328FED4-6A85-11DB-9FBD-806E6F6E6963} Model : Software Loopback Interface 1 Type : Loopback Speed : 1Gbps Packet MTU : 1.46kB IP Address 1 : ::1 Auto Configuration Enabled : Yes Auto Configuration Engaged : No Operational : Yes Network Adapter Name : \DEVICE\TCPIP_{8F40FDFC-51B7-4EE3-9529-431D559884BA} Model : WAN-minipoort (L2TP) Type : Tunnel Speed : 1Gbps Packet MTU : 1.43kB Auto Configuration Enabled : No Operational : Yes Network Adapter Name : \DEVICE\TCPIP_{46F58194-1717-4CA9-ADAD-FE13A4DF3BD8} Model : WAN-minipoort (PPTP) Type : Tunnel Speed : 1Gbps Packet MTU : 1.43kB Auto Configuration Enabled : No Operational : Yes Network Adapter Name : \DEVICE\TCPIP_{D2AE8352-ECE3-45F7-A112-4A71580C824F} Model : WAN-minipoort (PPPOE) Type : PPP Speed : 1Gbps Packet MTU : 1.46kB Auto Configuration Enabled : No Operational : Yes Network Adapter Name : \DEVICE\TCPIP_{CC4F201B-DEB8-4DDE-9AF7-9A5CDA9EE449} Model : WAN-minipoort (IPv6) Type : Ethernet Speed : 1Gbps Packet MTU : 1.46kB Auto Configuration Enabled : No Operational : Yes Network Adapter Name : \DEVICE\TCPIP_{23CE79FE-DFAF-4894-B0B7-47B516A4C264} Model : WAN-minipoort (IP) Type : Ethernet Speed : 1Gbps Packet MTU : 1.46kB Auto Configuration Enabled : No Operational : Yes Network Adapter Name : \DEVICE\TCPIP_{347E9457-C2BD-4EBA-99B1-878A98BF3CF6} Model : RAS Async-adapter Type : PPP Speed : 1Gbps Packet MTU : 3.18kB Auto Configuration Enabled : No Operational : Yes Network Adapter Name : \DEVICE\TCPIP_{A01C08D3-0C31-46C4-9D8D-86AA3AE783D5} Model : WAN Miniport (SSTP) Type : Tunnel Speed : 1Gbps Packet MTU : 4kB Auto Configuration Enabled : No Operational : Yes Network Adapter Name : \DEVICE\TCPIP_{84628EB1-F1CB-47DD-854C-4E7677D67E4C} Model : WAN-minipoort (Network Monitor) Type : Ethernet Speed : 1Gbps Packet MTU : 1.46kB Auto Configuration Enabled : No Operational : Yes Network Adapter Name : \DEVICE\TCPIP_{20F08FC2-41D1-43BB-ADFD-1910F3FEBC2A} Model : Teredo Tunneling Pseudo-Interface Type : Tunnel Packet MTU : 1.46kB Auto Configuration Enabled : No Operational : No Network Adapter Name : \DEVICE\TCPIP_{CDEAF4D5-67D2-4866-83A7-32CD043A7F44} Model : Bluetooth-apparaat (RFCOMM Protocol TDI) Type : Other Auto Configuration Enabled : No Operational : No Network Adapter Name : \DEVICE\TCPIP_{A332BCCA-54A8-43AB-9E8A-BF62CD4FB310} Model : Bluetooth-apparaat (Personal Area Network) Type : Ethernet Auto Configuration Enabled : No Operational : No Network Adapter Name : \DEVICE\TCPIP_{4D0573E1-936E-45F3-AB9C-FF3C05B1A4EF} Model : Bluetooth-apparaat (RFCOMM Protocol TDI) #2 Type : Other Auto Configuration Enabled : No Operational : No Network Adapter Name : \DEVICE\TCPIP_{FD86C404-DB26-4653-B3C6-845E063FD9BB} Model : Bluetooth-apparaat (Personal Area Network) #2 Type : Ethernet Packet MTU : 1.46kB MAC Address : 00:10:60:A2:C3:2D Manufacturer : BILLIONTON SYSTEMS DHCP Enabled : No WINS Enabled : No Auto Configuration Enabled : Yes Auto Configuration Engaged : No Operational : No Network Adapter Name : \DEVICE\TCPIP_{3E6BD45C-8400-47E1-BA8B-744A1B453429} Model : Sony Ericsson Device 0016 USB Ethernet Emulation (NDIS 5) Type : Ethernet Auto Configuration Enabled : No Operational : No Network Adapter Name : \DEVICE\TCPIP_{D183F897-44DB-4FBD-BB6D-047AD39A924F} Model : Sony Ericsson Device 1018 USB Ethernet Emulation (NDIS 5) Type : Ethernet Auto Configuration Enabled : No Operational : No Network Adapter Name : \DEVICE\TCPIP_{68A8D567-C879-41E5-A35B-D1037CF450CA} Model : Bluetooth-apparaat (RFCOMM Protocol TDI) #3 Type : Other Auto Configuration Enabled : No Operational : No Network Adapter Name : \DEVICE\TCPIP_{87729209-A353-44B8-8C91-21F5866486A2} Model : Bluetooth-apparaat (Personal Area Network) #3 Type : Ethernet Auto Configuration Enabled : No Operational : No Network Adapter Name : \DEVICE\TCPIP_{A4DE730A-2275-44F5-A2B0-CD999BFEC485} Model : Sony Ericsson Device 1018 USB Ethernet Emulation (NDIS 5) #2 Type : Ethernet Auto Configuration Enabled : No Operational : No Network Adapter Name : \DEVICE\TCPIP_{992BE4EB-6634-488A-BC53-A1C3F8C3CF07} Model : Bluetooth-apparaat (RFCOMM Protocol TDI) #4 Type : Other Auto Configuration Enabled : No Operational : No Network Adapter Name : \DEVICE\TCPIP_{9952BE0D-9738-4066-96CD-FFD6D9CAD135} Model : Bluetooth-apparaat (Personal Area Network) #4 Type : Ethernet Auto Configuration Enabled : No Operational : No Network Adapter Name : \DEVICE\TCPIP_{73C55B82-0B8B-454E-866E-2F3A6918BA1D} Model : isatap.