Question about Bose SoundDock digital music system Docking Station for iPod - White (35703)
My Bose SoundDock is not working, I have tried various ipods (touch/orig) neither charge, they do play, but no sound comes out. Both play on other docking systems. I have tried a few different power cables and the only thing I can get the system to do is; if I INcorrectly insert the cable to the back of the SoundDock an intermittent buzz/tick noise can be heard. Other than that the remote does not seem to work (tried 4 batteries), no connection noise is made when plugged in so I dont even know if the power side is working. Prior to this, the cradle appeared to be somewhat loose and a little jiggle would achieve sound (although not always hold). This is now my 2nd sounddock that has gone this way, so I need to get this one fixed as I cannot afford to buy a new one!
  • 20 Answers
SOURCE: Bose docking statoin
They both use the same speakers, my personal opinion deems they are both the same. However the second SoundDock charges via USB pin, so it is future proof for future iPods.
Posted on Dec 11, 2008
SOURCE: docking cradle in bose sounddock
Hi
To fix this you will need to have the dock/cradle re-soldered. I know someone who does this and does not charge a fortune. If you would like to get it fixed then let me know,
Steve
stevieoke@gmail.com
Posted on Sep 09, 2009
  • 73 Answers
SOURCE: Bose SoundDock portable music system -
It is a loose contacts. Disassemble ipod, check if plug in jack is loose and resolder plug in connections on the circuit board.
Posted on Oct 23, 2009
SOURCE: No sound from Bose SoundDock
I had this problem on my SoundDock. My iPod would charge on the dock just fine and when I played my iPod on the dock, it would look like it was playing, but have no sound. Since my Bose was out of warranty, this is what I did to fix it. #1 Unplug the adapter. #2 Unscrew the four large screws on the bottom of the speaker and the three small screws under the dock. #3 You'll see one long ribbon connection and one very short one. Check to see if the ribbon connector coming from the front of the speaker system came loose from the green board. You'll only be able to see 1/2 an inch of it sticking out, and it's not easy to plug it back in, but it's possible. Just take your time. #4 Carefully put everything back together being very careful not to let the ribbon fall out of the plug again. #5 Make sure to plug in the DC adapter the correct way. There's a very subtle difference, but there is a difference. There are four prongs - two are square and two have slightly rounded corners. If it's not plugged in the correct way, the dock will have a static clicking sound. On my adapter, the words "DC power" are on the top of the plug.
Posted on Nov 24, 2009
SOURCE: with my ipod dockes I am getting a distorted sound
Did you get this solved??
I am having the exact same issue!
Posted on Feb 20, 2010
My ipod wont play in the bose sounddock. tried shutting off the ipod. dont think my sounddock has an on/off switch. did unplug all pieces
We have an HCL desktop computer. Though we had loaded Ac97 Sound Driver still the sound is not coming (totally soundless) Can you suggest what to do?
Jan 16, 2011 | Bose SoundDock digital music system...
Ipod charges on bose dock but won't play ipod firmware 3.1.2 recently updated
i have bought a ipod nano and i want it to work in my car stereo it charges but does not play it does play my sons ipod touch so the cable is ok
Feb 07, 2010 | Bose SoundDock digital music system...
Bose Sounddock won't play iPod touch
You probably have a broken docking connector or bad power supply. Contact www.invebo.com to get a replacement board. It takes minutes to fit. They also sell the USB charge upgrade to enable you dock to charge the IPHONE on the Soundock original.
Sep 13, 2009 | Bose SoundDock Portable Music Pack Docking...
Bose Docking Station incompatibility with IPOD Touch
You need to reset your ipod. You can go online to find out how to do this. I had to do it with mine and then it worked perfectly.
Aug 08, 2009 | Bose SoundDock digital music system...
Bose sound dock - no sound comes through it but my ipod works with the ear plugs so it's not my ipod
I had this problem for the pat two days. Believe it or not I took my Ipod touch of the dock. Shut the power off to the Ipod to reset it. Also the power to the docking station. turned everything back on. Put the Ipod back into the docking station and heard the beep.. and hit play and it was working again. Not sure but shutting Ipod off does act like a reset.
Jul 19, 2009 | Bose SoundDock digital music system...
New ipod nano not compatable with bose docking
This is true. The new iPod nano is not compatible with the original SoundDock. This only means that it won't charge the iPod's power. Audio should be okay. This is an Apple issue. They changed the way almost all of their iPods charge (except the iPod classic). Bose can upgrade the SoundDock for their normal repair fee of $99. This would also you a new 1 year warranty.
Jun 23, 2009 | Bose SoundDock digital music system...
Our sound dock does not charge our ipod touch 2nd gen. Bose manual says it does charge. The sound dock is not series 2. Are they not compatible? Thanks, Mark
The original SoundDock will not charge the iPod touch 2nd gen, or the iPhone 3G, or the new nano either. This is because Apple changed the way their new iPod products charge. (via USB only now)
There is 1 solution- Call Bose tech support. They can replace the 30 pin metal connector for a new one that will charge this. If this is not under warranty, it will cost $99, but it's worth it. New 1 year warranty, and compatibility with all iPods (except much older- non-clickwheel iPods)
Jun 21, 2009 | Bose SoundDock digital music system...
Does the new bose dock station charge the new ipod touch (32g)?
The new SoundDock II charges your new iPod touch and is fully compatible all iPods and the iPhone 3G. Also the SoundDock Portable will do this. But..
Better news-> Call Bose. They can upgrade the 30-pin connector to charge via USB-only and function with the remote as well. $99. This will make your iPod touch 100% compatible and somewhat future-proof your SoundDock. If the SoundDock was purchased within 90 days (at full retail price), they will do the upgrade for a smaller fee or even free I think.. (new 1 year warranty given with repair/mod) btw- This is an Apple issue, not a Bose issue. All 3rd party iPod connection devices had to make this change at some point.
May 31, 2009 | Bose SoundDock digital music system...
Won't charge on Bose SoundDock
You're not doing anything wrong. Newer iPods and the iPhone require accessories that were specifically designed for them. For example, the iPod interface in my car will not charge my iPhone, however, I can still play music through it.
The only solution is to: 1: Buy a SoundDock II or 2: Charge your ipod seperately.
Apr 20, 2009 | Apple iPod touch
Bose Sounddock problem
I had the same issue, it just stopped working today for no reason. Since it's out of Warranty and Bose charges too much to fix it, I took the bottom off, cleaned all the contacts, applied some dialectric silicone compound to the contacts, put it back together... and it works great!
Sep 17, 2008 | Bose SoundDock digital music system...
Bose SoundDock digital music system Docking Station for iPod - White (35703) Logo
153 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
