Question about HP Photosmart C3150 Printer
Color copy quality
I replaced color ink cart #93 and now am getting very poor color copies. I tried a second new cart and same thing. Wording is ghosty and color is not clear and blotchy. I am using a color word document. Can you help?
my e-mail is cindypowell2@allstate.com
  • abr4839 May 07, 2008
    I have a hp psc1210 all in one. I am trying to install it for wireless use just using my linksys wrt54g. Can you help. Thanks
I have a hp psc1210 all in one printer and a linksys wrt54g router.
Is there any way I can use the printer using the wireless mode. Thanks.
Posted on May 07, 2008
I have a problem with print quality of my Brother printer mFC-6490CW, I have run the ink management utility, the black, yellow and magenta printed to about 95% just one dotted line missing on the black,...
Well, this is a common problem with people who purchase Brother printers, but do not always use Brother Ink Cartridges. Brother has a cleaning agent in the print cartridge and the compatibles do not.
"If you have a lack of one (or more) color do the following:
Make sure all carts are full, placed well and are secured. Insert a new ORIGINAL BROTHER CART for the one that shows no color.
Press menu then start bk-copy then four times arrow up quick after another. machine will switch into maintenance mode and all lights will flash. Press 7 then 6 then 4 then start bk-copy. machine will initialize the carts and refresh ink within tubes and print head. After that it does some power cleaning. When finished press 7 then 6 then 3 then start bk-copy. machine will run a power purge. when finished press 9 then 9 to leave the maintenance mode. do run a quality test print.
This should clean the lines out and clear up your issue.
Jun 20, 2011 | Brother MFC 6490CW InkJet Printer
Tip
Brother MFC Printers Ink Problems
<span>Your printer does not print certain colors or does not print completely. Well, this is a common problem with people who purchase Brother printers, but do not always use Brother Ink Cartridges. Brother has a cleaning agent in the print cartridge and the compatibles do not.<br /><br />"If you have a lack of one (or more) color do the following:<br /><br />Make sure all carts are full, placed well and are secured. Insert a new ORIGINAL BROTHER CART for the one that shows no color.<br /><br />Press menu then start bk-copy then four times arrow up quick after another. machine will switch into maintenance mode and all lights will flash. Press 7 then 6 then 4 then start bk-copy. machine will initialize the carts and refresh ink within tubes and print head. After that it does some power cleaning. When finished press 7 then 6 then 3 then start bk-copy. machine will run a power purge. when finished press 9 then 9 to leave the maintenance mode. do run a quality test print.<br /><br />This should clean the lines out and clear up your issue.</span>
on Jun 20, 2011 | Office Equipment & Supplies
Poor copy quality - ink is full
Need to download to the printer software
May 31, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
Hello! Copies are very poor. New ink. Copies
Try to align the cartridges again...
Steps to align : press the setup button.. > go to tools > align cart and clean cart
Oct 19, 2009 | HP Officejet J5780 All-In-One InkJet...
Print poor copy quality
Fuser pressure (2 green levers on fusing section) may be set to envelope position.
Mar 04, 2008 | Konica Minolta bizhub C250 All-In-One...
Brother MFC-440CN won't print color
Did you use generic carts?
Do use only original brother ink carts!
Only these have special cleaning fluids mingled with the ink.
There are several advantages, too:
You can run a special cleaning mode (DO insert original carts at first!!!)
Press menue then start bk copy then fourtimes arrow-up.
machine should switch to maintenance mode (buttons will flash).
press 7 then 6 then 4 then start bk copy. machine will refresh ink within the tubes and the print head and run a special cleaning routine. when finished press 7 then 6 then 3 then start bk copy to run a power cleaning. leave the maintenance mode by pressing 9 then 9.
The machine should print without proböems. If there is a poor quality left, the printhead is affected by bad ink and cant be fixed anymore.
Jan 24, 2008 | Brother MultiFunction Center MFC-440CN...
Colors
Did you run a quality test print by pressing ink etc...?
It might be that you have no magenta anymore.
If you can see all the 4 colored blocks on the test sheet, firstly try to copy(!) a picture with pink colors and secondly run a pc print. If there is still no pink and you have it blue or green on the COPY one the scanner needs readjustment (from service personell). If you have trouble with the pc printing, too there might be
a defective ink cart holder which leaks and mingles the ink (you need a new ink cart holder then)
Jan 08, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother mfc 420 cn does not print red color
do you use generic ink? If yes, the generic ink might have clogged the ph (valve stucks inside because of lack of additives!).
Anyway, do this:
(use near full level ink carts!)
make sure carts are placed well and are secured.
Press menue then start bk copy then fortimes arrow up. machine will be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will refresh ink in tubes and ph and do some cleaning cycles. when finished press 7 then 6 then 3 then start bk copy. ,achine runs a power purge. when fisihed press 9 then 9 to leave the mode. press ink etc. to run a quality test print.
If you still cant see any magenta, the ph is defective and needs replacing!
Dec 19, 2007 | Brother MFC 420CN All-In-One InkJet...
Color printing
if you have used generic ink the ph might be destroyed.
Nevertheless give it a try (use nearly FULL carts):
press menu then start bk copy then 4 times arrow up. machine will be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will refresh tubes and ph with new ink and do some cleaning cycles. when finished press 7 then 6 then 3 then start bk copy. machine will do a power cleaning. leave maintenance by pressing 9 then 9. Do run a quality test print by pressing ink etc. If you cant see any color blocks the ph has to be replaced by a new one.
Dec 12, 2007 | Brother MFC-5440CN All-In-One InkJet...
HP Photosmart C3150 Printer Logo
99 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