{9952BE0D-9738-4066-96CD-FFD6D9CAD135} Type : Tunnel Packet MTU : 1.25kB Auto Configuration Enabled : No Operational : No Network Adapter Name : \DEVICE\TCPIP_{4EDC17BA-0E1B-496D-A59F-337AAA5AF22D} Model : Intel(R) 82567LF-2 Gigabit Network Connection Type : Ethernet Speed : 100Mbps Packet MTU : 1.46kB MAC Address : 00:22:68:46:96:D7 Manufacturer : 002268 IP Address 1 : 192.168.1.41 IP Address 1 Subnet Mask : 255.255.255.0 IP Gateway/Forwarder : 192.168.1.1 DHCP Enabled : No WINS Enabled : No DNS Server 1 : 192.168.1.1 Auto Configuration Enabled : Yes Auto Configuration Engaged : No Operational : Yes Network Adapter Name : \DEVICE\TCPIP_{B885AF6F-CF93-4CCD-9D1F-C3F622D4E659} Model : isatap.{FD86C404-DB26-4653-B3C6-845E063FD9BB} Type : Tunnel Packet MTU : 1.25kB Auto Configuration Enabled : No Operational : No Network Adapter Name : \DEVICE\TCPIP_{CC2E5278-182A-40E7-9340-4FD24A3921E6} Model : isatap.{4EDC17BA-0E1B-496D-A59F-337AAA5AF22D} Type : Tunnel Packet MTU : 1.25kB Auto Configuration Enabled : No Operational : No Network Adapter Name : \DEVICE\TCPIP_{C328FF12-6A85-11DB-9FBD-0014222358F2} Model : WAN-minipoort (IPv6)-QoS Packet Scheduler-0000 Type : Ethernet Speed : 1Gbps Packet MTU : 1.46kB Auto Configuration Enabled : No Operational : Yes Network Adapter Name : \DEVICE\TCPIP_{C328FF15-6A85-11DB-9FBD-0014222358F2} Model : WAN-minipoort (IP)-QoS Packet Scheduler-0000 Type : Ethernet Speed : 1Gbps Packet MTU : 1.46kB Auto Configuration Enabled : No Operational : Yes Network Adapter Name : \DEVICE\TCPIP_{5C4D346B-C7CF-11DC-AEFA-0014220F46A8} Model : WAN-minipoort (Network Monitor)-QoS Packet Scheduler-0000 Type : Ethernet Speed : 1Gbps Packet MTU : 1.46kB Auto Configuration Enabled : No Operational : Yes Network Adapter Name : \DEVICE\TCPIP_{34AB0D89-3330-11DF-B032-D21F7E396786} Model : Intel(R) 82567LF-2 Gigabit Network Connection-QoS Packet Scheduler-0000 Type : Ethernet Speed : 100Mbps Packet MTU : 1.46kB Auto Configuration Enabled : No Operational : Yes
  • 319 Answers
Thedailyreviewer.com/.../maintaining-same-session-of-existing-ie-when-open-a-link-in-email-from-oe-107215487
Posted on Aug 29, 2010
Dear Sir/Madam Could you please advise as to where
Dear sir i have problem with my sending email please help me
Thanks&Best regrads
Sep 19, 2013 | Computers & Internet
Hi sir i by mistake deleted my qeep account and i regrate it please re-open it sir...my id is sonnie33.....
Hi sir/ madam already deleted my qeep account and i regrate it . Please re open it sir/madam my id is .Nf
May 26, 2013 | Computers & Internet
Dear Sir/Madam, I had an email address as follows sice 2000 viscoahem@hotmail.com unfortunately one day around jan 0r Feb. 2011 i could not sign in then i followed all procedure but i could not use my...
  • There is a good chance your email has been hacked by someone else. Try clicking "Forgot your password?" to try and recover it if it has changed.
Jul 07, 2011 | Lands Phones
Lost my cd to install printer can you help me install without the cd
Sir/Madam look for the brand or model of your printer then search it from the google,download the driver of the said model of printer or ask for another copy of cd to the store where your printer bought.Hope this solution can solve your problem.Sir/Madam don't forget me to rate me up,thanks a lot.
Jun 07, 2011 | Computers & Internet
Hi sir/madam am sasi from
you have selected the small fonts for messaging in your settings.. try to look at the message settings then find font size then changed it to what you desire.... hope it helps...
Jan 09, 2011 | Samsung S3653 Cell Phone
Dear sir/madam, i forget my yahoo id password
Hello there!
Unfortunately, if you have forgotten your username or password and even your security question/answer, you can no longer recover your email services. You just have to create a new one.
However, try to click the "forgot password" and then the reset password link might be sent to your secondary email address, if you register one.
Nov 07, 2010 | Yahoo Mail
Corrupted IMEI Number for Nokia 5220
hello sir /madam i have nokia 5220 mobile his imei no has been corruped how can i solve this proble
pls give me infor
email:kuldeepchauhan6@gmail.com
Jan 12, 2010 | Nokia 5220 XpressMusic Cellular Phone
Computers & Internet Logo
500 people viewed this question
David Payne
David Payne
