Where is filter in hotpoint wt960 washing machine
  • 1 more comment
  • Anonymous Mar 17, 2009
    Me too!
  • Anonymous Apr 07, 2009
    And me :-)
  • Anonymous May 03, 2009
    Me too i don't think there is one
I Had the same problem today, Firstly my WM was ripping up clothes then today it started to show a flashing tap on the display and it stopped working on the rinse cycle, I did a little research and found out that it was probably a blocked filter, BUT where is the filter! Fortunately i love dismantling things so i removed the back panel and found that under the drum there is a cone shaped rubber hose which is held on by a clip, the filter was here.
I have now fixed it
I hope this helps
Posted on Dec 14, 2009
I would also like to know the answer to this!
Posted on May 17, 2008
Hotpoint washing machine wt960 not working because fo8 code come
Hi Hitendra,
F08 is a sticking heater relay. First check that connections on pressure switch are good, Check that heater connections are good.Check the board connections.Check that pump filter is clear.
Hope this helps!
Wayne
Nov 20, 2014 | Hotpoint Washing Machines
Hotpont washing machine wt960 fo8 code m/c stop
I believe F08 Error code is for a Heater fault
Issue: During a wash cycle the programme pauses part way through.
Hotpoint WT960 has the H2o symbol flashing it has water and no pipe kinks
Make sure that the water pressure is o/k, and that the valve is fully turned on.
Also check the filter in the inlet valve, you wilave to remove hose to do this.
Mar 29, 2010 | Hotpoint Washing Machines
How do i reset my hotpiont ultima lcd wt960 washing machine?
I have a hotpoint wt960 i did 1 load of washing, turned it off. Put next load in then it would not turn back on. any ideas???
Nov 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
I have a Hotpoint WT960. After each wash there is
The hole that the fabric conditioner goes through is blocked.. use a straw to blow down it and this should solve your problem. hope this helps.
Sep 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
Removal of the filter from a hotpoint wt960
Filter is located inside large black hose at rear of washer, remove lower rear panel and remove hose, and clean plastic filter inside hose.
Please rate my solution.
Thanks.
Mar 31, 2009 | Washing Machines
Filter on WT960
hi, in the uk the filter is behind a flap on the bottom/front of the machine, be careful as when you undo it some water will leak out, hope this helps
Feb 09, 2009 | Hotpoint Aquarius WD63 Front Load...
I have just fitted a new door lock on my washing machine hotpoint wm53p and now it wont work.
How do i replace the door handle on my hotpoint washing machine (wt960)?
Jul 21, 2008 | Hotpoint Washing Machines
Hi where is the filter for a hotpoint WT960 washing machine
Its most likely built into the tub and you don't need to access it.Under the agitator is usually the place on the tub they would put a filter
May 25, 2008 | Washing Machines
Washing Machines Logo
844 people viewed this question
Top Washing Machines Experts
