Question about ASUS Computers & Internet
I've instlled xp2 n windows 7 in my pc.bt my problem is now i want to format my pc .so when i insert window7 bootable dvd or xp2 bootable dvd then option "press any key to boot "is not coming n again the old os is running..so plz give a sol'n to my problem.
  • raazsimi Aug 29, 2010
    i'm sure that there is no problem in that bootable dvd as i've installed window7 in my friend's pc through that dvd only...::Ashish..
  • 319 Answers
Windows.bigresource.com/Win7-BOOT-DISK-ERROR-INSERT-SYSTEM-DISK-AND-PRESS-ENTER-0SlGs7SS.html
Posted on Aug 29, 2010
Format after a virus
get a windows dvd (or a bootable pen drive with windows) and insert in your dvd rom and restart the pc. The dvd will itself boot and then follow the instructions. There will be drive options with a option to format drive.After this install a fresh copy of windows.
Jan 12, 2014 | Seagate Computers & Internet
Tip
Steps to create a bootable Vista or Windows 7 USB flash drive for the purpose of...
<b>Steps to create a bootable USB flash drive for the purpose of installing a Vista or Windows 7 OS<br /> <br /> <br /> Microsoft Provides a tool to do this for you - Windows 7 USB/DVD Download Tool which is available for <a href="http://images2.store.microsoft.com/prod/clustera/framework/w7udt/1.0/en-us/Windows7-USB-DVD-tool.exe">download here</a>. If you need instructions on how to use the tool, see the Microsoft Store Help on the ISO-Tool (<a href="http://store.microsoft.com/Help/ISO-Tool">http://store.microsoft.com/Help/ISO-Tool</a>).<br /> <br /> or <br /> <br /> <br /> <span style="text-decoration: underline;">Please follow the steps below</span><br /> <br /> </b> <b>Required:</b><br /> <ul> <li>USB Flash Drive (4GB+)</li> <li>Microsoft OS Disk (Vista / Windows 7)</li> <li>A computer running Vista / Windows 7</li></ul> <b>Step 1: Format the Drive<br /> </b>The steps here are to use the command line to format the disk properly using the <i>diskpart</i> utility. [Be warned: this will erase everything on your drive. Be careful.]<br /> <ol> <li>Plug in your USB Flash Drive</li> <li>Open a command prompt as administrator (Right click on Start &gt; All Programs &gt; Accessories &gt; Command Prompt and select "Run as administrator"</li> <li>Find the drive number of your USB Drive by typing the following into the Command Prompt window:<br /> <span>diskpart<br /> list disk</span><br /> The number of your USB drive will listed. You'll need this for the next step. I'll assume that the USB flash drive is disk 1.</li> <li>Format the drive by typing the next instructions into the same window. Replace the number "1" with the number of your disk below.<br /> <span>select disk 1<br /> clean<br /> create partition primary<br /> select partition 1<br /> active<br /> format fs=NTFS<br /> assign<br /> exit<br /> </span><span>When that is done you'll have a formatted USB flash drive ready to be made bootable.</span></li></ol> <b>Step 2: Make the Drive Bootable <br /> </b>Next we'll use the <i>bootsect</i> utility that comes on the Vista or Windows 7 disk to make the flash drive bootable. In the same command window that you were using in Step 1:<br /> <ol> <li>Insert your Windows Vista / 7 DVD into your drive.</li> <li>Change directory to the DVD's boot directory where <i>bootsect</i> lives:<br /> <span>d:<br /> cd d:\boot</span></li> <li>Use <i>bootsect</i> to set the USB as a bootable NTFS drive prepared for a Vista/7 image. I'm assuming that your USB flash drive has been labeled disk G:\ by the computer:<br /> <span>bootsect /nt60 g:</span></li> <li>You can now close the command prompt window, we're done here.</li></ol> <b>Step 3: Copy the installation DVD to the USB drive<br /> </b>The easiest way is to use Windows explorer to copy all of the files on your DVD on to the formatted flash drive. After you've copied all of the files the disk you are ready to go.<br /> <b>Step 4: Set your BIOS to boot from USB<br /> </b>This is where you're on your own since every computer is different. Most BIOS's allow you to hit a key at boot and select a boot option.<br /> <br />
on May 19, 2011 | Computers & Internet
Tip
How to create a bootable USB using Vista or Windows 7
Having a bootable USB is very essential, especially if you are a Netbook user. Using bootable USB to install an operating system (OS) not only makes the installation faster, but also saves a DVD.Creating or using an USB drive to install Windows operating systems is very easy if you follow the below mentioned steps.
