Question about Epiphone Pr 150 Acoustic Player Pack Vintage
How do i get the battery out took off the door on the side but the battery seems stuck don't want to pry it out
  • Epiphone Master
  • 5,603 Answers
A lot of these you have to GENTLY pry up one end of the battery cells.
Posted on Aug 30, 2010
My tone knob given that it's no more fixed to the body and keeps rotating on itself?
usually they have a small nut that screws don the shaft to hold in place firmely
Apr 29, 2015 | Epiphone SG Prophecy Custom EX Electric...
Zoom H4n compact card is stuck in the slot. Cannot remove it. Where do I send these to be repaired
I had the same problem.
the sd card got stuck somehow with the secure lock.
the spring still pushed it out, but it was stuck in the slot.
i took a small pin and pushed it in between the slot and the card (upper side on the left) and it was possible to take it out.
May 03, 2012 | Zoom H4 Handy Recorder
The cd/tape (standby) button stuck on Behringer SX2442FX Eurodesk Mixer. The button is stuck in the down position, placing all inputs other than the RCA jacks for the CD/TAPE inputs into STANDBY mode......
First thing is to get a can of CRC226 from Home depot in the electrical dept. Put a little on a q Tip and work it into the area between the button and the panel. work the button a little bit sideways. Using the point of a scalpel or Xacto knife from one side, gently pry up by sticking the point into the side of the button and levering it up. Once it is up, apply more CRC226 around to lube the button. Be gentle... often contamination gets between the button and the hole in the panel.
Jul 03, 2011 | Behringer Sx2442fx Eurodesk 24channel...
It seems I've got a loose contact at the input socket, how do take the amp out so i can open it up and fix the connection?
For some reason that model number doesn't appear to be valid.
HOWEVER... look for screws from teh side where the amp chassis is AND sometimes Behringer HIDES screws holding the amp under the covers where the handles are. These cover snap off after a fashion... one has to pry sideways near where the rubber/plastic goes insidethe cap and pry ONLY the plastic part sideways to release the cap. There is a metal piece inside so the pry has to be on about the first 32nd of the plastic. The screws under this also hold the amp. Under the amp are wires to the speaker... Be careful to not damage them... USUALLY the amp goes out the front. I have a BX1200 so mine may be different.
Mar 29, 2011 | Behringer Ultrabass Bxl450 45w 1x10" Bass...
Edirol Midi Keyboard Controller PC-50 Many notes no longer sounding. Can't get into keyboard to check contacts
Well, you have to get into the keyboard. There will be screws or latches that hold the case together.
SOMETIMES screws are hidden beneath stuck on rubber feet.
SOMETIMES plastic latches are where there are slots... have to be careful as they can break if you don't open them right.
WORST are latches along the sides that you have to pry open... knowing where they are is key.
You will probably find that the keys consist of conductive rubber "pills" that are in silicone rubber domes that the keys press against finger-like circuit traces on a board under the keys.
Clean BOTH the pills and the traces with 99% isoprophyl alcohol and a Q-tip.
Dec 11, 2009 | Music
Epiphone Pr 150 Acoustic Player Pack Vintage Logo
47 people viewed this question
Top Epiphone Music Experts
Michial Gueffroy
Craig Butler
Craig Butler
Vito Vacirca Jr.
Are you an Epiphone Music Expert? Answer questions, earn points and help others
