Question about Hotpoint WMA74 Front Load Washer
How can l put back a fallen belt from my hotpoint washing machine?
    Problem Solver:
  • 10 Answers
Basically you have to open up the rear access panel and first place the belt on the motor and then starting from the right hand of the drive wheel, place onto it and hold with your hand whilst turing the drum wheel with the other hand and this gradually should put it back on. Just like you put a bicycle chain on.
Posted on Sep 11, 2010
  • Trickster07 Sep 15, 2010
    Be patient and protect your hands with gloves, forearms need protecting too.
  • rudy78 Oct 18, 2010
    I have the same problem . however I cant seen to locate the screws that hold the backpanel in place. actually it seems that the backpanel and side panels are one solid panel..
Plate at back of door hinge on hotpoint aqarius has fallen down
Tilt the washer back, and you will be able to retrieve the back plate from the bottom of the washer.
To refit it, you will have remove the front of the door seal from the cabinet front.
May 25, 2010 | Hotpoint Aquarius WD63 Front Load...
How to change the belt on a hotpoint wma54 washing machine
there is a rear access panel in the center of the back,remove this cover and put the new belt on the motor pulley,then over the larger drum pulley,it takes some strength unless you release the motor tensioner and retighten after the belt is on
Mar 23, 2010 | Hotpoint WMA54 Front Load Washer
Yeah hello there , im trying fitt a belt two hotpoint washing machine wf100p , i havn't taken the back off putting the belt on the motor first the on two the drum wheel gradualy turning the wheel to put...
You are doing the right thing. Hook the belt onto the motor pulley, then onto the main pulley as far as it will go, use a few cable ties to hold it on the pulley and turn the drum anti clockwise, the cable ties will snap as the pulley turns. Hotpoint have made a tool for putting these belts on but you woudn't want to pay out just for one belt.Belt fitting Diagram link
Mar 16, 2010 | Hotpoint Aquarius WF000 Front Load Washer
How do i fit a belt to hotpoint washing machine WF865
*********** unplug from mains************** top cover off ....rear cover off ....remove old belt belt ...place new belt on lower puly feed it on to larg pull turn at same time ************WATCH YOUR FINGERS ********THEY CAN GET CAUGHT EASY******* done .put covers back on ...
Dec 30, 2009 | Hotpoint Ultima WF865 Front Load Washer
How to open hotpoint wf440? our machine is not spinning but the engine is working fine. opened the lower back and the belts have fallen off. what could be the problem and how can we fix it? help me...
well you have found the problem the belts have fell off,
now how to put this wright? take the back off or the top, pull belt over all the drive pullys and the job's a good un! thing is, what caused the belts to come off in the first place???? most likly to be the motor adjuster ie: the spring! has come loos letting the belts slip off the pullys
Oct 17, 2009 | Washing Machines
My wfooo hotpoint washing machine doesnt spin, the belt came off i put it back on but then it snapped when i put the washer on spin, will the washer being empty when i did this affect the belt?
Think your belt was allready on the way out and you will need a new one. Just a coincedence that it broke when it did. It came off because it was worn and stretched.
Sep 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
How to put a belt on
remove lid and bottom cover 2expose moter pully lean washer towards u pass belt down and put over motor pully then start putting on drum pully can b very tight good luck
May 03, 2009 | Washing Machines
The drive belt has come off my Hotpoint WF860 washing machine
remove the lid and the lower back panel.
loop the belt over the motor shaft from the top and then half over the drum pulley. turn the pulley slowly while holding the belt to it until its fully on, you can also put a cable tie to hold it if it's easier for you as the are tight. the tie will break off when the belt is on fully. its a bit like putting a bicycle chain back on.
Feb 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
Drum wont turn
sounds to me like the belt may have fallen off the back of the drum.
look under the lid and see. if a wd, should be simple enoughto put it back on by removing the back cover to refit.
turn the power off though.
Jan 29, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WMA74 Front Load Washer Logo
186 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
