Question about Irons
Steam iron does not work sgr k123 imetec me 107800
2 Suggested Answers
  • 1196 Answers
SOURCE: The steam does not work.
Unplug the iron, and allow it to completely cool down before beginning any repairs. Inspect the steam vents from the outside, and use a pipe cleaner or other small utensil to remove any excess buildup that is blocking the vents. Be careful not to let the buildup fall down into the steam vents. Clean the steam iron's directional spray tip. Minerals and other debris can build up on the nozzle over time and will greatly hinder the use of your steam iron. Pour equal parts vinegar and water into the steam iron's water supply tank. Put the steam iron above an empty pot, and turn the iron on. Let it steam the solution until all the water/vinegar solution is gone. Now try use it to see it performance.
Posted on Aug 22, 2011
Steam iron not steaming was working ok one min then no steam
If the temperature dial is not set high enough, or the thermostat is faulty and setting the cut-off temperature too low, some steam irons will fill up their steam chamber in their soleplates completely with water and stop steaming, until the temperature returns above what's needed to continously generate steam.
Nov 26, 2017 | Irons
I have SGR pro k121 steam is not working
-Make sure dial or slide control switch to the correct position.
-Make sure there is water in the reservoir.
Good luck
Mai
Jun 06, 2016 | Euro-Pro Steam Generator EP8001 Iron
Not steaming
Steam Iron Not Working ' ThriftyFun
www.thriftyfun.com/Steam-Iron-Not-Working-1.html
Sep 4, 2013 - Here are questions related to Steam Iron Not Working. ... Why is my mini steam iron not working, after reaching 20 pounds of pressure? How do ...
My iron does not produce any steam - Philips
https://www.philips.co.uk/e/.../iron-does-not-produce-steam.html
PhilipsThe steam control may have been set to zero steam position. 2. There is no water in the tank and/ or the settings are not set correctly. 3. The steam vents of the ...
GC1015/31 Philips Steam iron GC1015 - Philips Support
Nov 18, 2015 | Irons
Instruction manual
Try Retrevo Manuals.com
Nov 26, 2013 | Irons
Issues with Rowenta Steam Iron DG 05030 steam hose
Does your iron have a self cleaning feature? It sounds to me like you have calcium build up and when you squeeze the hose it displaces the "clog" just enough to allow steam through.
Nov 12, 2012 | Rowenta Steam Generator DG050 Iron
It leaks water when I iron sometimes staining my clothes with black streaks or water stains.
Hello :
1:Clean your steam iron according to the manufacturer's instructions. Your iron is more likely to leak when it has not been cleaned properly. Plus, the water that leaks from a steam iron that hasn't been cleaned will likely be dirty and stain your fabric. Every steam iron brand is different, so be sure to check the manual that came with your iron or browse the manufacturer's website for instructions on keeping your steam iron in good working order.
2:Use your steam iron on a rigid surface like an ironing board. In a rush, you might be tempted to quickly iron a blouse or pants on the nearest available surface like a bed, carpet or even on a table with a towel draped over it. However, these surfaces may not provide the proper amount of level padding for successful steam ironing, and leaks are more likely to occur. Take the time to set up your ironing board for smooth steam ironing to reduce water leaks on a bumpy surface.
3:Allow your steam iron to heat fully in the upright position before ironing. Because your steam iron is designed to convert water into steam that will easily smooth out wrinkles on bulky fabrics, you can avoid leaks by ensuring your iron has time to get the water to the correct temperature. If you lay your steam iron in the horizontal position too quickly, water that is not hot enough to convert to steam will leak. Give the iron a chance to heat up, and then test your steam function on your ironing board cover or spare fabric swatch before tacking your favorite blouse.
4:Turn off the steam function on your iron when ironing at lower temperatures. Since your iron's steam function is designed to convert the water in your iron to steam at the right temperature, lower iron temperatures can cause water to leak if your steam setting is still activated. For ironing more delicate fabrics, turn off the steam to avoid water leaks.
PLEASE RATE !
Apr 18, 2010 | Euro-Pro Shark GI490 Iron
Everything works except steamer
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Mar 30, 2009 | Travel Steam Iron EasyGo Steam Iron Iron
Euro-Pro Steam Generator G6200H iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 18, 2008 | Euro-Pro Steam Generator EP8001 Iron
Won't steam
The steam irons I have see have a separate button to allow water from the reservoir to enter the steam chamber. This button latches down for steam and you unlatch it for dry. Also, there is a temperature range on the temp dial for steam.
The reservoir must have water in it for the iron to make steam. If calcium from the water has built up on the reservoir valve, it may prevent the water from entering the steam chamber. Straight white vinegar instead of water may help.
Nov 02, 2007 | Toastmaster 3302 Iron
Irons Logo
589 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