Here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:DISKPART and hit enter.LIST DISK and hit enter.Once you enter the LIST DISK command, it will show the disk number of your USB drive.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number), CLEAN, CREATE PARTITION PRIMARY,SELECT PARTITION 1ACTIVE,FORMAT FS=NTFS(Format process may take few seconds),ASSIGN,EXIT.
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.CD BOOT and hit enter to see the below message.BOOTSECT.EXE/NT60 H:(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.You are done with your bootable USB. You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
on Dec 18, 2010 | Computers & Internet
Asus n50vc won't install windows 7 from USB device
Try bringing up the boot menu (it will say what key to press on the splash screen) and choosing the usb. if that does not work try moving ports.
Jan 16, 2013 | ASUS N50Vc-B3WM PC Notebook
My cd/dvd drive G:\ (hl dt st rw dvd gcc h21n version.1.00) does not reads windows 7 dvd .. and it only reads cd-r/cd-rw.... plzzz help i want to install windows 7... plzz help...
It sounds like your drive is having issues, you can always install windows 7 from a flash drive (so long as your computer supports booting to one). Instructions on setting this up are here: http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/ You will need to do this from a computer with a working DVD drive to transfer the info to a flash drive.
Jun 28, 2011 | Computers & Internet
How to format compaq presario CQ 60 204NR LAPTOP WITH WINDOWS VISTA
When you boot from your Vista dvd, it will show all your partitions.
Then you can format, delete and much more...
I've you dont have a Vista dvd, you should use Hirens Boot CD.
Tutorial + Download links:
http://www.youtube.com/watch?v=3oXmwMIJLoo
Note:
You can't format your harddrive when Windows is active, so you must use a bootable cd/dvd.
I've you have any questions, feel free to post them here.
Jun 25, 2011 | Compaq Presario CQ60-204NR Notebook
Windowz format problem????
just try with another cd disk
Mar 16, 2009 | Samsung X05 Notebook
How to instal xp2 in dell laptop
try this!
if you have a xp2 bootable cd,..insert it on your cd-drive
step1: power on your laptop , then press dell until you view the bios set.up
step2: then go to boot sequence: your first boot is your ( cd-drive ) where your cd xp2 is in....
note: in boot sequence just follow the reference of your laptop settings...
step3: if you finish seting up the bios set.up,..just save and quit...then it will automatically restart...then wait for instructions view on your screen...
Mar 10, 2009 | Dell Vostro 1510 Laptop
Massstorage
This will walk through the steps to create a bootable USB flash drive for the purpose of installing a Vista or Windows 7 OS. These instructions assume that you have a computer with Windows Vista installed on it.
Required:
· USB Flash Drive (4GB+)
· Microsoft OS Disk (Vista / Windows 7)
· A computer running Vista / Windows 7
The steps here are to use the command line to format the disk properly using the diskpart utility. [Be warned: this will erase everything on your drive. Be careful.]
Open a command prompt as administrator (Right click on Start > All Programs > Accessories > Command Prompt and select “Run as administrator”
diskpart
list disk
The number of your USB drive will listed. You’ll need this for the next step. I’ll assume that the USB flash drive is disk 1.
Format the drive by typing the next instructions into the same window. Replace the number “1” with the number of your disk below.
select disk 1
clean
select partition 1
active
format fs=NTFS
assign
exit
When that is done you’ll have a formatted USB flash drive ready to be made bootable.
Next we’ll use the bootsect utility that comes on the Vista or Windows 7 disk to make the flash drive bootable. In the same command window that you were using in Step 1:
Change directory to the DVD’s boot directory where bootsect lives:
d:
cd d:\boot
Use bootsect to set the USB as a bootable NTFS drive prepared for a Vista/7 image. I’m assuming that your USB flash drive has been labeled disk G:\ by the computer:
bootsect /nt60 g:
You can now close the command prompt window, we’re done here.
The easiest way is to use Windows explorer to copy all of the files on your DVD on to the formatted flash drive. After you’ve copied all of the files the disk you are ready to go.
This is where you’re on your own since every computer is different. Most BIOS’s allow you to hit a key at boot and select a boot option.
I used these instructions to get my new Dell Mini 9 laptop loaded with Windows 7 (the PDC bits). HTH.
Jan 23, 2009 | Computers & Internet
Computers & Internet Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
